WTB: Series II/IIA 88 tub - pastel green - Defender Source
Old January 14th, 2013, 11:54 PM
Had a mishap with my Series this summer, resulted in a bent frame/crossmember and the tub got bashed pretty good.
Using this as an excuse to do a galvy chassis swap and figured the easiest way to deal with the tub situation would be to slap a new one on during the swap.
Must be pastel green, and preferably in darn good shape.
What'cha got out there?
Old January 22nd, 2013, 12:52 AM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
I have my old one, but unfortunately too far from you.
Old January 22nd, 2013, 06:11 AM
Lav I forgot to talk to you about this at HH. I found a guy in Lancaster who has a carcass. Dunno how good the tub is but it looked usable in the pics.
Old February 6th, 2013, 09:13 AM
87 D110 (Ruby)
Lav - did you check over at GnR...they have one in NY for you.
Old February 6th, 2013, 10:42 AM
Yes, saw those...sort of being picky. One was pretty beat up, the other had these crazy rivets down each side (not sure why). Really need to find one that's well sorted, otherwise I've got a bead on one in limestone that is in great shape but would require a color change (which I was trying to avoid). But may just have to go that route.
Old February 6th, 2013, 02:30 PM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
Pics sent to your email inbox.
Old February 6th, 2013, 11:54 PM
giftshopduane
Chris luciano
72 Series 3 88"
Crazy rivets turns out are on a SIII tub NADA spec, they are for supports for rear seat belts, I did not know this.
Old August 3rd, 2013, 11:05 PM
Bump...keep in mind I'm really being particular about the condition (but less particular about the color).
Old December 27th, 2013, 06:21 PM
It looks like I can finally close the loop in this...may have to do a color change if I can't get the dark green paint off, but the tub is in decent shape and will serve the purpose well.
It is, however, worth noting that I am in need of some 88 axle assemblies (entire setup front & rear)...so if anyone in the NY area has a set they want to part with let me know!
Old December 27th, 2013, 06:39 PM
What's different between the 88" and 109" axles?
Originally Posted by pendy
I'm here for the D's
Old December 27th, 2013, 06:44 PM
Apparently (and I should have clarified, it's just the rear axle), the mounting points for the springs are different since they're outboard of the chassis on the rear (whereas on an 88 they are lined up directly with the chassis). Fronts, I've been told, are actually the same...so it's just the rears.
See below...I put an arrow to indicate where it bumps out.
Old December 28th, 2013, 11:48 AM
Yeah it's not like the truck is running right now. I'd borrow Jeff's wheel dollys and pull the axles and suspension and transfer over to the new frame if you want to build up the chassis in advance.
series
Trailer Project (Coil sprung series tub) 1962siia88 Smaller Projects 9 July 1st, 2011 07:17 PM
Series tub vs 110 tub MUDSUX Defender Technical Discussions 7 March 4th, 2010 10:50 AM
1974 III Series 88 SW Prototype For Sale Nil For Sale - Vehicles 0 August 10th, 2005 02:39 PM
Series 88 roof top and sides kellymoe For Sale - Parts 0 January 27th, 2004 01:12 AM
