10hp worth $34 - Defender Source
Old January 14th, 2006, 11:42 PM
10hp worth $34
http://cgi.ebay.com/92-3-94-95-96-97...QQcmdZViewItem
I wonder what the gain in hp is for a 3.9, for the price though it isn't bad when compaired to other chips.
Old January 14th, 2006, 11:55 PM
you gonna give it a try
Old January 15th, 2006, 10:17 AM
not any time soon, maybe in the summer but then I might try the megasquirt thing then. But for someone not going the MS rout this might be something to try.
Old January 21st, 2006, 02:00 AM
It does not look like an ECU chip it looks like a MAF resistor. I would ask but generally they cause way more problems than they are worth.
If you want some more go without that much cost and at a bit less MPG get a 4.2 chip out of a 93-95 RRC for about $75.
Ron
Old January 21st, 2006, 03:52 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Read the guys feedback!
Old January 21st, 2006, 04:36 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Definitely going to be a resistor and not an actual 'chip'.
Going by the bad feedbacks, probably just a resistor that goes inline with the air or coolant temp sensor. Common cheap 'HP Gain' gimmick, along the lines of fuel magnetizers and splitfire plugs. Doesn't alter the fuel map at all, just tricks the engine into misreading the sensors.
I wouldn't risk it, much better methods of gaining power out there with much safer results. Heck, you'll probably get the same results from checking tire pressure and doing a good tune-up.
-Hans
Now I remember what this reminds me of. Those 'emissions code readers', which were usually nothing but a jumper wire in a plastic box and cost $30. All they did was put a jumper between the contacts in the diagnostic connector causing the check engine light to blink. All the software was already built into the ECU in the car.
gimmick, gimmick, gimmick.... pure and simple
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 22nd, 2006, 10:44 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Ron
Can you tell me more about this? Does it give the car more power, or is it barely noticable? I am very interested in this little tip.
Is it worth my money? JBurt Misc. Chit-Chat 9 February 28th, 2006 12:57 PM
Factory subwoofer worth? UpnOver Misc. Chit-Chat 1 May 7th, 2005 11:59 AM
Is This 97 D-90 Worth Purchasing? jchan88 Defender Technical Discussions 17 December 17th, 2004 05:25 PM
which is worth more ST or SW ron Defender Technical Discussions 3 March 2nd, 2004 09:12 PM
What do you guys think these parts are worth? Chris Cox Misc. Chit-Chat 2 January 26th, 2004 06:06 PM
