LA Happy Hour with Jeff Briggs - April 12th - Page 3 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old April 12th, 2012, 10:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
Anyone coming?
Old April 12th, 2012, 10:46 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
On my way!
Old April 13th, 2012, 01:10 AM
silby32's Avatar
silby32
Josh Silberman
1997 D-90 #123 SW
why did I just get this now?
Old April 13th, 2012, 02:52 AM
bjf's Avatar
bjf
barry f
94 ST #395
In typical LA fashion no one showed. We will be working on the truck all day tomorrow if anyone wants to stop by.
Progress today
Resealed transfer case access plate - only part that was leaking on the transfer case
Resealed top plate on transmission that holds the shift lever and the ground bolt. Odd leak but we fixed it.
Had the fly wheel resurfaced and it is back on the truck.
New cross seals, rear main installed.
Oil pan resealed.
Put manifold back on. New style gasket and new y pipe studs
Primed transmission crossmember.
Realized my new steering pump is leaking so I have some rage for that and my oil pump has seapage. These trucks are shit.
ID:	50224   Click image for larger version
Old April 13th, 2012, 07:43 AM
Ha. Probably because you only put up the location at the last minute! Not that I could have made it anyway.
Old April 13th, 2012, 10:40 AM
phoenix37's Avatar
phoenix37
john
not true...i showed but 12 hours early.... Jeff is a saint a for helping you and thanks for the RRC door handle! I owe you one.
Old April 13th, 2012, 03:26 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
So you guys went to Barry's pad?
Robert Deniro
Old April 14th, 2012, 02:22 AM
bjf's Avatar
bjf
barry f
94 ST #395
Tranny bak in truck - holyshit so damn heavy. No clue how it line up. Thanks Jeff and Greg for breaking your backs getting it in.
Filled tranny with royal purple
Filled transfer case with royal purple
Tomorrow bleed clutch, put exhaust back on, put floors in, drive Jeff to the airport.
ID:	50282   Click image for larger version
Old April 14th, 2012, 12:19 PM
Neil McCauley
Neil McCauley
Not that it would help you now, but if you mentioned it earlier, I would of let you borrow my R380 clutch alignment tool. Oh well.
Robert Deniro
Old April 14th, 2012, 02:21 PM
Neil McCauley
Neil McCauley
Bought the tool but thanks.
Neil,
Do you do everything yourself or have a good shop. I need to change my steering pump again.
------ Follow up post added April 14th, 2012 10:36 AM ------
Oops wrong account - Barry
I do it myself, pump really isn't that bad, you just have to have a spare high pressure line and o washers handy just in case it gets threaded. I'm using the autozone pump that came without the green plastic spacer/washer on the shaft but the belt keeps it aligned, no problems or leak for almost 2 years. Drive it over and I'll help you change it at my pad. It's a slight PITA to reach the bolts but if i can do it..
------ Follow up post added April 14th, 2012 11:24 AM ------
Barry pm me your address and I'll see if I can stop by.
Robert Deniro
Old April 14th, 2012, 11:58 PM
bjf's Avatar
bjf
barry f
94 ST #395
Neil
I will be in touch. We can meet up, do the pump and talk whores.
So the clutch is in and everything is back together. I never thought it would work after we were done but sure enough it drives well. Huge thanks to Jeff for flying in and helping me out. I still have no clue why he was so generous with his time. He clearly is out of his mind. Also huge thanks to Greg who drove over and really helped get the tranny back in. Something about lining up dowels. I wasn't paying attention.
Also honorable mention to Aaron for coming over and helping out.
No thanks to Brian who came over in his perfect truck and mocked.
Old April 15th, 2012, 09:05 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Sorry I wasn't able to come up... it's getting close to deployment time and things are pretty hectic!
Old April 16th, 2012, 10:23 PM
navydevildoc
Neill Thornton
Josh and I leave on the 1st for just under 6 months... we work on the USNS Mercy, so we will be going around the south pacific doing good in the name of the USA. It's a pretty safe gig.
Old May 3rd, 2012, 01:47 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Anyone want to meet up tomorrow (Thursday) evening? I'm in town until Friday morning. I'm staying down in nowheresville Cypress tonight but moving to a hotel up near LAX tomorrow after my meetings.
happy hour
Chicago Happy Hour! Stmpede Misc. Chit-Chat 29 November 30th, 2013 12:54 AM
LA Happy Hour phoenix37 Trips, Trails and Events 745 January 28th, 2012 12:24 PM
New & Improved NOVA Happy Hour Thread Wolf Fabrication Trips, Trails and Events 103 May 1st, 2008 08:41 AM
Atlanta Happy Hour woldd90 Trips, Trails and Events 3 June 13th, 2006 05:48 PM
Happy Hour in NoVA loykd Trips, Trails and Events 6 August 12th, 2004 04:09 PM
