NoVa Happy Hour - 3rd Thurs Monthly - Page 107 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old January 19th, 2012, 02:25 PM
Originally Posted by Rugbier View Post
who makes that plate?
Wondering the same thing. You could probably just run the wiring through the hole behind the light, no? I think I need one.
Old January 19th, 2012, 02:39 PM
carlosz's Avatar
carlosz
Carlos
Originally Posted by down_shift View Post
Good intel with the part #s. Stepped out for "lunch", picked up and installed that Bosh fuel filter and no dice, it drove the same. Back to thinking clogged left cat. Charles has an IR gun for and complete y-pipe. Will compare the inlet/exit temps of both cats and do the 'ol switcheroo if needed tomorrow.
fair enough, worth a shot, now you know you have a good filter so it is out of the equation/ trouble shooting chart.
Old January 19th, 2012, 02:53 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Originally Posted by Firemanshort View Post
My only update to the beer drinking table story telling is that I got Huff's bracket bolted to my truck and now have an antenna mounted - it is really long (just bragging). I could not figure out how to get a work light mounted with the Stage One reverse light in the way - so I gave up on the work light. (Now I have to either find a buyer for a brand new Hella Matador light or send it back )
Temporary hijack...
Why not wire the work light up to come on in reverse as well and use it as the reverse light? Then it wouldn't matter that it covers the stock lamp.
I have mine wired up to come on with reverse, on demand via switch or off.
Hijack off... Resume normal programming...
ID:	46335   Click image for larger version
Old January 19th, 2012, 03:14 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Work brings me to Newark Penn Station every few weeks. What nights do you guys get together for HH?
BTW - if you continue to troll ours, best that you make it down here for one.
Old January 19th, 2012, 03:21 PM
We don't have a set week or day or anything. Usually it's when I, Tom, or someone else suggests a meet-up, we try to make it happen - probably on a quarterly basis at best.
I have told Charles and Gustavo to host a BBQ and I will make it down, but I haven't seen it happen yet!
Old January 19th, 2012, 03:23 PM
Bmxer06pa's Avatar
Bmxer06pa
Doug S
2000 disco 2
I'm out for tonight I have been out of work sick for a couple days now, no going out drinking might not be a good idea.
Dave I might be interested in taking that light off of your hands. My work lamp shit the bed anter only a few days.
Old January 19th, 2012, 03:28 PM
I'll have one here in the spring. Will let you know when.
Originally Posted by pendy
I'm here for the D's
Old January 19th, 2012, 03:34 PM
carlosz's Avatar
carlosz
Carlos
if at all possible I will drop by to grab bite after class, say 9:30'ish to 10:00.
see ya'll then (maybe).
Old January 19th, 2012, 03:40 PM
I'll be there at 6:00 pm, will stay for an hour but have to go back to work afterwards...am planning for a day off tomorrow to work on my truck!!
Old January 19th, 2012, 04:25 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
That is one of Oliver Whiting's (Overland Specialties) brackets.
------ Follow up post added January 19th, 2012 04:26 PM ------
you know that you won't be able to get out of there in less than an hour! we need at least two to get sufficient badgering in
------ Follow up post added January 19th, 2012 04:28 PM ------
Originally Posted by ipgregory View Post
Temporary hijack...
I know that Dave already has a Matador but Hella also makes a dual beam work lamp that could be used as both a backup light and a work light off of a switch...I plan to change out my Matador for this setup.
Old January 19th, 2012, 04:30 PM
Rugbier's Avatar
Rugbier
Gustavo
Thought so. ( on the bracket )
I had the dual light on my Black 90, maybe Chris wants to put pics of the set up
( came on by itself in reverse and had a little switch in the speaker housing )
NO SIGNATURE
Old January 19th, 2012, 04:32 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
exactly! Chris, post up if you can.
Not sure if Oliver still has these like he did but I picked that aluminum one up for about $20 shipped including a backing plate. The backing plate is a little thin if you are putting a heavy light on there but otherwise works well.
Old January 19th, 2012, 04:56 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Bmxer06pa (Doug) - Galpin licked the light. Fight with him - I do not care who gets it.
Others - the lens from the Stage One reverse light interferes with the space over the bracket. I can not physically mount the light on top of the bracket. It looks like I can sneak or slide it up under there until you put the two peices together in the same space and it is definately a NO-GO.
Firemanshort
1980 Stage One 109
Sterling, VA
Old January 19th, 2012, 05:00 PM
Doug it's all yours if you want it. I probably shouldn't be buying it anyway. I have an el-cheapo one without a handle that's bracket is already rusting, but since I never actually wired a switch to it, and have the second el-cheapo one left froma pacl of two, I don't *need* it. I suspect the hella will just rust as well. LOL.
Old January 19th, 2012, 05:40 PM
After promising to be back at Happy Hour for 2012 - I am backing out of the first one of the year.
February is looking better, though.
I also installed a new 12volt plug - permanent mount on the dash - behind a fuse (lesson learned).
Once I get my cardboard radiator muff artwork worked out in my head and onto the paper.... that will complete my Winter Romp preparations. We are looking good for a Friday, February 17th 5AM departure. (BTW - it looks like the Feb HH will be on Thursday Feb 16 - so the HH will not be long as I might be leaving early to catch much needed sleep before the long drive.)
David:
Don't know if it helps since it's a bit late in the discussion, but here's my rear worklight on the Series...I took out one of the two rear idiot lights and mounted the bracked through that hole and ran the wiring through the body cappings.
I likewise plan to wire it up as a reverse light, installed the switch as such but just need to add a plunger on the tranny - just haven't gotten around to it so flip it on manually when I'm backing up.
I'd probably say just remove the actual backup light and replace it in that spot with a rear worklamp. Should still pass inspection (if you even need it) and will get you the desired result of getting the worklamp on there.
ID:	46358   Click image for larger version
Old January 19th, 2012, 05:52 PM
David - followup...actually, the Matador is a 4-prong attachment, from looking at your original pics with the bracket your using maybe you should swap the Matador out for a genuine LR (like the one shown in my pics) that only uses a single attachment point. Then you actually could leave the reverse light AND mount this on your current bracket without issue I believe.
Old January 19th, 2012, 06:18 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Sorry fellas, I'm out. Still home with the kids waiting on the wife to show up
Semper Fi!
Old January 19th, 2012, 06:33 PM
Ray_G's Avatar
Ray_G
Ray Gerber
What?!?
About 5 miles out
Old January 19th, 2012, 07:57 PM
carlosz's Avatar
carlosz
Carlos
Rats, technical classes are boring specially when you have taken them many times before but it is a requisite in order to renew a licence......bummer
Old January 19th, 2012, 08:08 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Decent turnout tonight (10)...though the density of Rovers in the parking lot is a little low.
Reporting from the scene...Tony...
dementia, disturbing, dood, gay nachos, happy hour, nova, pathetic, third thursday monthly, virginia is for lovers
New & Improved NOVA Happy Hour Thread Wolf Fabrication Trips, Trails and Events 103 May 1st, 2008 08:41 AM
Happy Hour in Nova? Bozman Trips, Trails and Events 125 June 25th, 2007 04:17 PM
Happy Hour in NoVa? Eric N Trips, Trails and Events 40 November 8th, 2006 03:44 PM
Happy Hour in NoVA loykd Trips, Trails and Events 163 September 14th, 2006 08:28 AM
Happy Hour in NoVA loykd Trips, Trails and Events 6 August 12th, 2004 04:09 PM
