NoVa Happy Hour - 3rd Thurs Monthly - Page 310 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old May 20th, 2016, 11:00 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Originally Posted by Kevin88RRC View Post
Not when you see the price! It's easy to test.
Yea, just found it on RockAuto..... $473.
1985 Land Rover 110 3-door ST
Old May 20th, 2016, 06:12 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Checking spark plugs. Plugs from cylinders 2, 4, 6, and 8 look brand new (#2 is shown)
Plugs from cylinders 1, 3, 5, 7 all look like garbage, as you can see.
Old May 20th, 2016, 06:27 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Dad and I are discussing, and think the ECU is telling the injectors to dump too much fuel in the left bank of cylinders? Bad O2 sensor?
Old May 20th, 2016, 06:34 PM
If all those plugs started off new, I'd be suspicious of the ones that look too clean, not the ones that look too dirty?
Old May 20th, 2016, 06:42 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
These plugs have one trip to the gas station, and one trip to Kilroys on them. Maybe 25 miles total.
Old May 20th, 2016, 07:37 PM
If I had to guess, I would guess that the ECU is wired to the injectors backwards. That is, the left side is injecting when the right side should be.
Old May 20th, 2016, 09:22 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I don't understand how it could be backwards, or how swapping anything will fix it.
Old May 20th, 2016, 09:31 PM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
My eyes may be old, but it looks as if your #2 never even fired. As Ed mentioned, I'd be more suspect about the clean ones. Are the sparking?
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old May 21st, 2016, 08:28 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I'll check for spark this morning, but it would baffle me to think the truck runs as well as it does if only 4 of the cylinders are firing.
Old May 21st, 2016, 09:21 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
If you suspect a sensor problem, pull the maf connector and try to run your engine (this will bring up the check engine light; it's ok). This will force the ECU into limp-mode which make it ignore all (?) sensor input and will allow you to focus your attention to non-ECU-based theories (I.e. Back to basics).
I don't know what yo'all tried so far, so I will not provide any more theories [but would be tempted to verify that the amplifier has the relocation kit, swap a coil, rotor head, swap ignition wires and verify (at night, very easy) that there is no arcing when the engine runs.
P.s.: you might get more help (or more theories? ) having your own troubleshooting thread than this one!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 21st, 2016, 09:32 AM
Bill may be on to something. Are the clean plugs even wet with fuel? They won't be clean if there is fuel and they are firing.
Have you done a compression check on this engine? Also you can put a stethoscope (or long screwdriver) to listen to injectors and see if they are operating.
The dirty plugs don't look that bad, hard to tell from the photo.
DOes this truck have a working CEL?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 21st, 2016, 09:36 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I have good spark everywhere. It makes no sense why one side of the engine has caked black plugs, and the others are clean. The clean ones aren't "new" clean. You can tell they've been firing. The only logical fault would be the O2 sensor on the black plug side being bad. The injectors are being told to dump more fuel on those 4 cylinders. Faults in any other sensors/components wouldn't explain the massive difference in the plugs from one side of the engine to the other. I know I'm a novice, but I can't make sense of it any other way.
------ Follow up post added May 21st, 2016 09:39 AM ------
I have no dash yet, so no lights. I don't have the tools for a compression test.
There is no way this engine runs this smooth still, or at all, with half of the cylinders not firing. Am I crazy for thinking that?
Old May 21st, 2016, 09:41 AM
Swap o2 sensors then and check the plugs after a ride. I plan to put my o2 sensors on an oscilloscope soon, maybe tomorrow. Keep getting a 44 code myself.
I will look to see if I have a code reader. I had one with a broken tab but might have gotten rid of it. We should also get you a cel, and see what rover gauge says.
Originally Posted by pendy
I'm here for the D's
Old May 21st, 2016, 10:07 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Swapped O2 sensors. They mimicked their dirty/clean side spark plugs respectively in terms of blackness. Engine runs the same, and truck drives the same. I am letting it run for a while, then will pull a clean side plug to see how dirty it got.
Old May 21st, 2016, 10:11 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Easy way to confirm rich bank. Assuming you are running CATs, measure the temp of each CAT with a IR temp gun. One CAT will be significantly hotter (~100F) as it is burning off the surplus hydrocarbons. It could still be spark, O2 sensor, plug wires, other.
Old May 21st, 2016, 10:14 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
No cats. But could still check the temp at the exhaust manifolds, right?
Old May 21st, 2016, 11:49 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
After test run, odd # plugs are still caked black, while the even # plugs are clean. Temp difference between the two sides is significant. Even # cylinders are still hot though, so they are definitely firing, but just running really clean. Something is wrong with the odd # bank, likely the injector wiring section of the harness?
Old May 21st, 2016, 12:01 PM
down_shift's Avatar
down_shift
Russell
try swapping ECUs with someone? Else, check that left O2 sensor.
Old May 21st, 2016, 12:09 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I switched the O2 sensors, and the results were the same.
Old May 21st, 2016, 12:32 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Def try a known good ECU.
dementia, disturbing, dood, gay nachos, happy hour, nova, pathetic, third thursday monthly, virginia is for lovers
New & Improved NOVA Happy Hour Thread Wolf Fabrication Trips, Trails and Events 103 May 1st, 2008 08:41 AM
Happy Hour in Nova? Bozman Trips, Trails and Events 125 June 25th, 2007 04:17 PM
Happy Hour in NoVa? Eric N Trips, Trails and Events 40 November 8th, 2006 03:44 PM
Happy Hour in NoVA loykd Trips, Trails and Events 163 September 14th, 2006 08:28 AM
Happy Hour in NoVA loykd Trips, Trails and Events 6 August 12th, 2004 04:09 PM
