WTD: Shift Linkage LT230 Defender Style R380 - Defender Source
Old September 2nd, 2014, 08:17 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
WTD: Shift Linkage LT230 Defender Style (R380), see attached pictures...
Will consider complete assemblies, but mainly need the perpendicular rod from top to bottom that connects to the shifter at the top and the diff lock mechanism at the bottom.
This is different from the LT77 (at least early ones).
Note the Round shift rod coming out of the shifter assembly unlike the RR & Disco rod that is slotted (see next post).
ID:	101953   Click image for larger version
ID:	101955   Click image for larger version
RDavisinVA
Old September 2nd, 2014, 08:23 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I went through the exercise of trying to modify a RR Disco rod (ZF automatic)which I couldn't get to work properly.
The attached photos show why the RR Disco ZF style LT230 shift assembly won't work with a defender style R380.
ID:	101958   Click image for larger version
ID:	101960   Click image for larger version
RDavisinVA
Old September 2nd, 2014, 08:29 AM
the rover shop
shayne young
Last time I needed one it was still available form the dealer and not terribly expensive..and the little top hat bushings too..
------ Follow up post added September 2nd, 2014 08:30 AM ------
From memory the manual trans one is flat steel and has a bend in it to fit correctly..
Old September 2nd, 2014, 08:40 AM
Another one of those "why did they change that" moments.....
Old September 2nd, 2014, 12:34 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Have gotten a few PMs from people analyzing the pictures and here are aa few FYIs.
In post 1, am told that the shifter is from a LT77 setup because the shaft that slides side to side is round and not notched on the end.
Am told that the top shifter on the R380 and ZF automatics will interchange and may be the same between Defender style vehicles and Disco/R380 models.
If this is the case, it's possible to swap over everything from a ZF setup less the perpendicular rod (FTC4095) which as Shayne suggests is still available.
End result: order a FTC4095 and use everything else from a ZF setup.
Thanks for the input everyone.
RDavisinVA
defender, lt230, r380
LT230 shift linkage eye bolt michael67 Wanted 0 December 17th, 2011 07:59 PM
Adjusting R380 linkage--hard to shift to 3rd Davis Defender Technical Discussions 6 April 22nd, 2010 12:14 PM
LT230 Linkage rebuild kit? bharris Defender Technical Discussions 6 March 29th, 2010 06:59 PM
D90 LT230 t-case linkage evilfij Wanted 8 April 26th, 2009 10:49 AM
LT230 locking linkage needed pcarey Wanted 2 July 23rd, 2007 01:11 PM
