Rovers on the Rocks 2 - Page 3 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old November 10th, 2010, 08:26 AM
dchapman
Daniel Chapman
1999 D1
John,
I bet your axle is loose. If you do not tighten the bolts, you will sheer off all the bolts and make it a PITA to get it fixed.
Old November 10th, 2010, 10:19 AM
NoVaKevin
Kevin
sold#1469
axle seal
Old November 10th, 2010, 10:43 AM
dchapman
Daniel Chapman
1999 D1
Axle seals have nothing to do with it. Most people remove their axle seals anyway. You don't need them.
It could be a hub seal, and he may even have some bad wheel bearings that caused the hub seal to fail. But knowing John, I can't believe he'd drive the truck with bad wheel bearings.
I know John has a traction aid in the rear. Traction aids and the stock LR axle hub bolts don't mix real well. The stock LR bolts do not have a big enough shoulder and they're a tad short. Because of this, they become loose, even with loctite. That's why a lot of folks switch over to socket-head bolts on their axle flanges.
Old November 10th, 2010, 11:48 AM
Jarek M
Jaroslaw Maras
D1 OM617, S3 88, S3 FFR, D2 04'
Coming Sat morning and staying for dinner. See you all there.
Old November 10th, 2010, 01:25 PM
JohnK
John K
The bolts have come loose on that wheel before (one was sheared). I replaced them with new genuine LR bolts from RN. They were torqued and may have had blue loctite applied. I haven't checked them since the new leak. I am running trutracs front and rear.
Old November 10th, 2010, 02:25 PM
dchapman
Daniel Chapman
1999 D1
Throw those bolts in the trash. Then go to your local Fastenall and get some real bolts. You want some L9's with a broader, and deeper, shoulder. They should also have a few more threads on them. They should look something like this:
You might even think about some Nord Washers. You can get them from McMaster Carr.
Old November 10th, 2010, 02:35 PM
pushngo
Randy Williams
I am betting on preload.
Old November 10th, 2010, 03:21 PM
dchapman
Daniel Chapman
1999 D1
As opposed to postload?
Old November 10th, 2010, 03:31 PM
I assume he means the torque on the hub nut (ie loose). The lock tabs can break or if not properly installed the hub nut can work loose.
Old November 10th, 2010, 03:53 PM
JohnK
John K
I need to be skooled on preload.
The bolts on the left rear axle flange were loose before (one was sheared).
Old November 10th, 2010, 05:18 PM
pushngo
Randy Williams
Under your ABS sensor are shims which you remove to add load to the swivel ball If the tension is too loose it creates a gap between the swivel ball and the seal and they leak
I can't remember the load in lbs but I just remove them till I can feel drag when I move the steering knuckle by hand with the TRE disconnected
Old November 10th, 2010, 05:19 PM
The picture is of the rear
Old November 10th, 2010, 05:22 PM
JohnK
John K
So, preload is not an LSD term.
Old November 10th, 2010, 06:16 PM
disco dog's Avatar
disco dog
Tracy Dwyer
2002 D110 TD5
No, Preload is when you are getting ready to do a great looking girl, at least that what some have told me...
PURA VIDA !!
Old November 10th, 2010, 06:36 PM
dchapman
Daniel Chapman
1999 D1
That's a presoak. If you've reached the preload part, it's time to pull out.
Old November 10th, 2010, 07:41 PM
Rugbier's Avatar
Rugbier
Gustavo
Leave it to Tracy and Dan to turn the thread into a low class brothel *LMAO*
NO SIGNATURE
Old November 10th, 2010, 07:52 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
8lbs-12lbs. Correct, no TRE attached.
What tree?
Old November 11th, 2010, 08:23 AM
disco dog's Avatar
disco dog
Tracy Dwyer
2002 D110 TD5
Thumbs up
PURA VIDA !!
Old November 11th, 2010, 01:58 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I should be there before 10 am tomorrow (Friday).
So who's wheeling on Friday?
Old November 11th, 2010, 02:11 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I'll be there about 9am and ready to wheel.
Semper Fi!
Rovers on the Rocks Roverlab Trips, Trails and Events 3 May 24th, 2010 12:46 PM
Rovers on the Rocks Ring tone is ready Fivespddisco Misc. Chit-Chat 0 November 27th, 2009 11:40 PM
Rovers on the Rocks Videos Fivespddisco Trips, Trails and Events 17 November 20th, 2009 09:24 PM
Rovers on the Rocks Photo Shoot with Tara Fivespddisco Trips, Trails and Events 8 November 16th, 2009 07:39 AM
Rovers on the Rocks Roverlab Trips, Trails and Events 131 November 11th, 2009 09:40 AM
