WTB Nas D90 fuel gauge - Defender Source
Old December 3rd, 2013, 11:01 PM
cwerlin's Avatar
cwerlin
Craig Werlin
1994 D90 #877 ST AA Yellow
The gauge on my 94 NAS has decided that the tank is always full :-) so I am looking for one that will give me an accurate reading. Does anyone have a gauge they are willing to part with?
Old December 3rd, 2013, 11:11 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Are you sure it's not the part in the tank sending a wrong signal?
Old December 4th, 2013, 05:31 AM
rovertrader's Avatar
rovertrader
Dale
I have a gauge if interested, but agree it is likely the sending unit...
Old December 4th, 2013, 06:38 AM
fwiw a vdo is a direct replacement
Old December 4th, 2013, 07:59 AM
There is a thread here on repairing the fuel pump. Fuel pump and sensor are all in one big expensive unit. You need to drop the tank to get to it and more than likely it will be a corroded mess. Start looking for a replacement.
Old December 4th, 2013, 08:04 AM
cwerlin's Avatar
cwerlin
Craig Werlin
Thanks guys, the fuel pump and send are less than a year old with only 5k on them. I was jacking around with the gauge cluster removing the green plastic bubbles and dropping LEDs in and I am guessing I broke something in the gauge. Light is great now but...
------ Follow up post added December 4th, 2013 07:05 AM ------
Rover trader, what do you want for the gauge?
Old December 4th, 2013, 12:39 PM
Originally Posted by cwerlin View Post
Thanks guys, the fuel pump and send are less than a year old with only 5k on them. I was jacking around with the gauge cluster removing the green plastic bubbles and dropping LEDs in and I am guessing I broke something in the gauge. Light is great now but... ------ Follow up post added December 4th, 2013 07:05 AM ------ Rover trader, what do you want for the gauge?
You probably have a lose connection or it connected incorrectly. It should have 3 wires . A black ground and 2 others.
It's unlikely you broke the gauge.
Old December 5th, 2013, 05:52 PM
cwerlin's Avatar
cwerlin
Craig Werlin
Thanks Jason, any idea how to test the gauge and or the wiring? I have unplugged and re plugged a couple times
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
WTB Seat for a NAS D90 ( Driver ) Rugbier Wanted 2 February 18th, 2009 10:02 PM
WTB 97 NAS D90 AC system ECR Wanted 7 July 16th, 2008 07:58 AM
WTB: Owners and Workshop manuals for 97 NAS D90 wea Wanted 2 August 30th, 2004 11:23 AM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
» Defender Registry
Winston
JrJetJock
Sold
Add your Defender
