NoVa Happy Hour - 3rd Thurs Monthly - Page 311 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old May 21st, 2016, 01:23 PM
Is known good. O2 sensors not in play in this
It does appear that the right bank is not fueling
Old May 21st, 2016, 03:08 PM
carlosz's Avatar
carlosz
Carlos
Originally Posted by 85Red110 View Post
I switched the O2 sensors, and the results were the same.
Lack there of or failure of speed sensor will cause the odd bank to go into Rev limiter mode, thus emulating your simptoms. This should be located as a box with wires coming out of the t case and speedometer cable.
If you have cats and you continue to drive you will kill them, if all you have is 02 sensors you're a step ahead of the game as there is no fear of damaged cats....
the truck ran like a "raped ape"
A fussy warm weather creature...
Old May 21st, 2016, 03:29 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I have no speed sensor. Was told I didn't require it.
It's the odd bank that's getting fuel, and burning rich. The even bank may not be getting fuel at all.
1985 Land Rover 110 3-door ST
Old May 21st, 2016, 03:52 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Temp difference between the two sides is significant. Even # cylinders are still hot though, so they are definitely firing, but just running really clean.
How significant?
Old May 21st, 2016, 04:37 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Problem solved! Lav brought the ECU from his 90 over, and BAM! Truck runs perfect. Now to source a new ECU. Anybody have one that you know works? AMR3947R is the serial on Lavs.
Thanks to everyone for their input and help. Gotta love this community. You guys are great! Let's go wheeling, gentlemen.
Kent
Old May 21st, 2016, 05:07 PM
Rover Lover's Avatar
Rover Lover
Ron Dade
97/D90 Soft Top
Kent
Glad you got it sorted, Kent!
Old May 21st, 2016, 06:34 PM
Kent
Open yours up and see if it is full of corrosion.
Old May 21st, 2016, 06:47 PM
Jimmy - he's thinking his ECU is from a 4.2 RRC, would that be "compatible" with his 3.9 setup? Or would corrosion be the more likely cause?
Old May 21st, 2016, 06:49 PM
It should run fine with the 4.2 ECU. I've only ever seen corrosion cause issues with those as far as I can remember, but I'm no 14CUX guru.
Old May 21st, 2016, 07:12 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I'll crack it open tomorrow
Old May 21st, 2016, 07:14 PM
carlosz's Avatar
carlosz
Carlos
Kent, glad to read you got it going...14 cux box is very stout it's only the second I hear has failed in many years.
As per speed sensor it is supposed to help keep idle and it is possible someone fooled the system by using some kind of potentiometer or resistor...In any manner if it runs don't hunt for ghosts.
This ecu are very cheap on ebay as just about any English v8 running efi uses them.
At one time I had about 6 of them collecting dust...all are gone now...damn, sorry I cannot offer better...
On my 87 rr I tucked the ecu under the dash after a failed deep water crossing...it never failed again due to wetness, or you could seal it with silicone and a zip lock baggie.
Many tricks to keep it dry if that was the cause of your failure.
Old May 21st, 2016, 07:54 PM
I thought I told you earlier I have an ecu here you can have. The ecu is the last thing I work have suspected though! First thing I would check is corrosion on the pins, but they are easy to open and see.
Originally Posted by pendy
I'm here for the D's
Old May 21st, 2016, 08:19 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Just an FYI, some 14CUX( pronounced SUCKS) boxes had an inherent solder flaw from the factory when new.
I had one.
Otherwise, there isnt an issue running a 4.2 ECU with a 3.9; I've done it plenty---gave me an extra .008% horsepower!
Rent my
Old May 21st, 2016, 08:29 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Yea, I'm glad any of the 14cux ecu's will work. Mine is likely corroded pretty bad, as it looks a bit nasty even on the outside. Charles, I'd be happy to buy your spare off you if mine is totally F'ed.
By the way, in your exact words, the truck ran like a "raped ape" with Lavs good ECU in it. I couldn't believe it.
Old May 21st, 2016, 08:56 PM
True dat. You came back with a huge smile on your face!
Old May 21st, 2016, 10:17 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Originally Posted by o2batsea View Post
Is known good. O2 sensors not in play in this It does appear that the right bank is not fueling
Sometimes known good ends up being not good; I suggested it because I have seen when a known good ECU that had previously worked fine end up being the culprit. As these things age, corrode, etc it happens.
Glad the truck got sorted.
Old May 22nd, 2016, 10:11 AM
4.2 ecu is plug and play for a 3.9
Old May 22nd, 2016, 10:17 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Other that being a little dirty on the outside, this thing looks perfect. Inside, the board looks brand new. No corrosion, burnt or broken connections, that I can tell. Maybe a chip is bad somewhere.
Old May 22nd, 2016, 10:37 AM
carlosz's Avatar
carlosz
Carlos
I love that phrase...lol.
Old May 22nd, 2016, 11:45 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
You can check the eprom chip under the black Lucas box. It should have a a sticker noting which fuel map it is and it should match the sticker on the case stating 3361.... "Range Rover Classic 4.2 Desensitized OBD 95 MY Tune".
I have two 14cux. Both supposedly from RR 4.2s. The AMR2941 has map 3102 "Range Rover Classic 4.2 High CR Low Reed Vapor Pressure fuel tune" and the other AMR2943 has map 3100 for a 3.9. I had been running the first but tried the 3.9 map yesterday. It seemed to run my 3.5 better. Would be interested to try one of 92rrrandall's remapped chips for a 4.6.
There's a 52 page thread over on Pistonheads about remapping a 14cux. Way over my head though.
dementia, disturbing, dood, gay nachos, happy hour, nova, pathetic, third thursday monthly, virginia is for lovers
New & Improved NOVA Happy Hour Thread Wolf Fabrication Trips, Trails and Events 103 May 1st, 2008 08:41 AM
Happy Hour in Nova? Bozman Trips, Trails and Events 125 June 25th, 2007 04:17 PM
Happy Hour in NoVa? Eric N Trips, Trails and Events 40 November 8th, 2006 03:44 PM
Happy Hour in NoVA loykd Trips, Trails and Events 163 September 14th, 2006 08:28 AM
Happy Hour in NoVA loykd Trips, Trails and Events 6 August 12th, 2004 04:09 PM
