Mar 2006 - Page 5 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old October 3rd, 2006, 10:39 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Mike is half way across the country.I am sure they are stock, is yours already to drop straight in or do i need to get anything else. also need the lock nut.
3rd low and BOOT IT
Old October 3rd, 2006, 10:44 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
You can drop Randy's in but you will have to live w/o the rear lockers. If you decide to trailer the 90 and install the 3rd at MAR you can stop by our camp (PR camp) and use our generator and impact gun. I can swap the 3rd in about 20 minutes.
John C.
Old October 3rd, 2006, 11:20 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Originally Posted by Bozman
Tony,
10 or 11 am is fine with me. Rendezvous at your place?
Greg
Works for me -- haven't heard yet from Ken, Brian or Keith ('95 lwb) -- I'll update as I hear more.
Old October 3rd, 2006, 12:35 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
John, will drain the oil tonight and look for bits, will more than likely trailer it down and fix there
3rd low and BOOT IT
Old October 3rd, 2006, 01:08 PM
Awesome! To be clear Jimmy, swapping the 3rd is a quick and easy temporary fix. Once you have the old one out you can determine how to fix and do it at your leisure, and put it back in later when done. You then have a spare third, or can resell it. I have a broken one I'll rebuild with an ARB one of these days.
hth
charles
Old October 3rd, 2006, 01:09 PM
JohnC
I just spoke to Jaime Crusellas and he is bringing down an extra 3rd just in case. Randy should bring his down also since I have a feeling I'm gonna need one (my shoes just got bigger).
John C.
Old October 3rd, 2006, 03:16 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Jimmy, when are you heading down?
I think I may be leaving thursday morning.
Im renting a van to tow the d down as the tranfer case isnt sounding to good.
Will T will have one waiting for me when I get down. I may have to do a field swap.
Can any bench press a transfer case : )
Old October 3rd, 2006, 03:22 PM
JohnC
I did mine about a month ago by myself. If you need help just stop by our camp and I'll give you a hand.
The only problem I had with mine (95 DI) is that I got a 97 DI TC and it had the short spline shaft so I had to order one from AB. I'm just telling you this so that you make sure you get the right TC.
John C.
Old October 3rd, 2006, 03:51 PM
ron's Avatar
ron
Ron
this t cas is supposed be coming out of a 99 disco. will it work with a 97 defender?
Old October 3rd, 2006, 03:52 PM
Ron, I just did mine recently when replacing the tranny - it's not that bad. I have a jack stands and little tranny jack I could bring - that and a piece of plywood (so the tranny jack can roll smoothly) should make it pretty easy to get it in place. Just let me know if you need me to bring them. I could probably lend a hand too depending on when you will be doing it (gotta clear it w/ the boss) and it should go pretty quickly.
charles
Old October 3rd, 2006, 04:53 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Ron i would be leaving after work thursday night, bout 6pm.
if mike heads south from where he is i could give him and his dad a lift home sunday
Just been talking to a tec whose a so called expert on T/C ect, he tells me when tightening the flange nut more often than not it will jump the last thread so when you come to undo it cross threads its self. hes just lent me some of his tools (which are alot bigger than mine) so will give it another try tonight. then drive it till it drops the weekend. if there is gonna be spare diffs ect and iv'e got spare half shafts i should be ok
3rd low and BOOT IT
Old October 3rd, 2006, 05:19 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I'm comming don't you worry. I just have to sort out a steering problem now. A really low speeds the front wheels are wobbeling on occasion as well as getting a baging noise when I turn. I think i bent track rod again when I did my impersonation of Jimmy at rausch creek. Even if i don't fix it thursday morning before trevor and crew get here I'll hitch a ride down with him.
Jimmy Buffett
Old October 3rd, 2006, 06:08 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Tony et al,
suggest that we make it 0900 at Tony's house. We MIGHT make it out by 1000
Old October 3rd, 2006, 07:54 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
I borrowed a 2ft pipe wrench to hold the flange and a 2ft bar, slowly got tighter,thought i would give it one last pull and stripped the thread completely. Back to quare one (front wheel drive)
3rd low and BOOT IT
Old October 3rd, 2006, 08:46 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Originally Posted by loykd
Tony et al,
Works on this end. Let me know if anyone needs directions.
Old October 3rd, 2006, 09:18 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Won't be able to make it down to MAR but I have a stock 95 rear differential, carrier and all if anyone wants to borrow it/buy it. John knows where i live and can take it down. Make sure someone has a propshaft tool
Old October 4th, 2006, 06:45 AM
ronward's Avatar
ronward
Redsrover
None - sadly
Il be there tomorrow around noon. Look for the conniston green One Ten!
Anything is possible, with the right tools...
Old October 4th, 2006, 12:36 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
I'm going but not bringing my truck. I had queer sounds before i did my diff oil seal and i dont want to fix that down thre only to find out something else is wrong. Gonna be towing Rons down and trash his instead, he's gonna supply the whisky and guinness althought it would have been cheaper to rent his own tow truck
3rd low and BOOT IT
Old October 4th, 2006, 06:58 PM
ron's Avatar
ron
Ron
Jimmy I said I'd buy the gas and Guinness. I cant afford the whisky you'd drink.....
Heading out of MA 12:00
call me on the cell if your stuck or want to caravan
781 640 2640
Old October 5th, 2006, 06:11 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
If i mix the gas with plenty of ginger ale i suppose it would pass as whisky
3rd low and BOOT IT
MAR Group Photo loykd Trips, Trails and Events 42 September 29th, 2004 10:18 PM
Where to camp for MAR Dfndr90 Misc. Chit-Chat 11 September 27th, 2004 10:42 PM
Rausch Creek, Mar 26-28 loykd Trips, Trails and Events 125 March 31st, 2004 07:54 PM
MAR 2003 photos KeithElisa Misc. Chit-Chat 3 October 14th, 2003 08:16 AM
MAR Orphans loykd Trips, Trails and Events 60 October 7th, 2003 10:58 AM
» Defender Registry
MIke's D90
usla1
248
xjahx
Add your Defender
