WTB: wing-top vent air scoop - Defender Source
Old September 25th, 2015, 11:54 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Looking for a used air scoop for my right hand wing. My air intake is now under the wing, this will help bring in cold air. I figured I would ask here in case someone has one sitting on a shelf. Thanks!
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old September 25th, 2015, 11:57 AM
ontheway's Avatar
ontheway
Dave
Old September 25th, 2015, 01:31 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
I have a couple to choose from in Portland. I'll be there on the 5th if you're not in a rush.
Old September 25th, 2015, 01:36 PM
kgottehrer
Kevin Gottehrer
1997 D-90 SW
I've got one. I can take some pictures and send them to you if you would like. Where in NC are you located?
Old September 25th, 2015, 04:20 PM
D90Overkill
David Frank
1995 ST #2615
Right on, Kevin. You are Johnny on the spot! And pretty local. That should work out nicely!
Old October 7th, 2015, 06:33 PM
CDeWan
Clay DeWan
5.3L beastie
what a stupid idea!!!
Attachment 130589
Cold air intake how dumb- check out what this idiot did http://www.defendersource.com/forum/...-of-19933.html
anyway, with this set up you do want to consider the impact of rain being in NC and if you will be sucking up a bunch of water into the intake.
You can go with the scoop type or if you go on ebay UK you can get a "snow cap" version for a right hand drive that hangs over the fender a little bit if we get back into the rainy season.
Good luck. I also built a box around mine using aluminum before trashing the whole set up and going with a GEN III GM.
I still have the cone and 90 degree set up if anyone is interested in putting it on their defender.
Wing Vent scoop tomaco1 Wanted 24 November 3rd, 2013 12:22 PM
defender wing top air scoop unimogfever Smaller Projects 4 January 27th, 2012 12:52 AM
Low Profile Wing Top Scoop fleabus Defender Technical Discussions 1 October 14th, 2006 11:38 AM
Wing Top Heater Intake Scoop newfD90 Defender Technical Discussions 2 April 13th, 2006 12:54 PM
Wing top Air Intake or Scoop??? adibitar Defender Technical Discussions 7 July 8th, 2004 08:57 AM
» Defender Registry
Murphy
NealK
Hilda
badvibes
Add your Defender
