NoVa Happy Hour - 3rd Thurs Monthly - Page 309 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old May 19th, 2016, 04:25 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Leaving Alexandria will secure a table.
Jimmy Buffett
Old May 19th, 2016, 04:50 PM
flippedrover
Tyler
'94 D-90
FYI deck has a party so the only seating is a couple of high tops.
Jimmy Buffett
Old May 19th, 2016, 05:13 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
My truck made it here, barely. You other punks better show up
1985 Land Rover 110 3-door ST
Old May 19th, 2016, 05:19 PM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
I'm out, still wrenchin'
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old May 19th, 2016, 05:52 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Traffic sucks
Old May 19th, 2016, 06:16 PM
NADA
im out - wrenching...and swearing still!
Old May 19th, 2016, 06:33 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
WTF, what are you doing?!?
Old May 19th, 2016, 06:41 PM
NADA
church - - my place. Wouldve been all done tonight, except for bleeding, but I received the wrong discs for the rear, couldnt get the calipers on. No worries, though they will be done by the weekend I am sure.
Old May 19th, 2016, 06:54 PM
pl626's Avatar
pl626
Peter
Front stub seals, repack bearings, replace rear calipers & discs, repack bearings. I've no garage, so I have to work outside on dry days...
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'02 Hobie Getaway
Old May 19th, 2016, 07:27 PM
speedpin's Avatar
speedpin
Looking ;)
Hhh.
~ Semper Fidelis ~
Old May 19th, 2016, 07:45 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by speedpin View Post
Hhh.
Damn, rub it in.
Jason bolts the country and the NYC HH falls apart!
Old May 19th, 2016, 09:19 PM
Originally Posted by down_shift View Post
Damn, rub it in. Jason bolts the country and the NYC HH falls apart!
Jason and Jimmy meeting weekly is just a romantic date. They invited us so that it wouldn't be so awkward.
Old May 20th, 2016, 07:49 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Good HH last night. Thanks to everyone for taking a look at my truck. Driving home last night, I took Braddock and Backlick in order to avoid 495. I didn't experience the same bogging down when getting into the throttle that had me limping into Kilroys earlier in the evening. It's still running rough, and I'm sure I'm plenty down on power still, but I don't have any experience with a properly running 3.9 to compare it against. I was able to get up to the speed of traffic on Braddock, which was probably about 45 (no speedometer yet), but still not enough power to get past 4th gear. So I'm not sure what about the drive TO Kilroys on 495 made the engine completely give up, but I don't feel comfortable driving the truck anywhere until it's sorted out.
I think a compression test, and verifying spark plug and wire function, will be the first tasks. Any other ideas? There were a lot of suggestions last night, which I probably should have written down....
Kent
Old May 20th, 2016, 08:28 AM
1of40's Avatar
1of40
1of40
Originally Posted by 85Red110 View Post
Good HH last night. Thanks to everyone for taking a look at my truck. Driving home last night, I took Braddock and Backlick in order to avoid 495. I didn't experience the same bogging down when getting into the throttle that had me limping into Kilroys earlier in the evening. It's still running rough, and I'm sure I'm plenty down on power still, but I don't have any experience with a properly running 3.9 to compare it against. I was able to get up to the speed of traffic on Braddock, which was probably about 45 (no speedometer yet), but still not enough power to get past 4th gear. So I'm not sure what about the drive TO Kilroys on 495 made the engine completely give up, but I don't feel comfortable driving the truck anywhere until it's sorted out. I think a compression test, and verifying spark plug and wire function, will be the first tasks. Any other ideas? There were a lot of suggestions last night, which I probably should have written down.... Thanks, Kent
Wish I had some insight or could be of some help. You might try talking to Wally at Loudoun Rover. He's done a ton of conversions in his day and may have some tricks.
Old May 20th, 2016, 09:09 AM
Take out each plug to check the appearance. Even tho you have very few miles on them you should be able to tell if one looks different. That will be your suspect cylinder. Could be your injector or the wire for the plug or even the plug itself.
If that doesn't reveal anything then the next step is to put the Rovergauge on it.
Old May 20th, 2016, 09:15 AM
pl626's Avatar
pl626
Peter
^^x2 what Bill said. Could be any of a dozen different issues. Rovergauge will show you right away if your TPS is bad.
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'02 Hobie Getaway
Old May 20th, 2016, 10:19 AM
Kent,
It's pretty easy to test the TPS, you just need to follow the procedures in the Range Rover manual.
Do you have the port for the Rovergauge?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 20th, 2016, 10:22 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Yes.
------ Follow up post added May 20th, 2016 10:23 AM ------
Yes.
Pretty sure the TPS is original to the engine. Might just replace it anyways.
Old May 20th, 2016, 10:25 AM
well just don't go down that road of randomly replacing shit when there is a perfectly good and reliable way to test
Yes.
Present:
1987 RRC- "Chewy 2"
Past:
Old May 20th, 2016, 10:56 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Not when you see the price! It's easy to test.
dementia, disturbing, dood, gay nachos, happy hour, nova, pathetic, third thursday monthly, virginia is for lovers
New & Improved NOVA Happy Hour Thread Wolf Fabrication Trips, Trails and Events 103 May 1st, 2008 08:41 AM
Happy Hour in Nova? Bozman Trips, Trails and Events 125 June 25th, 2007 04:17 PM
Happy Hour in NoVa? Eric N Trips, Trails and Events 40 November 8th, 2006 03:44 PM
Happy Hour in NoVA loykd Trips, Trails and Events 163 September 14th, 2006 08:28 AM
Happy Hour in NoVA loykd Trips, Trails and Events 6 August 12th, 2004 04:09 PM
