08 RRS Burning oil and smoking like crazy - Defender Source
Old July 3rd, 2015, 01:23 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
So, while I was up in NH during the week I get a phone call from the wife. Her RRS has picked up a bad habit and is smoking like crazy. Not overheated. She drove it back home, a couple miles, and it has been parked since.
I got home yesterday and replaced the PCV valve today (the internet said to), and she is still smoking like crazy. It's definitely oil that is burning. Oil is even dripping from the exhaust tips.
Checked for codes. It has the 2, 4, 6, and 8 cylinder misfires, random cylinder misfire, and misfire in the first 2000 RPM.
I can't see anything else that is common for the port bank.
Any ideas?
2008 Range Rover Sport with 4.4L gas engine.
75% of all Land Rovers ever made are still on the road...
the other 25% at least made it home.
Old July 3rd, 2015, 01:32 PM
Dripping from the exhaust????!!!!!???!!!!
That's crazy.
Obviously your oil levels a little lower than it was.
Wondering about the compression though. Wondering if the head has gone bad.
Old July 3rd, 2015, 01:35 PM
red64chevelle
Daniel Smith
Yep, oil level was lower than normal. I brought it back into spec before troubleshooting. I was thinking head, but how would that effect all four cylinders at once? I could see one, or maybe two if the gasket was blown between two cylinders, but all four?
Old July 3rd, 2015, 01:40 PM
2-4-6-8 failure at any rate! It's a British vehicle. Any type of failure is possible.
Old July 3rd, 2015, 01:45 PM
I don't know. But would encourage you to make sure all the PVC tubing is clear of obstructions aka oily goop. Then move onto the EGR system.
Old July 3rd, 2015, 04:30 PM
red64chevelle
Daniel Smith
I have read a lot of posts about the EGR system causing it. But how would it do that?
Old July 3rd, 2015, 06:04 PM
red64chevelle
Daniel Smith
Ruled out the EGR. Made a block off plate and she still smoked.
Old July 3rd, 2015, 06:07 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Just to throw out another thought. My RRS started smoking and losing power and acting totally weird one spring. Turned out squirrels had made a nest and had eaten through a bunch of wires. Don't recall off hand to what but something to just check. But if you've looked through everything you're probably good.
1994 Silver DEFENDER 90 NAS SW
Old July 3rd, 2015, 08:40 PM
red64chevelle
Daniel Smith
No birds nests or other evidence of animals.
I pulled the spark plugs, #1 and #6 had oil on them. #1 was pretty minor, #6 was soaked. I pulled them all and turned over the motor for a bit to blow anything out. Installed a new set of plugs and cleared the codes.
Started her back up. Idled great. Once I started accelerating the smoke show started again. Strangely, no codes are even showing up as pending now.
If I can't figure it out, I'll be borrowing my buddies truck and trailer and towing her down to Jamestown.
Old July 4th, 2015, 10:14 AM
Replace the PCV valve on the passenger side valve cover. It is super easy to do. You will probably need to replace your spark plugs. I would try to run it and burn up the oil before you replace the spark plugs so you don't foul the new ones.
Old July 4th, 2015, 11:19 AM
red64chevelle
Daniel Smith
Replaced the PCV valve yesterday along with the plugs. Cleaned out the PCV hose as well.
Going to pull the throttle body today just to check for pooled oil or something I can clean out.
Old July 4th, 2015, 12:16 PM
You'll probably have some light smoke for a while, I would just drive it hard until it stops.
Old July 4th, 2015, 09:37 PM
red64chevelle
Daniel Smith
Busy day. Pulled the throttle body and found a oil reserve that puts the Saudi's to shame.
Got the intake off so that I could completely clean it.
Now, I have two questions:
1. How do I tell if the old PCV Valve was bad? Both the new one and the oil one do not appear to restrict air flow in either direction.
2. How do I test the EGR valve? I pulled it and the plunger is present and does not look bad, but I can move it easily with a screwdriver. Should I not be able to?
Name:	Range intake oil.jpg
ID:	124252   Click image for larger version
Name:	Range valley.jpg
Old July 4th, 2015, 10:18 PM
I've never hear of an EGR valve causing oil consumption issues on these. There should be a noticeable difference in smoke with the new PCV valve after cleaning out the intake.
Old July 5th, 2015, 12:58 AM
Some Pcv valves rattle when clean others don't. If you can't get a replacement use brake cleaner to free up the oily goop.
Is there an oil catch can in the Pcv system?
Been through similar scenario with wife's Volvo. the PCV system inc oil catch/aggregator was totally blocked causing oil to get to the inlet side of the engine
Old July 5th, 2015, 11:13 PM
red64chevelle
Daniel Smith
FIXED!
Pulled the intake and cleaned it all out.
Put her all back together and she is running like a swiss tank
Still don't know how the PCV valve works on these jobs, but the old one must have been bad. I guess I am just used to the old check valve type.
smoking like James. bond. bkgonefishin Defender Technical Discussions 26 September 5th, 2014 06:13 PM
Any of you guys like crazy Russian women? Neil McCauley Misc. Chit-Chat 30 June 24th, 2012 08:36 PM
300TDI new injectors - smoking like mad jaherring Defender Technical Discussions 4 May 2nd, 2011 11:58 AM
new VDO gauges sway like crazy oldscratchggf Defender Technical Discussions 4 October 22nd, 2006 12:37 AM
Blowing wiper/speedo fuse like crazy....help! P1CR Defender Technical Discussions 4 March 11th, 2004 03:23 PM
