Portsmouth Island, NC This Weekend - Page 2 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old June 28th, 2014, 12:49 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Got this from Raub a little bit ago.
Old June 28th, 2014, 01:01 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
damnit.
Old June 28th, 2014, 03:05 PM
solarguy's Avatar
solarguy
Abraham Bell
Man it looks like a great trip. As I am writing this Raub txt me and said the are running 40 mph down the beach.
Old June 28th, 2014, 03:22 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Forget your Sankey Craig, I think this is a Defenders Only outing...
Rent my
Old June 28th, 2014, 05:33 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Surf boards? Raub or Uncle Doug on a surf board? Must have pics!!!
Firemanshort
1980 Stage One 109
Sterling, VA
Old June 28th, 2014, 06:27 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
There is a single Ranger on the island after the last ferry leaves ea day and the guy wears body armor and a glock. Raub and I have already had run in's with the guy. He knocked on the cabin door and I opened it and he started stammering (guess I intimidated him ). Then Robert came out and talked his ear off until he left...
I'm watching Cape Fear just for you guys tonight.
Old June 28th, 2014, 08:15 PM
solarguy's Avatar
solarguy
Abraham Bell
Some more pics from Raub.
ID:	97760   Click image for larger version
Old June 28th, 2014, 08:24 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
It's officially killing me... I wish North Carolina wasn't so long. I know Raub drove a long way, but I couldn't get the time to do eight hours each way for this trip. Looks spectacular
Old June 28th, 2014, 08:43 PM
solarguy's Avatar
solarguy
Abraham Bell
Me too. I couldn't swing it because of work.
Old June 29th, 2014, 08:07 AM
You guys need some cheese to go with your whine.
The slave cyl went out on the green 110. Had me pretty freaked out since I'm on an island and coming off on the last ferry of the day so we won't all be there to push her on. So in a 25 mph blow (picture a sand blast effect) I climbed under the truck and was able to remove it. We too it inside and disassembled it. I used sand and a wet finger to hone the bore of the cyl and boiled the piston and seal in the coffee percolator and cleaned very thing as best I could and put it back together using spray PAM as a lube and reinstalled it. It took a long time to bleed but I have a pedal again so not driving it until its time to go. Hopefully I can make it the 5hrs home in the dark on a Sunday night.
Old June 29th, 2014, 09:17 AM
solarguy's Avatar
solarguy
Abraham Bell
Some more pics. Doug good luck my friend. Travel safe guys and gals.
ID:	97776   Click image for larger version
Old June 29th, 2014, 10:30 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Awesome guys! Looks like so much fun
Old June 29th, 2014, 10:43 AM
What's a Rover outing without someone's bonnet coming open!?
Doug I know you can shift without a darn clutch.
Old June 29th, 2014, 12:59 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Your a man's man for sure! Good skills...
Old June 29th, 2014, 03:07 PM
josh-man's Avatar
josh-man
joshua
You guys need some cheese to go with your whine. The slave cyl went out on the green 110. Had me pretty freaked out since I'm on an island and coming off on the last ferry of the day so we won't all be there to push her on. So in a 25 mph blow (picture a sand blast effect) I climbed under the truck and was able to remove it. We too it inside and disassembled it. I used sand and a wet finger to hone the bore of the cyl and boiled the piston and seal in the coffee percolator and cleaned very thing as best I could and put it back together using spray PAM as a lube and reinstalled it. It took a long time to bleed but I have a pedal again so not driving it until its time to go. Hopefully I can make it the 5hrs home in the dark on a Sunday night.
God damn mcgiever is what you are, uncle!!!!
Old June 29th, 2014, 03:38 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Was thinking just that - and with the diesel couldn't you get away with just using 2,3, & 4th gear?
Although I am sure it was one of those "I bet I can get that fixed using nothing". Nice job - and love the hone job with sand and a wet finger!
Old June 29th, 2014, 11:49 PM
Truck is a 3.5 V8 w/4bbl edlebrock. The trans is a lt95. We tried reving the engine and sliping it into gear as the rpm fell, no love. Also tried starting it in gear in 1st low but also no joy (keep in mind we were in soft sand, ie a high range in gear start wasn't an option. The kluge didn't hold up and fluid was running out of the slave as fast as we could pour it in the master, the seal was done. The ferry operator ended up sending an unscheduled boat that only holds three vehicles and Raub dragged me on with a short strap. Once back on the mainland I pulled the slave again and we loaded my truck on Raub's car trailer and he towed my 110 while I drove his tdi Tithonus. We took the truck to the nearest Batozone in Moorhead City, 30 miles away. Fortunately there was an old school guy working. Of course they had nothing close to a rover slave cyl of any kind so we measured the piston of my slave and I asked him if he had any wheel cylinders with the same bore. He pulled up some random cars looking for the right specs and found that a chevy impala used a 7/8's bore wheel cylinder and he had one. I bought it for $9.45 and popped one of the pistons out and the plunger type seal behind it. I took my slave and flipped the internal spring end over end so that it fit inside the new plunger type seal (think of the plunger in a hypodermic) as opposed to the original type seal which was a ring seal in a groove on the piston. With the spring flipped I slid the seal in and then the wheel cylinder piston as well. Fit perfectly. I took my new kluge outside where Cabell and Raub had set up folding chairs under the shade of a huge live oak tree on the edge of the parking lot. I climbed under the 110 still on the trailer and got my frankenstein slave cyl installed and Raub helped me bleed it and we got a firm pedal. I backed it down, and Raub loaded up and headed South and Cabell and I drove 5 hours home with no further issues.
Aside from the slave excitement today, we all had an incredible time. We had a perfect group assembled, all members of this forum: Greaser Bob, Ezzzzzzz, Robert Davis, Cabell, Daddymow/Raub, and myself and our daughters.
No one wanted to leave, and Bobby didn't. He stayed on the island and we gave him all our left over food, coffee etc since the only thing the park service sells out there are ice and fuel. He's going to stay this week camping on the beach with his blue heeler- Sprinkles.
We all agreed we had a better time than we ever have @ an organized event.
Collectively we had been trying to pull together and do this for nearly 5 years now, I think we will all leap @ the chance to do it again.
I never even took the insect repellent out of the box. Mosquito's were a non issue for us.
Old June 30th, 2014, 07:32 AM
87 D110 (Ruby)
Because of the wind!
Thought of you guys while driving down to NC yesterday. Bummed I could not make it like a lot of folks on here.
Doug - trust you will keep up on the outcome of the no vehicle rule, maybe if it doesn't pass we can do it in the fall.
Old June 30th, 2014, 07:52 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Keep the beach open...
We received a form that allows us to express our comments regarding the desire environmentalists have to shut the beach down to vehicle traffic that I haven't spent any time to analyze yet (more on this later).
I do intend to write my representative to push him to keep the beach open.
RDavisinVA
Old June 30th, 2014, 07:57 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
More Pictures
Originally Posted by Firemanshort View Post
Must have pics!!!
Here are a few shots.
Bobby's ride with his faithful companion
Ferry Ride over
Beach house cabins (sound side view from ferry)
Beach Picture - there was us and one other vehicle in sight (did we mention secluded?) The trasheru was put to good use.
Uncle Richard and Needle (note at this point we were the only people in sight on the ocean side).
I Garrenton-Tee you he'll catch some fish Ezzzzz on the fishing - leave some for the rest of the group
Raub and his ride
Small Thresher shark that Cabel caught is held out for a picture
Thresher shark sported by a slightly timid member of the group - It won't bite
Rides parked in the cabin area
ID:	97821   Click image for larger version
ID:	97823   Click image for larger version
ID:	97825   Click image for larger version
ID:	97827   Click image for larger version
ID:	97829   Click image for larger version
RDavisinVA
RURR Portsmouth/NOVA ranewman Misc. Chit-Chat 10 November 30th, 2013 09:18 AM
Portsmouth sighting Caribsurf Misc. Chit-Chat 5 October 29th, 2008 11:13 PM
Another Long Island sighting Red ST in Bohemia. Hans Misc. Chit-Chat 0 October 27th, 2005 08:18 PM
Sighting in Rhode Island John_Karlsson Misc. Chit-Chat 3 October 19th, 2005 06:15 PM
Saw a pair of D-90's on Long Island this week Hans Misc. Chit-Chat 0 October 7th, 2004 10:21 PM
