Overland Expo East Oct 2-4, Asheville, NC - Page 12 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old October 9th, 2016, 12:18 PM
Cummins 2.8 Crate engine program roll out display
My primary reason for attending was to meet and talk with Steve from Cummins about the 2.8 Cummins common rail crate engine program Carl made us all aware of. The program isn't being introduced until the first week of November @ SEMA where pricing will be announced but hints were it would be in the $6k range with wiring harness and ecu. The engine is 50 state compliant for vehicles up to 2000 or so. The engine can be programmed for that level emissions and will produce 160 some odd hp and 280 ft lbs or torque (the important number) or if emissions are not of concern, a second tune is available with 200 some odd hp and over 400 ft lbs of torque. There are no hardware changes between the two output ratings. Since this will be a newer approved engine configuration it will in theory be legal for install into all defenders whether 25 yr old imports or NAS spec trucks. The engine will come complete with everything but an a/c compressor which is available for a bit more $.
The injection pump has its own high pressure fuel pump so the engine is pretty much plug and play requiring only 3 wires hooked up to run but with a myriad of options available including canbus.
Most importantly unlike many defender engine swaps the engine will come with a full factory warranty- details again to be released @ SEMA.
Steve drove the Jeep the engine is pictured in down from Indiana to Asheville @ 70-75 nmph getting economy/mpg in the 30's. He indicated the worst economy they have seen in playing with many different configurations is 25 mpg. The inter cooler used for this display/test truck was way too big for the application and effected those numbers for the worse.
Turbo is on the right side of the engine so zero issues going into a lhd truck and given how nicely it was tucked against the block not likely to be an issue on rhd. Engine is running in these pictures, no noticeable vibration in the steering wheel off idle like there is with many diesel engines, very smooth. The engine weighs in @ 500 lbs so in line with what a tdi or Rover v8 weigh, ie no suspension changes required to compensate.
Name:	Cummins @ expo.jpg
ID:	159315   Click image for larger version
Name:	Cummins @ expo 2.jpg
Name:	Cummins @ expo 3.jpg
vasily's Avatar
vasily
Vasily
Originally Posted by rlynch356 View Post
Wow might have to put it back on the calendar next year... sound like they got their act together
I was impressed. 3rd time is the charm I guess
Old October 9th, 2016, 12:34 PM
Doug, what transmission will that mate up to?
95' D90 - Mostlydaily driver..
Old October 9th, 2016, 12:40 PM
TBD. Advance adapters is the only one in the aftermarket that has access to the engine to engineer adapters so far.
Old October 9th, 2016, 02:09 PM
Matt_110's Avatar
Matt_110
Matt
110
I look forward to checking this out at SEMA. It sounds great so far if the price is right.
1987 110, 2.8TGV, ZF Auto
Old October 9th, 2016, 03:42 PM
so cool...thanks doug!
Old October 9th, 2016, 06:38 PM
2016 Heritage 110 with pop top camper on display in NC and no one comments ?
Old October 9th, 2016, 06:52 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Prolly the acceptance that our overreaching gov't would never allow such a dangerous vehicle to be imported(I foresee the 25 yr rule being rescinded), since we aren't smart enough to not import it ourselves.
Or we're all just super jealous of our fellow ROW enthusiasts!!! :/ hide
Old October 10th, 2016, 05:52 PM
Chris B
72 + D1 drivetrain =?
Unobtanium combination.
Old October 10th, 2016, 06:36 PM
Have to say it was an awesome camper top. The entire roof is remade in a heavier grade aluminum. It followed the original lines so closely it took me several minutes to realize they hadn't cut and welded on an oe one, they had made a new one from scratch. What I really liked was the whole camper part of the truck could be unbolted and the truck taken back to stock in a matter of hours, and the camper roof moved to another rig. Retails for 11k.
Old October 10th, 2016, 07:49 PM
Was a little distracted by the Cummins
Old October 10th, 2016, 08:17 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Wow. That's just plain awesome.
Old October 10th, 2016, 09:04 PM
vasily's Avatar
vasily
Vasily
It was a work of art. As close as I'll ever get to the forbidden fruit.
Old October 10th, 2016, 10:45 PM
I think we don't want to talk about it so it doesn't get seized...
I have no idea about it's status here bye...
Totally awesome setup though.
Old October 10th, 2016, 10:49 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Let us remember that Unobtainium pertains to only 300M or so Americans, and Canada. For the other 7 billion on so the planet, that combo is still available new. Yeah, production ceased, but there are a ton of brand new 90, 110, and 130 trucks still avail in Europe. Puma - Better seats, doors that don't electrolysis themselves to death, complicated electronics, and factory water leaks standard.
That Heritage would be well equipped with something like this, the bed folds up into a couch/side seats, gives one headroom to stand, and can either sleep stealth below or use pop up tent:
It is funny to see Expo reflected in a positive light on this forum. Have read post about it and ExPortal here, mocking polishing jerry cans and which khaki color shows up best in Instagram. All in good fun. For my benefit, better tech here, better "adventure" there.
I am very bummed we are out of country and missed Expo East, and are going to miss URE. We did Expo two years running, and very much enjoyed, even in the rain. It ia also nice to see the cool toys from here, Aus, and SA making an appearance. ExTec, Hesch, Nakatanenga and others seems to understand there is a decent US market.
But we did make Abenteur und Allrad. 80,000 people attend that one.
I was reading about this yesterday:
The popular swap here is replacing Puma 2.2/2.4 motors with Ford Transit diesel. DuraTorque here, AKA 3.2 PowerStroke in US. 200HP/300FtLbs. Then easy remap to 250/400. All with most parts at Ford counter, and know the MT85 or ZF juicebox bolt right up.
KGH - “Stinky LR diesel” Defender Snob
Old October 11th, 2016, 12:18 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Need a shoehorn to get that in! looks amazing...
Old October 17th, 2016, 08:37 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
https://solaros1.smugmug.com/Land-Ro...xpo-East-2016/
Here are my pictures from Expo East 2016
Old October 17th, 2016, 08:54 AM
vasily's Avatar
vasily
Vasily
Thanks for sharing, Jack. It was good to catch up.
Old October 17th, 2016, 09:01 AM
Jack, I'm very disappointed in you. i was expecting no less than 700 pictures. You need to put your back into it next year.
------ Follow up post added October 17th, 2016 10:02 AM ------
PS. it was great seeing you! Hopefully I will be able to stay longer next year.
Mark Kellgren
KM4BOR
Old October 17th, 2016, 09:40 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Well I did take about 100 pictures in and around the Biltmore House but I admit that I didn't take as many shots as I should have. I'll try to meet your expectations next year. I was having fun checking out the vendors and spending money when I should have been shooting photos.
There were a lot more vendors this year with an amazing range of stuff. I just wish we could have gotten a Rover Camp a little more organized.
Expo East 2015 Oct 2-4 Asheville, NC rdavisinva Trips, Trails and Events 41 April 20th, 2015 08:36 PM
Expo EAST ranewman Trips, Trails and Events 705 December 26th, 2014 10:29 AM
East - Overland Expo 10/3-5 Asheville, NC rdavisinva Trips, Trails and Events 12 May 9th, 2014 09:02 PM
Overland Expo - East 2014 Howski Trips, Trails and Events 8 March 16th, 2014 08:49 AM
