Y Pipe Flange - Defender Source
Old November 28th, 2007, 11:56 AM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Y Pipe Flange
I need two "Y" Pipe flanges, the part that bolts to the bottom of the stock manifold. Even if they are cut off of an old Y pipe I can still make them work.
Old November 28th, 2007, 12:14 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Check with wwwDOTroverdudeATsbcglobalDOTnet in Fullerton.
Old November 28th, 2007, 12:38 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Thanks Chris, sent an e-mail.
Old November 28th, 2007, 07:36 PM
Paul Grant
Paul Grant
I've got them if you are having trouble locating a pair. If I can be of help contact me at:
paulgrant@mac.com
Paul Grant
203-770-1699
Old November 29th, 2007, 01:19 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Yeah if Paul can't help you I will cut a couple off and send them to you. PM me an address if you need em'
JP
legend in my own mind
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Custom exhust setup? Pipe size to use?? Defender50th Defender Technical Discussions 8 November 22nd, 2005 12:21 PM
4.0 heater pipe Mike Hippert Defender Technical Discussions 8 May 29th, 2005 07:37 PM
Tail pipe replacement d90Monkey Defender Technical Discussions 9 March 24th, 2005 12:10 PM
