Wtb: speedometer w/digital odometer - Defender Source
Old June 16th, 2014, 08:42 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I am looking for a newer style (adjustable) speedometer for my '85 ninety. The stock unit is way off now I am running 265/75/16 Bfg's and I would like to install an adjustable unit which can then be calibrated so it's spot on.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old June 16th, 2014, 08:44 PM
you want an aftermarket vdo speedo.
Mark Kellgren
KM4BOR
Old June 16th, 2014, 08:46 PM
spartan's Avatar
spartan
Fred
83 D110
speedometer
will this work? its off a 2001 defender
Old June 16th, 2014, 09:04 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Where can I find one?
Probably not. Needs to be in MPH. Sorry, forgot to mention that.
Old June 16th, 2014, 10:13 PM
You could always try google to find things ... But here is what you need.
http://www.egauges.com/ProductDetail...ctCode=437-155
Old June 16th, 2014, 10:42 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Cool, thanks.
speedo
Speedometer / Odometer Not working TheBeast Defender Technical Discussions 4 June 13th, 2009 09:08 AM
Needed- 1997 D90 Speedometer/odometer JMPDIV82 Wanted 9 October 30th, 2007 02:49 PM
digital odometer reset Overlander Defender Technical Discussions 5 May 15th, 2007 10:03 AM
Odometer -- Digital vs Analog smenzel Defender Technical Discussions 8 August 13th, 2004 11:29 PM
Digital cameras - What do you use? chrisvonc Misc. Chit-Chat 16 July 5th, 2004 10:51 PM
