28th Annual Hump N Bump 7&8 Nov 2008 - Las Vegas - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Trips, Trails and Events
Old August 17th, 2008, 04:29 PM
BCR's Avatar
BCR
Brian Richardson
Need a D90 Tdi
Would love to see more Defenders on these trails.
The 28th Annual Hump N Bump will take place
November 7th and 8th 2008. This is a multi club & breed rig event to benefit the So. NV. Trails Fund.
28th Annual Hump n Bump CLICK FOR INFO
this year we have reserved the County Fair grounds for camping
it has power / water and lots of room for all the RV`s
The Trails!
The follow trails will be ran this year:
Arockalpse - Extreme trail with a gigantic boulder at the beginning. This trail is rated 4 and should not be attempted unless you have 35"+ tires, 2 lockers and do not care what you vehicle looks like!
Bowl Trail - Perfect trail for those with stock to lightly modified vehicles. The trail winds through the desert through some very scenic parts of the Logandale area. There are a few obsitcles for those of you adventurous types but all are optional. At the very end of the run you can really test your driving skills and attempt the S-TURN. Though it is optional we suggest lockers front and rear and there is a possibility for some body damage. Full size not recommended in the S-Turn and are guaranteed body damage.
Bronco Falls - A trail named after the one biggest obsticles in the trail, a huge vertical climb up a rock wall. Though it looks more intimidating then it is difficult a good set of tires and some low gears will get you to the top.
Hawkins Trail - Scenic trail that takes you through the mountains to the valley adjacent to the Logandale Valley. This is the connector trail for many other trails such as Matterhorn, Arockalypse and The Bowl trail. So if your looking for a scenic easier trail take the Hawkins Trail.
Matterhorn - Rated probubly a 2 this trail is good for those slightly modified vehicles. Scenic ride through the Logandale hills to some mild obsticles. Great optional off camber climb just before a large climb that puts you back in the launch postition.
Rock Bottom - This is a great trail for those looking for a challenge. Rated a 3+ this trail will test your rig. The entrance to the trail is a V notch that you tip toe through. From there you crawl some sand stone obsticles along the way until you end up in a canyon with 4 ways out. The easiest is rated a 2 or 3 the hardest put mosts on there roof! As the trail comes to an end you have two ways to exit the trail: the S turn near the end of the trail where your powersteering, gearing and brake control abilities get a major workout or the waterfall which is pretty steep flat rock wall decent. After the trail have some fun at the sand dunes and back to base camp. Trail will take about half the day with a large group so bring snacks and plenty of water.
****ter Trail - This trail will challenge the stock the vehicle but still have excitement for those modified rigs with some optional obsticles. This trail is also close to base camp and is famous for unofficial night runs. Rated about a 2-3 depending on the optional obsticles.
Nevada BackRoaders are leading some scenic trails
Bitter Springs and The Logandale Loop.
Please note:
The Country Fair Grounds have 110 power / water / restrooms
to use this facility we need to add a RV fee.
$20.00 for the event
New Information:
No Fee for tent camping on the grass
No Parking on the grass
There is an area wide enough next to the grass and RV`s
that will be reserved for tent camping
We have new vendors for this year that want to come set up a display of their products.
We had over 15k in prizes to give away last year. We expect a lot more this year.
** ARE YOU READY TO REGISTER? **
Register Online
*MS Internet must be used fill out the form*[/QUOTE]
There was even a FJ Cruiser at last years Hump N Bump & press coverage http://www.4wdandsportutility.com/ad...ide/index.html
Access Army - Joint Chiefs of Staff
Blue Ribbon Coalition - Life Member
BRC Kickiní Access Technology (KAT) Team - Charter Member
Graduate of Del Albright's RLTC course
Just Good Trails - Trail Boss
Tread Lightly - Tread Trainer
Old August 17th, 2008, 06:34 PM
BCR's Avatar
BCR
Brian Richardson
Need a D90 Tdi
Hump N Bump media coverage from years past
2004/24th Four Wheeler http://www.fourwheeler.com/eventcove...ump/index.html
2005/25th? Off-Road Magazine Land Rover Disco feature @ Hump N Bump http://www.off-roadweb.com/features/...ver/index.html
2006/26th JP Magazine http://www.jpmagazine.com/eventcover...ing/index.html
Pics My MudPro @ written by Mo
2006/26th J Rations http://rides.webshots.com/album/556474363PGHNMJ http://store.jrations.com/product_in...2b041c142d68fb
2007/27th 4WD & Sport Utility http://www.4wdandsportutility.com/ad...ide/index.html
Old August 25th, 2008, 03:44 PM
BCR's Avatar
BCR
Brian Richardson
Need a D90 Tdi
We did what turned into our 1st pre-run this past Friday as a night run. We ran the Hawkins, Matterhorn & Bowl trails in everything from a mog to a TLC Icon that I rode shotgun in. A few pics of so so quality, more on Vegas Valley 4 Wheelers: Event Information
Old November 19th, 2008, 02:11 PM
BCR's Avatar
BCR
Brian Richardson
Need a D90 Tdi
Talking
Didn't see and Defenders but had a couple Discos & LR3s, I did have a family in brand LR3 on the Bowl Trail's run that I lead on Saturday - LR3 did amazing with those low profile street tires, did loose some trim pieces, but they were fine with that & had a great time.
THANKS to all the who came out n helped and wheel`d
Special Thanks to Sponsoring Clubs
Vegas Valley 4Wheelers - Total Karnage - NV BackRoaders - Southern NV LandCruisers
Many THANKS & please support our Hump n Bump Sponsors!!!!!
Robert Anderson @ Findlay Toyota - Ted Weins Custom 4x4 - Camping Lab - Disabled Explorers - Del Albright - Northridge4x4 - Gen-Right - Hi-Lift - Jim Marsh Jeep - Treks Offroad - TnT Customs - Olympic4x4 - Tom Woods DriveShafts - Kilby Ent. - ARB - Coleman - Camping World - COP4x4 - Warn - RockStar Energy Drinks ...
U all ROCK!!!
Official site for pics & videos http://www.vv4w.org/humpnbump.asp
Del Albright's pics from Hump N Bump - http://www.delalbright.com/Images/Hump/index.html
Blog from Four Wheeler Magazine http://blogs.fourwheeler.com/6336976...ert/index.html
My pics - Friday The Matterhorn Trail http://good-times.webshots.com/album/568579857eCosgr
Saturday The Bowl Trail http://good-times.webshots.com/album/568579887Ntiath
Pics from Fridays Matterhorn trail run
I was the trail boss for the Bowl Trail on Saturday with 5 additional trail guides & 33+ rigs. Thanks to a great team it went smooth & timely
Keith on the 2nd Obstacle
For Saturday the S Turn backwards :lildevil:
Lance of Disabled Explorers doing a recovery
Old December 11th, 2008, 06:59 PM
BCR's Avatar
BCR
Brian Richardson
Need a D90 Tdi
Talking
Did have a brand new LR3 sporting paper plates on the run I led but no Defenders this year.
FYI: Hump N Bump '08 is scheduled to publish in the April issue of Four Wheeler.
gas
Las Vegas 41gpaws Trips, Trails and Events 6 February 12th, 2010 11:57 PM
Defender on Barrett Jackson Las Vegas Coverage.. LRNAD90 Misc. Chit-Chat 2 October 10th, 2009 03:34 PM
Fiberglass Top For Sale - Las Vegas mikey For Sale - Parts 3 August 9th, 2009 11:12 AM
SOLAROS - SAE 2008 - Nov 7-9 JackW Trips, Trails and Events 10 October 16th, 2008 08:30 PM
Moab Nov 6-12 m.olivares Trips, Trails and Events 3 October 31st, 2005 10:51 AM
