WTB: RRC Swivel Ball & Knuckle Assembly - Defender Source
Old July 17th, 2015, 06:17 AM
UserName's Avatar
UserName
Andy
Janey
Looking for a Range Rover Classic Right Hand Swivel Ball / Pin / Knuckle assembly. 7 bolt, 10 spline, non-ABS. Perhaps you upgraded to 24 spline and still have the old parts kicking around? Please e-mail or PM me. Thanks for looking!
Old July 17th, 2015, 06:35 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
One from an 89 RRC will work, correct?
John C.
Old July 17th, 2015, 08:56 AM
UserName's Avatar
UserName
Andy
Janey
Yes - I believe it will. I think 1987 thru mid 1993 were 10 spline, 7 bolt. I will send you a p.m.. Thanks
Old July 17th, 2015, 09:03 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I never really looked at them. What's the difference between a 10-spline vs 24-spline swivel assembly?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 17th, 2015, 10:14 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I have one still on the axle from a 92, but it's abs.
Email is
Same place, new dogs.
Old July 17th, 2015, 10:15 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I've converted 2 RRCs from 10 to 24 spline and never touched the swivel assembly...
Rent my
Old July 17th, 2015, 10:16 AM
I have a complete 89 front axle assembly,10 spline no abs
Old July 17th, 2015, 11:08 AM
UserName's Avatar
UserName
Andy
Janey
Isn't the diameter of a 24 spline different? In any event I need this for a RHD to LHD conversion on a Defender. The addition of the RRC knuckle on the right side is what I am after. Finding one to fit 10 spline, 7 bolt pattern will save me from replacing the whole axle (I think). I think the ABS version is different enough that it will not work but I could be wrong.
Old July 17th, 2015, 11:14 AM
See Dave Stauffer's part out ad in parts for sale. He's got everything you need to go lhd for short money
Old July 17th, 2015, 07:17 PM
Antichrist's Avatar
Antichrist
Tom Rowe
The axles are different diameter but as far as I know the swivel assemblies are the same as long as you're comparing non-ABS to non-ABS. But I don't know for 100%, that's why I was asking. The swivel balls are the same PN though.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
assembly
RRC ABS swivel ball, stub axel and CV... Gabriel_Laconi Wanted 1 June 13th, 2015 06:40 PM
WTB: Alpine bar and swivel ball sro Wanted 10 March 13th, 2013 02:33 PM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
Swivel Ball Leak... norros Defender Technical Discussions 19 May 5th, 2004 03:50 PM
