NoVa Happy Hour - 3rd Thurs Monthly - Page 290 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old January 10th, 2016, 01:50 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Firemanshort View Post
Clay - there are tools you can borrow that are nearby. Also nice red bag photo bomb in the last photo.
Ha! Bobeck is teaching me a new way to roll.
If you've seen this film it'll all begin to make sense.
Old January 10th, 2016, 09:43 PM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
Congrats Clay . . .
Got a bit done, but not all I wanted. Exhaust, brakes bleed, motor mounts corrected.
Still need to figure out the Vdo speedometer.
Seems the clutch may need a slight adjustment also.
Charles since you requested it ...
https://youtu.be/tc3uI5XoSCw
Old January 10th, 2016, 10:09 PM
mdcoa's Avatar
mdcoa
Bill
1995 Discovery
Mike, that sounds great. Nice work, and congrats! Good luck with the VDO stuff--nothing like doing four projects at once.
Also. don't forget to adjust the shoes on the left rear brake--I had to back off the snails all the way to get the drum on . . .
Old January 10th, 2016, 10:19 PM
wanabewheelin
Michael Sword
Ok, will take a look at them. Thanks again!
Old January 10th, 2016, 11:15 PM
Rover Lover's Avatar
Rover Lover
Ron Dade
97/D90 Soft Top
Thanks for posting the video! What a treat to see/hear it run. You've got a keeper there, Mike! I enjoyed working with everyone.
Charles, what did you figure out about the clutch slave, anyway? Man! That was a hold-up. Sure wish we'd have installed it before installing the engine/tranny/xfer.
Things must have come together quickly after I left. Dang! Was I the impediment?!
Old January 10th, 2016, 11:17 PM
NADA
Let's just say Galpin knows that the bleed nipple is ALWAYS on the top....and if anyone needs a slave done - he could do it in his sleep or blindfolded.
Old January 10th, 2016, 11:34 PM
Rover Lover
Ron Dade
97/D90 Soft Top
You mean he wasn't asleep and blindfolded! I don't know how he got the plastic clip on the slave rod snapped in place in the blind, basically.
Old January 11th, 2016, 07:28 AM
Yeh Bill I texted him that the brakes were still undone.
Old January 11th, 2016, 09:03 AM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
He was also curled up, almost in a fetal position, bit of a contortionist...
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old January 11th, 2016, 12:32 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Oh no
$100 and I'll edit them
Jimmy Buffett
Old January 11th, 2016, 09:34 PM
Yeah the slave was a bitch, but we got her done. The third time's a charm. It would have been way easier to have put the pushrod in when installing the fork, and also installing the slave (in the right orientation) while out of the truck
Sounds great. Very impressed with the motor and their packaging!
Originally Posted by pendy
I'm here for the D's
Old January 12th, 2016, 10:40 AM
Rover Lover
Ron Dade
97/D90 Soft Top
Mike, be sure and check all lug nuts for tightness. Not sure if you heard us discussing it, but you really need longer lugs with those wheels as only about 2/3 of the threads on the nuts are able to grip. Also noted were missing bolts to frame from bulkhead in footbox areas. This is a very nice truck!
Old January 12th, 2016, 12:54 PM
wanabewheelin
Michael Sword
Ron, should I just replace the studs with longer ones? What is the best way to go about this??
Old January 12th, 2016, 01:16 PM
Don't listen to Ron. Those lugs are fine, lots of folks run them with no problems.
You can buy longer ones but they aren't cheap and they can be a hassle to install without removing the hubs.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 12th, 2016, 03:55 PM
Rover Lover
Ron Dade
97/D90 Soft Top
When we did the lugs on Kent's truck, we drove the short ones out with a hammer and pulled the longer ones in with a plain nut on the front. Wasn't involved in the back. Didn't require disassembly of front hubs to accomplish. Apparently, there are other opinions, but Galpin and I discussed and we feel longer is needed. Although you can apply same torque to each lug nut, only a bit over half the threaded area is making contact. Common sense would be that you are making only a little over half the friction, which is what makes threaded fasteners work. I'd sure do it if my family rode in it. Does anyone else remember if we did Kent's back lugs while we had the halfshafts out?
Old January 12th, 2016, 05:33 PM
flippedrover
Tyler
'94 D-90
I remember there being an issue with at least one hub when you two were replacing the studs.
Jimmy Buffett
Old January 15th, 2016, 08:41 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Anybody local have a blast cabinet that I could use? Need to clean up the winch mount pieces for the L322.
thanks
Old January 15th, 2016, 09:05 AM
NADA
Listen to Ron...may be a pita but it is needed. It's a safety issue
Old January 18th, 2016, 03:22 PM
mdcoa's Avatar
mdcoa
Bill
1995 Discovery
Mike, is that 110 in the road yet???? If so, first ride report, please. If not, status update?
Old January 18th, 2016, 03:27 PM
NADA
yep - he has been driving it to work
dementia, disturbing, dood, gay nachos, happy hour, nova, pathetic, third thursday monthly, virginia is for lovers
New & Improved NOVA Happy Hour Thread Wolf Fabrication Trips, Trails and Events 103 May 1st, 2008 08:41 AM
Happy Hour in Nova? Bozman Trips, Trails and Events 125 June 25th, 2007 04:17 PM
Happy Hour in NoVa? Eric N Trips, Trails and Events 40 November 8th, 2006 03:44 PM
Happy Hour in NoVA loykd Trips, Trails and Events 163 September 14th, 2006 08:28 AM
Happy Hour in NoVA loykd Trips, Trails and Events 6 August 12th, 2004 04:09 PM
