WTB RRC Lwb Eas Ecu - Defender Source
Old January 23rd, 2018, 10:36 AM
V8County's Avatar
V8County
V8County
One Ten v8 Station wagon of 1983
WTB RRC Lwb Eas Ecu
Hi,
may be more chance to this side of the world.
It seems my eas ecu is dead.
So I looking for one.
Old January 23rd, 2018, 10:46 AM
What makes you think it's dead?
Old January 23rd, 2018, 11:04 AM
V8County's Avatar
V8County
V8County
I checked fuses and relays, all seems ok.
The indicator lights illuminate continuously whenever the starter switch is in position "II"
And sometime the eas reworks without I know why.
Old January 23rd, 2018, 03:01 PM
I think your ECU is fine. You have some fault code that is keeping the system from operating.
You have a few choices. You can temporarily bypass the ECU by simply unplugging it. That will hold the system at the current inflation. You can safely drive it as long as it has not gone to the bumpstops.
Inflate it manually: You can make a small pigtail with 4 wires. strip both ends about 10mm. gang all 4 on one end. The remaining wires go into the (unplugged) AMP plug in the following manner...
Connect sockets 1,8, to start the pump. It will shut off when full. Connect pin 1 and 26 to inflate. Connect 1 and 9 to deflate. The air bladders are as follows: LF 10, LR 11, RF 27, RR 28. So to add air to the RF for example, you connect pins 1,26, and 27. To let air out of the RF you would connect pins 1,9, and 27.
I know it sounds confusing but after you do it successfully, it all becomes simple and clear.
Finally, you'll want to visit Storey Wilson's site where he offers instructions to make a com cable which will allow you to read and clear codes, set min and max height, and otherwise live harmoniously with your EAS system.
One note...the cable end he refers to (the 5 pin Rover end) is unavailable. If you are super lucky maybe you can scrounge one somehow, but it may be best to simply hack off the plug and replace it with something else that is easier to source. Autosparks.co.uk has some other choices for you that are similar.
Old January 23rd, 2018, 04:31 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Great info. I'm going to apply some of that today. Thank you, sir!
You are the Sage of Classics and Series, Mr. Adams!
"Barry is correct!"
Old January 25th, 2018, 12:39 PM
V8County's Avatar
V8County
V8County
Thank you so much Bill,
very helpfull informations.
I just found a compagny in UK who can make the cable. If some member are interested, send me PM.
ecu, lwb
1995 RRC LS3 plus restore Brewie212 Truck Build-up's & Restores 45 February 14th, 2018 10:16 PM
Feeler 1995 RRC lwb (all California) D90Overkill For Sale - Vehicles 24 December 29th, 2017 01:57 PM
WTB : 90s RRC LWB Talleyrand Wanted 4 April 2nd, 2017 05:49 PM
WTB: OEM rubber floor mat set for RRC LWB signalMTB Wanted 0 February 27th, 2017 10:50 AM
WTB: RRC LWB sliders (used or new/fabricated) REDrum Wanted 3 April 9th, 2013 06:24 AM
