WTB: LT230 Input Gear - Defender Source
Old November 21st, 2017, 03:06 PM
DiscoDavis
C Davis
1990 110, 1995 Disco
Have a 98 LT230 1.2 from a disco that needs to go in. Only problem is somehow it has an earlier style input gear that is not crossdrilled, and is not fitting great on the car. Needs to go in soon.
Does anyone have an LT230 Input gear that is the later crossdrilled style they are willing to part with? Located in northern CA.
C
EDIT: found one. Whoops only minutes after this post.
Old November 21st, 2017, 03:11 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Is there not the mod plate fitted? on non-drilled units a drip plate was fitted. I do not have a picture but Ashcroft may on the web. I am going to say fitted to some?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old November 21st, 2017, 03:18 PM
Naplm00
Matthew
Oil sling plate under the pto is optional and isn't fitted to all tcases.
Old November 21st, 2017, 03:20 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Ashcroft Transmissions
Old November 21st, 2017, 03:47 PM
No way a 98 would not have a cross drilled gear. I would be a little worried about the box. i would just buy a new gear. They are not expensive.
Old November 21st, 2017, 04:51 PM
DiscoDavis
C Davis
Yeah a minute after I posted I got a call from the shop doing the trans, tcase swap and he is getting a gear from ashcroft to be picked up by a local friend on vacation.
Red, that's what we were thinking. My guess is rebuilt box? Getting the correct later gear.
------ Follow up post added November 21st, 2017 01:56 PM ------
John Roverman,
no plate fitted like that. I have a 1.4 that is original to a 1990 car and a 1.2 for this one, a disco., my guess is no crossdrilled gear, and this new one that should have had it but did not. Only add on piece I have seen is an external pipe that someone ran an oil pump to the input shaft to get around swapping the gear.
lt230
Tips on Swapping out the T-Case input Gear? LRNAD90 Defender Technical Discussions 2 April 23rd, 2009 05:14 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
howling trans or Transfer case? Gkase Defender Technical Discussions 18 February 8th, 2008 11:08 AM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
