RC Nautique pics - Page 2 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old October 26th, 2004, 01:27 AM
Hey All
Awesome trip despite the cold nights!
The JB weld up enough to get me home (thanks Trevor!), although I did have some leakage. Need to read the manual a bit and I'll be back asking for advise on the dismantling of the axle
My scant pics are here: http://www.lhsw.com/gallery/rausch2004 . I took some video on the camera too, but somehow botched the transfer to my computer and deleted them off the camera before realizing it.
charles
Old October 26th, 2004, 09:21 AM
whats that thing stickin up beside the top of Hipperts snorkle? Looks like a whistle or something?
Old October 26th, 2004, 10:25 AM
It is, it runs off of my air compressor.
Old October 26th, 2004, 10:46 AM
sweet, I would personally have the Dixie horn but maybe that more appropiate here in the south, where did you get your whistle?
Old October 26th, 2004, 11:47 AM
I found it in my grandfathers basement kicking around with some other junk.
Old October 26th, 2004, 02:47 PM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
VDO Vision numbers
Most of this is available on the FAQ on this site, but I can confirm the follow regarding the VDO Vision series gauges:
temp gauge: 310-105
temp sender: 323-422 if you can find it (250F, 5/8-18 UNF), I couldn't. I'm pretty sure egauges had me buy the 325-095 instead, though I'm not 100% on that. I ended up getting a SunPro adapter kit at AutoZone that had the 5/8-18 UNF connector. You may want to look for the adapter kit first, then determine what size the adapter kit is converting from, and get that one. The adapter kit was cheap.
fuel gauge: 301-106
use stock sender*
tach (6K RPM): 333-158
no sender required, just adjust the switches on the tach until it's right
speedo (4"): 437-155
sender ('94-'95 only): 340-011 + mod's (see d-90.com FAQ) - I haven't done this yet, but the instructions on the FAQ are pretty clear.
* FYI, I'm not that happy with the VDO fuel gauge... I assume its the sender, but I'm not sure. The gauge swings back and forth when fuel is sloshing around in the tank. It happens once you're down about 50 miles from full, whether going down the road or trail, etc. I believe its accurate (or at least as accurate as stock was) while sitting still, and the lighting is ridiculously better, but just be aware that the needle moves with any truck movement. Its kind of annoying but you get used to it.
Good luck
Old October 26th, 2004, 03:03 PM
I noticed your fuel gauge moves more then my stock one, I have noticed that after market gauges seem to respond faster the the stock ones, so when you move your 90 the smallest amount and it shows on the gauge. One thing that you did that seemed to help was switching the Fuel gauge with the tach, so the fuel guage is hidden behind the steering wheel some and it is not as noticeable when it moves. They are a ton brighter!
souza's Avatar
souza
Dave Souza
A little more FYI:
I searched on Yahoo Yellow Pages for a speedometer shop near me, and found 2, one in Worcester, MA (30 miles) and Hartford, CT (50 miles). I called Worcester and told them exactly what it says to tell them in the FAQ.... they didn't know what the heck I was talking about. They wanted to see the cable first, and I said well can't you just tell me whether or not you can change the male end on my speedo? No, they don't do much cable work anymore... So I called the Hartford shop, and they knew exactly what I was asking, and said bring in the cable and no problem. I told him I'm 50 miles away and could I ship it? No problem, just include written instuctions and phone numbers and they'd do it... He asked a few follow-up questions (vehicle, sender, etc), but very knowledgeble and I felt good about it.
So, if you can't find someplace locally:
Connecticut Speedometer Co
89 Hoadley Pl, Hartford, CT 06120
(860) 247-3677
I haven't done this yet, but I'm ordering the sender from egauges today, and I'll be sending these guys my cable ASAP.
Yeah Mike, I saw the switch in either the tech or custom mods section, and thought it was great... I wanted to see the tach easier. It seems to make more sense with the tach right in front of you...
Old October 26th, 2004, 03:34 PM
OK Just spending more time looking at Charles pics, and I can't help but laugh at the first 2 pics of me stuck in the wheelie mud hole (#s 17 and 18). In both pics Sam is hanging out the window looking down at the mud, she must have been thinking "What have I got myself into" and in the other pic "how am I going to get to dry land".
Also in the first pic you have the norm for Tyler all weekend answering his phone!
Then in pic 29 Ken learns the fine art of hooking up a tow strap under water.
I think if we got everyones pics together we could put them together to make a movie of the weekend.
Oh bonus points to whoever can guess what is mechanically wrong with my engine in pic #32, oh and no guessing if you were there!
Old October 26th, 2004, 03:41 PM
Comments can be added to the pics - I just have not had the time. If you want I can give you a login with rights to add comments if you want Mike.
I still can't believe you could just shut it off in the water, and then start it again on the first turn. My truck stutters when I drive by a self-serve car wash.
Old October 26th, 2004, 09:58 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I believer I was on the phone talking to the Rausch repair shop a.k.a Trevor about bringing JB and gear oil for Charles. The rest of the time I was answering text messages from a lady friend. Sorry to say no booty call sunday.
Jimmy Buffett
Old October 26th, 2004, 10:29 PM
on 2nd thought Hippert you need to change from crbhpr or what ever your current plate says to pudlhpr
Old October 26th, 2004, 10:44 PM
Damn, no booty after all that text messaging. bummer.
BTW, it was 45 miles and 50-55 minutes for me to get home from where I split off on 15, so next time we go up I'll meet you up there instead.
charles
p.s. Your avatar is from RC isn't it?
Old October 27th, 2004, 03:23 PM
rvrsrvc
Trevor Griffiths
71 109 double cab
Handy Smurf says: I had a good time also!
It was nice to put some faces with some names. I'm sorry for all those that suffered misfortunes- Mike, have you been able to continue diagnosis?
Old October 27th, 2004, 03:58 PM
Yep, the oil cooler line thing that bolts onto the oil pump was loose and allowed sand into the pump, and clogged the the pressure release valve open.
Old October 27th, 2004, 04:12 PM
Doh!
How the hell did we not notice that?
Is she going to be ok?
charles
Old October 27th, 2004, 04:52 PM
Well I hope to find out by this weekend. We may not have noticed if it was packed tight with mud.
Old October 27th, 2004, 07:59 PM
flippedrover
Tyler
'94 D-90
Nope no booty yet. Still working on it. Figured it was faster for you to go that way. Yep its from that first hole we came to after the hill climb.
Jimmy Buffett
pics need of coil -please!! mattdh Defender Technical Discussions 0 April 29th, 2005 01:41 PM
Need Pics of 97s Mike Hippert Defender Technical Discussions 2 February 5th, 2005 12:56 PM
So where's the pics of some good hard rock action Dave? Mike Hippert Misc. Chit-Chat 0 January 26th, 2005 07:51 AM
Camel Trophy D90 pics? NASD90 Defender Technical Discussions 1 August 18th, 2004 12:48 PM
can someone take pics for me? mattdh Defender Technical Discussions 7 February 6th, 2004 12:17 PM
