WTB: Speedometer Cable and Road Speed Sensor - Defender Source
Old December 6th, 2015, 09:35 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
For my 85 110 with 3.9 V8(14CUX). Has 1.4 LT230 and R380 from a NAS90, in case that matters for the speedo cable. Let me know what you got.
TIA,
Kent
1985 Land Rover 110 3-door ST
Old December 6th, 2015, 09:37 PM
Upper or lower cable?
Old December 6th, 2015, 09:40 PM
Oh you say VSS as well so you need both cables. I think EFI Defender cables are hard to find as they were only used on NAS trucks.
If it were me I'd get a VDO speedo and you can run it and the EFI signal from a Disco 1 VSS.
Old December 6th, 2015, 09:50 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I'll be running a GPS speedo, so all I need is the speed sensor and cable necessary to enable the ECU to get proper reading for fueling the engine....
I guess the D1 VSS and lower cable will suffice?
Old December 6th, 2015, 10:00 PM
You could it needs a resistor added.
Why waste money on a GPS sender for a speedo when the VSS will run it for free
Old December 6th, 2015, 10:06 PM
The disco VSS does not use a cable. It connects directly to the transfer case.
Old December 6th, 2015, 10:10 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Its not a sender to run the speedo. The speedo itself is a GPS unit.
So, I guess if anyone has a Disco VSS, Im interested.
Thanks for the info John.
Kent
Old December 6th, 2015, 10:22 PM
Okay. GPS speedos are not really as good as ones driven by the vehicle.
You really want to buy new. They are not that expensive for the VSS.
Old December 6th, 2015, 10:28 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
New ones Ive found online are around $270. That is expensive to me.... Am I looking at the wrong sensor?
Land Rover Speed Transducer - Genuine Part YBE100540
Old December 6th, 2015, 10:49 PM
Originally Posted by 85Red110 View Post
New ones Ive found online are around $270. That is expensive to me.... Am I looking at the wrong sensor? Land Rover Speed Transducer - Genuine Part YBE100540
Sure if you buy genuine everything is expensive. The aftermarket ones work fine.
http://www.roversnorth.com/ProductDe...=PLI616&type=0
http://www.paddockspares.com/ybe1005...cer-speed.html
Old December 7th, 2015, 08:18 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Wouldn't you want the transducer from a Classic or Defender since you're running a 14cux?
TRANSDUCER VEHICLE SPEED RANGE ROVER CLASSIC , RNC860, AMR3386 - Rovers North - Classic Land Rover Parts
Old December 7th, 2015, 08:45 AM
the actual drive gears come in different colors and you should choose one based on the size rubber you intend to run.
How to replace the speedo drive gear on a Land Rover - The Land Rover Blog
Old December 7th, 2015, 08:59 AM
Either work.
The only complexity is that you need to add a resistor to the disco VSS. AMR3386 has the resistor inside the box. It is all explained in one of the VDO speedo threads.
Old December 7th, 2015, 09:00 AM
He is not running an actual speedometer, so it does not matter. The VSS is just telling the ECU if you are stopped or moving to switch idle modes.
Old December 7th, 2015, 06:20 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Yes, I just need the engine to run smoothly, and apparently the VSS is required to do that. This is frustrating. If its not one thing, its another. Once I figure out the VSS situation, I'm sure there will be something else I will need to do to get one step closer to making this truck run, so stay tuned. Thanks for help guys. This forum is invaluable.
Old December 7th, 2015, 07:00 PM
I can probably rip one from a parts truck next time I go to Rob's shop.
Old December 7th, 2015, 07:08 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
That would be awesome. Thanks Bill!
Old December 7th, 2015, 07:11 PM
Really, you can just go to any mall with an allen key and get one off the first Disco you see. They will never notice the difference.
sensor, speedo
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
Road Speed Sensor Cred Defender Technical Discussions 2 February 16th, 2010 09:37 PM
Speedometer cable... standard threads down below? Hans Defender Technical Discussions 0 January 13th, 2007 09:33 PM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
