ROAV Spring Rally @ the Cove May 20-22 - Page 2 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old May 26th, 2011, 12:05 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Be nice, Doug was paddling up hill.
Semper Fi!
Old May 26th, 2011, 12:37 PM
Originally Posted by Wolf Fabrication View Post
Really Steve? Was this pic necessary? It's like you are saying "Hey, check out this sweet pink braclet I am wearing!"
Real men wear hot pink! looking good, bartley!
Old May 26th, 2011, 05:49 PM
dchapman
Daniel Chapman
1999 D1
Who ever this is in the pic, he needs to be skooled before he hurts himself or someone else. I have a feeling that's why John took this pic.
https://lh3.googleusercontent.com/-x...0/IMG_3116.JPG
Old May 26th, 2011, 06:31 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Bad practice in the pic but doesnt seem to be under load at the same time.
Old May 26th, 2011, 07:12 PM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
Thats me, no the line isnt under load, the tow strap is dragging on the ground, the winch line is being hooked up. Fucking relax
Steve B-
Otterberg, Germany
"Walk tall, kick ass, learn to speak Arabic, love music and never forget you come from a long line of truth seekers, lovers and warriors."
- Hunter S. Thompson
Old May 26th, 2011, 07:52 PM
dchapman
Daniel Chapman
1999 D1
Does not matter. Safety is safety. A truck could pop out of gear or otherwise move. Maybe not in this instance, but straddling the line is a bad habit to get into. You always step on the line when you cross it, even if the line is on the ground.
Also, get a real winch extension line. You're driving a $25k truck and you have a $30.00 recovery strap as a winch extension. Call up Viking or who ever your favorite winch line provider is and order a correct winch extension line.
Your recovery strap is too big as well. It's way too wide. What is that, 6" wide? A proper recovery strap for your Land Rover would only be 2" wide. Wider straps are stronger, but they're not as effective during a pull if someone is stuck in mud or over a bank. A recovery strap is like a rubber-band -- it stretches and uses that energy to pull the non-moving vehicle. A recovery strap will stretch about 15%. A 6" wide strap is going to need more force (weight) to make it stretch and the Land Rover is not heavy enough. Even a 3" strap is too wide. A 3" strap would be suited for a full-size truck such as a Duramax or Hummer. A quality 2" strap is plenty strong enough for a Land Rover and is more effective than a 6" strap. Call up Master Pull or Expedition Exchange and buy a proper strap, then sell that big strap to someone on the Army Abrams M1A1 Tank forum.
Old May 26th, 2011, 08:00 PM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
yeah, I agree safety is safety. true statement, and I dont argue that.
But, my truck is parked with the front brushguard blocked by the tree in front of me, in vehicle in park, e-brake on. The truck im about to pull, is in front of me, in park, propped up on rocks. Neither vehicles are liable to move.
The tow strap isnt mine, it was attached to the stuck disco in front of me. (not the other disco in the picture)
Steve B-
Otterberg, Germany
Old May 27th, 2011, 08:12 AM
Well since we are picking on Steve's recovery methods, why is the tow strap even being used? Wouldn't it make more sense to attach the winch line directly to the stuck vehicle, thus getting more line out and using more of the winches power? I can't think of a time I have needed to use the pictured setup. I carry a big chain with slip hooks both ends for making a bridle to attach to nitwits* who go out without recovery points. Not going to ruin my tow straps just because someone is even cheaper than I am.
*Some of my best friends are nitwits
ID:	39114   Click image for larger version
Old May 27th, 2011, 08:58 AM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
because the strap was already hooked up and because the vehicle wasnt buried, it just needed to be moved back off of the rocks as seen in the previous photos.
Steve B-
Otterberg, Germany
Old May 27th, 2011, 12:14 PM
Ok. I spent a day off-roading with Mark Letorney one year at the winter romp. I thought I knew how to use a winch until that day. I now realize that I still don't.
Old May 27th, 2011, 07:37 PM
[QUOTE=rijosho;283658]
runner up:
https://picasaweb.google.com/Zucchin...82937792700306
/QUOTE]
The canoe is a Bell Morningstar. It was mine and I never used it so I sold it to Cabell.
The canoe itself is a blend of carbon fiber and kevlar. Whole boat weighs 41lbs. With my 280 lbs it rides low in the water.
http://www.bellcanoe.com/products/de...=594&catid=194
BlackGold™
We're huge fans of composite fibers here at Bell Canoe Works. They're light, incredibly strong and they look super cool. Our highest-grade composite is something we call BlackGold™ and it is the finest canoe laminate available. BlackGold™ combines the stiffness and compression resistance of carbon fiber with the formidable tensile strength of Kevlar®. Every BlackGold™/KevLight™ canoe now comes with an integral Kevlar® skid plate in the bow and stern — which is ingeniously laminated between the outer and inner layer of composite fabric for additional strength and wear resistance. Color: Natural (Black carbon weave)
Old May 27th, 2011, 09:07 PM
dchapman
Daniel Chapman
1999 D1
280lbs? I think you need to get rid of that scale you bought from DAP. You're Rugby-player big....I'm ex-mountain-biker-who-got-lazy-and-started-drinking-beer big. I'm 220lbs but you got some size on me, it's got to be more than 60lbs.
Old May 27th, 2011, 09:10 PM
draaronr's Avatar
draaronr
Here
LR3
this brings back a joke, Doug- Ingham always said he never got over 280 and he's 5 inches taller than me and I called bs, I told him his scale was stuck at 280 was the problem.
and I think the brake was on in the canoe, surely that's why you have lean.
Old May 28th, 2011, 02:19 AM
specops1526's Avatar
specops1526
Beluga '97 90
Cool, like those. Simple fix, just flip the canoe around and sit in the bow seat to distribute the weight.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 28th, 2011, 09:01 AM
I was a lacrosse defenseman in college.
Never bought anything from DAP-couldn't like Steve Young.
You're probably right on weight-haven't weighed in in quite some time. Let's retro the statement.
I weighed 280 when I sold him the canoe.
Old May 28th, 2011, 09:53 AM
Rugbier's Avatar
Rugbier
Gustavo
If they were Rugby players the size of Doug...... I would have never played Rugby *LOL*
NO SIGNATURE
Roav spring rally disco dog Trips, Trails and Events 3 March 4th, 2011 08:38 AM
ROAV Summer Nuts and Bolts Rally July 31-August 2 ukoffroad Trips, Trails and Events 16 August 4th, 2009 12:44 PM
ROAV Spring Rally ukoffroad Trips, Trails and Events 8 March 8th, 2009 08:13 PM
ROAV Spring Rally kiefffff Trips, Trails and Events 24 May 22nd, 2007 09:39 PM
GBES GPS Rally June 16/17 Nevada MG/WCB Trips, Trails and Events 0 June 6th, 2006 07:28 PM
