Your old NAS 90 front calipers - Defender Source
Old May 18th, 2016, 11:44 AM
Looking for a pair in need of a rebuild. Thanks!
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 18th, 2016, 11:51 AM
I've got two sets. Coming up to NYC anytime soon? You can have them.
Old May 18th, 2016, 11:56 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Free is very much Dave's style...
RDavisinVA
Old May 18th, 2016, 12:34 PM
Jimmy, I'll try to figure something out. I think Dan owes me a favor.
Present:
1987 RRC- "Chewy 2"
Past:
Old May 18th, 2016, 12:54 PM
Want some rears too?
Old May 18th, 2016, 08:09 PM
Thanks Jimmy I'm staying with drums on the rear. I'm down for a set of fronts though, thanks!
Present:
1987 RRC- "Chewy 2"
Past:
Old May 18th, 2016, 09:31 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
I would love a set of calipers. I want to upgrade the new truck to vented discs in front and drums in rear.
Old May 18th, 2016, 10:49 PM
Dave, let me take a look, but I am pretty sure I have a rebuilt set ready to bolt in. I think I had a chatter/vibe or something and thought it might be the calipers and replaced them, but pretty sure they didn't end up being the problem. Either way they are yours. Can bring to HH.
Originally Posted by pendy
I'm here for the D's
Old May 20th, 2016, 11:29 AM
Calipers acquired. Thanks Charles.
Present:
1987 RRC- "Chewy 2"
Past:
Old May 20th, 2016, 08:51 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
dave are the different than disco 1 calipers????
good luck with your search
Old May 20th, 2016, 09:14 PM
Yes, A D1 utilises a solid brake rotor where the Defender has a vented rotor. It is common to install D90 brakes on a D1.
Old May 21st, 2016, 06:28 AM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
Same calipers for disc brake conversion? Front disco's will fit on rear sals axles?
Old May 21st, 2016, 09:42 AM
To expound on Jimmy's reply, yes they are a totally different caliper with bigger pistons.
A 110 with solid rotors will have the same caliper casting as a NAS 90 except without the spacer required by the vented disc.
Disco and RRC calipers are the same casting but the RRC one has the spacer for vented disc and the extra line ports to allow for the two circuits to coexist in the caliper.
I think there is a 3rd type also which is early RRC 87 and 88 which use a double line caliper without the spacer. Again same casting as D1.
I'll try to find pics.
Here's a thread with some useful but shitty pics
http://landroverforums.com/forum/dis...s-76115/page3/
Present:
1987 RRC- "Chewy 2"
Past:
Old May 21st, 2016, 10:45 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
All of the rears are the same, but are smaller (2 piston) than the fronts (4 piston).
NAS D90s have the largest piston fronts, and are single line. Discos and RRC fronts have the the same size pistons, but RRCs are for vented rotors and have dual line plumbing.
-Jeff
I haven't compared a set side by side, but there's also the 110 rear calipers (STC1268/9) that are compatible on the 90's. I don't know if the piston diameter is larger, but the pads do have more surface area.
-Ash
Geared Restoration Co.
352-572-3236
Old May 21st, 2016, 11:22 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Is this spacer available separately? I have a serviceable set of 110 solid rotor calipers that I pulled off my old axle.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old May 21st, 2016, 11:34 AM
-Ash
It is, that's what I have on my truck. The pads and rotors are bigger as well. Definitely a worthwhile upgrade since the price is about the same as D90 rear brakes AFAIK.
Old May 21st, 2016, 02:52 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Why wouldn't you just run the 110 calipers? The vented rotors is more bling factor than anything else, at least on these vehicles.
Old May 21st, 2016, 11:22 PM
What difference does it make?
Present:
1987 RRC- "Chewy 2"
Past:
FS D110 front brake calipers ECR For Sale - Parts 1 April 13th, 2008 08:10 PM
110 front brake pads old/new calipers? Rod Hayward Defender Technical Discussions 2 November 30th, 2007 03:25 PM
Front calipers CDN38 Defender Technical Discussions 0 August 11th, 2006 05:52 PM
front calipers TDI Guy Wanted 0 May 19th, 2006 03:40 PM
Front Brake Calipers 1of40 Defender Technical Discussions 7 December 30th, 2003 12:46 PM
