WTB LT230 defender frame mounts - Defender Source
Old May 24th, 2013, 10:34 AM
I'm looking for the two mounts that mount an LT230 R380/LT77 combo to the frame in a defender
See the picture for a rough idea (this shows a different tranny). ZF ones have the wrong angle on the DS.
tia
charles
Originally Posted by pendy
I'm here for the D's
Old May 24th, 2013, 11:03 AM
Do you want the rubber discs or the steel mount parts? Maybe a look at the part diagrams would help clarify.
Old May 24th, 2013, 11:11 AM
Pics
Old May 24th, 2013, 11:56 AM
pendy's Avatar
pendy
jim pendleton
89'd90
those are LT 77 style mounts that you pictured Charles.
I have a few extras of these. I can supply parts 1 and 2 from the parts diagram Red90 supplied. But I am running low on part 12 if you can source it elswhere.
legend in my own mind
Old May 24th, 2013, 02:06 PM
Thanks for the diagrams John. I need the the whole assembly but will be buying new rubber eventually and will galvy the rest so not worried about condition.
FWIW the LT230 mount is just the one on the right. The one on the left is the tranny mount, for what ever tranny (piece) you are using.
-Jeff
Understood. I need both the RHS LT230 assembly as well as the LHS assembly that will fit an R380 tail piece. I have no idea if this is different from the LT77. I'll look fo ra diagram for an R380 and see if it's the same part numbers
Yeah I need all 3, although I could make 12 easily enough. Let me verify if there are any differences between LT77/R380 and I'll send you an email. Got the LT230 RHS as well?
Old May 24th, 2013, 02:25 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Yes I have the LT230 RHS as well. You will need a 12 for both sides. 12 is an easy fab. Only need to notch one side and a center hole with 4 bolt holes. I can scribe one on some cardboard if that helps.
Old May 24th, 2013, 02:32 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I have them both galvied already
Old May 24th, 2013, 03:05 PM
Tom, I'm doing another galvy run anyway so it's a waste to get fancy (unless you want to sell them cheap )
Haven't found the LT230 RHS one yet, but these show that the LHS/Driver side ones are the same regardless if LT77 or R380.
Name:	r380 mounts.jpg
ID:	73044 Click image for larger version
Name:	lt77 mounts.jpg
So I know I need NTC1201.
I also need NRC8204 but i can fab that no problem (really just need to know the thickness).
Now I am not sure if the RHS mounts shown here are for the LT230 or not. The parts manual I got these from doesn't show a mount in the LT230 section so maybe they are. But I need that assembly as well (NRC6528 and 90575585).
Jim I'll send you an email.
Old May 24th, 2013, 03:46 PM
RH are for LT230. I might have a set, but I am not sure. I need to get the roller back together which I sort of hope to do this weekend.
When are you doing the galvy run? Maybe I can meet you there and we can save via a bigger batch.
Old May 24th, 2013, 04:07 PM
Don't use the NAS shiz unless you are using a NAS tunnel, floors, and seatbox. They will put the transfer box right where the front of the seatbox wants to be.
Use the stuff that Pendy has and it will put the transfer box further back. Or, maybe you don't care.
Attachment 73044 Attachment 73045
Old May 24th, 2013, 04:14 PM
Dave, I'm using a 109 body on a 110 frame and not far enough along to know which is better for this. Given this, what do you think? I just assumed I was better off keeping the LT230 in the stock location so that I could use stock mounts, frame holes and stick driveshafts. But I am free to put it anywhere I choose if necessary.
The motor is fairly large and will be where the transmission usually is, so I may have to make tunnel mods, but not too worried about that right now.
Ron not sure when but will let you know. I am well over the minimum already so no savings there, but it would save you if you don't have much.
Old May 24th, 2013, 09:47 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
http://www.defendersource.com/forum/...7&d=1369408247
These are the 2 I have.
#1 and #2
Old May 25th, 2013, 06:41 PM
I got Pendy's. Will let you know how it goes. Thanks everyone.
defender, lt230
1997 Defender 90 NAS Station Wagon, Coniston Green, Galvanized Frame 74k miles Boone90 For Sale - Vehicles 24 September 15th, 2012 10:59 PM
WTB: Defender SVX Wheels (VPLDW0001YCM) silby32 Wanted 30 April 3rd, 2012 04:37 PM
WTB / TRADE a 06 HD FATBOY & 00 Disco for Defender Rugbier Wanted 5 August 12th, 2008 07:18 PM
FS NAS Defender 90 frame ECR For Sale - Parts 4 April 8th, 2008 12:36 PM
WTB: Defender front seats pmd Wanted 7 April 5th, 2008 09:19 PM
