WTB: RRC Shifter - Defender Source
Old December 7th, 2014, 10:37 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
WTB: RRC Shifter
All:
ISO a Range Rover Classic shifter in very good condition. Prefer plastic or leather bound.
Thanks in advance,
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old December 7th, 2014, 11:07 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Sweet! I'm not sure how to get the old one off?
Old December 7th, 2014, 11:46 PM
Mtanzania
Frank
1994 D1 300tdi - Sold :-(
I've also got a plastic one from a 92 rrc....they just pry up from the back and kind of hinge up if I remember correctly
94 D1 300tdi - Sold
93 LWB-Isuzu diesel 5 speed
Old December 8th, 2014, 08:44 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Can you guys post pics?
Old December 8th, 2014, 09:15 AM
Mtanzania
Frank
Here's mine
This is the one I have
94 D1 300tdi - Sold
Old December 8th, 2014, 10:01 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Looks right. How much do you want for it?
Old December 8th, 2014, 10:09 AM
Mtanzania
Frank
You want just the top portion or the whole shifter? Just pm me an offer including shipping
94 D1 300tdi - Sold
Old December 8th, 2014, 10:33 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
If the top is wooden, how do I remove it? Same pry from rear removal?
Old December 8th, 2014, 10:45 AM
Engage brake. Set shift lever in Neutral position. Carefully pry between the handle and the cover, It is metal plate covered with glued-on wood veneer and it is easy to damage the wood. That will reveal a e-clip that holds the release button onto the release shaft. Undo the e-clip and pull the button up and out. There is a nut that holds the handle on the shift lever. Use needle nose pliers to undo the nut. The handle will pull off.
You can also pry up on the rear corners of the wood insert that holds the shift lever indicator and slide it up and off the shift lever. This will let you clean all the spilled coke and coffee out of the console and check the light bulbs.
Old December 8th, 2014, 11:04 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks Bill!
Old December 8th, 2014, 12:22 PM
Mtanzania
Frank
What he said
94 D1 300tdi - Sold
WTB Defender LT77 shifter and linkage ocrover Wanted 0 August 8th, 2013 11:51 PM
WTB: R380 transmission for a 300TDI with bellhousing and shifter Mike Sandone Wanted 1 September 13th, 2011 06:51 PM
WTB: R380 Shifter Gaiter Wolf Fabrication Wanted 0 December 12th, 2010 03:38 PM
Borg Warner Transfer Case Shifter Linkage (RRC) cellulararrest Wanted 2 August 22nd, 2007 01:20 PM
97 T-case shifter ronward Defender Technical Discussions 1 November 25th, 2003 04:12 PM
