NOVA D90 engine install Saturday 2/12 - Page 2 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old February 9th, 2011, 11:40 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Well I was there for the last engine install in one of your 90s, I'll try and make it to this one.
Old February 10th, 2011, 08:55 AM
Originally Posted by cgalpin View Post
Oh come on. You can't sell the girlfriend on a lovely romantic weekend down to the area beneath the major flight path of a huge international airport that happens to have an interesting aviation museum nearby with "free" admission but charges you out the wazoo for parking? Take in a few sights, visit some museums, get stuck in traffic, throw an engine into a D90...
Fixed it.
Just pulling your chain man.
Old February 10th, 2011, 08:56 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I'll wander buy if ya'll are still at it when i get done shopping for work cloths.
Jimmy Buffett
Old February 10th, 2011, 09:11 AM
That's the spirit!
Originally Posted by pendy
I'm here for the D's
Old February 10th, 2011, 10:12 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Sounds like fun! Wish I didn't get enough of that kinda fun here! Make sure that torque convertor is fully seated before tightening up the bell housing!
Email is
Same place, new dogs.
Old February 10th, 2011, 10:39 AM
Yes you get to have engine install parties all the time!
This is stick shift so just clutch and pressure plate. I torqued them down to spec, and will do it again after I remove it to put the stupid pilot bush in that I didn't realize was missing (due to the engine coming out of an auto)
I assume you can do an install without help, and I am sure I could too, but I know that for at least aligning the engine and transmission it's much easier with a hand. I went and helped fireman short put his engine in a couple of weeks ago and he only needed a hand for about an hour to get the engine lined up and a few bolts in place in the bell housing, and motor mounts in.
But as I said, the more the merrier, and I don't expect anyone to have to do a whole lot. I'm perfectly happy doing all the dirty work and getting under the truck (bell housing bolts, motor mounts, and downpipe). Hooking up the fuel lines, wiring harness, etc is pretty easy on these, and with the radiator out of the way so are the power steering lines. Radiator is easy too, although the top coolant lines may need some adjustment and due to the differences in the lower pipes I plan to switch the reservoirs. I have to make a little harness for the ignition module but that's easy as I have the connectors now.
Am I forgetting anything? I'm still sans clutch hydraulics parts so that won't be hooked up.
Old February 10th, 2011, 12:44 PM
Whoohoo, clutch hydraulic bits arrived. 17 days via air mail for 0.5kg envelope. Crazy.
Old February 10th, 2011, 03:46 PM
Rugbier's Avatar
Rugbier
Gustavo
I was expecting the Ladies ( Carlos, Bill, Pedro ...etc ) to bring us coffee and donuts..damn *LMAO*
NO SIGNATURE
Old February 10th, 2011, 09:33 PM
Crickets...
Anyone coming have a soft line for the clutch, and/or what thread it is? I bought a new one and also the lock nut, but the lock nut never came. I am stripping the threads on the soft line with the old nut. So at a minimum I need to get a nut that fits and likely a new line. This is the smaller upper side. Will be ordering something as soon as I can get online otherwise.
Charles
Old February 10th, 2011, 09:49 PM
should be M10 x 1.0
Crickets...
Charles
Old February 10th, 2011, 10:08 PM
Thanks Dave, It seemed close to a m10 1.5 nut I have but not close enough so that sounds about right.
Do you have a M10 1.0 tap and die? I'm going to see if I can order a replacement but maybe I can salvage what I have if it doesn't arrive in time. Otherwise it just means it isn't going anywhere Saturday, and it's a tad harder to put in with the engine in the bay.
charles
Old February 10th, 2011, 10:52 PM
Rugbier's Avatar
Rugbier
Gustavo
charles
I might be able to borrow the tap and die set from the Toy Store. Call me in the AM
Also, you need a M10-1 nut?, I am sure I have that or HD will
NO SIGNATURE
Old February 10th, 2011, 11:10 PM
I have already damaged the threads on the flex line - yes was too hasty and should have tried to buy a nut first. My HD sucks for nuts and bolts, especially metric, but now that I have screwed up the threads I'm wary of being able to verify it is indeed m10 1.0, as well as being able to get the hard line threaded on cleanly without then screwing that up. So at this point I think I need to run a die over the threads and if it looks decent, go get a nut. I'll see if I can get to Lowes tomorrow night and get one in advance if you can bring a die.
Otherwise it just means I won't be able to test drive it until I can get a replacement. Not the end of the world, and any number of other things could go wrong and put me in the same boat anyway
Old February 10th, 2011, 11:56 PM
I checked my tap and dies and I have m10 x1.25 so maybe that is it? You can thread on a 3/8-24 but it is a loose fit.
edit: checked again with a brake flex hose and they are M10 x 1.0 as originally suspected. I don't have the die for it. you need a short (jam) nut
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old February 11th, 2011, 06:44 AM
The Dro
Dro
1988 Ninety
charles
Charles, Call Loic. He has several Metric nuts/bolts in all sizes. He may have what you need.
...almost forgot.
Old February 11th, 2011, 07:02 AM
Roverlab
Trevor Griffiths
For some reason, I had the red 90 in my mind, which, as you know, is auto! For the last 5 years, I've had to do them by myself, but it is so much nicer to have an employee!
Email is
Old February 11th, 2011, 07:27 AM
Thanks Dave
Yes, existing is a jam nut but it appears there is room for a regular sized one. I also need a few nuts for the exhaust studs still so will go to Lowes this evening and hopefully they will have them.
Pedro, I'll call Loic - I need to get my table saw from him anyway. Gotta start laying some hardwood flooring next week.
Trevor, good to hear the new guy is working out.
charles
Old February 11th, 2011, 08:36 AM
flippedrover
Tyler
'94 D-90
So you have Max helping out huh
Jimmy Buffett
Old February 11th, 2011, 09:24 AM
Rugbier's Avatar
Rugbier
Gustavo
No he has trained Francis
NO SIGNATURE
Old February 11th, 2011, 03:03 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Chuck, I'm 100% in. Someone better bring donuts and strippers.
Anyone need 110 rear shafts?
Goose, you want me to bring the rack stuff?
Semper Fi!
90, d90, engine, nova
D90 Engine Wiring Harness for sale Snatcher For Sale - Parts 4 April 2nd, 2008 03:53 PM
94 D90 stalling when load put on the engine makof-16 Defender Technical Discussions 7 May 31st, 2007 08:23 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
D90 Engine Overhaul Landyfun1 Defender Technical Discussions 19 April 20th, 2004 06:02 PM
» Defender Registry
Watson
80sailor
D
drsmiley
Add your Defender
