WTB local: 1 or 2 KM1 33inch tires - Defender Source
Old April 20th, 2010, 09:14 PM
Will be upgrading to KM2s in the next year, but need to drive a bunch this weekend (heading up to Boston) and I have some crazy wear and a bit of a wobble on my front two tires. It looks like the culprit is the passenger side tire, so I want to get newer rubber up front, get them balanced, and see if there's a bigger issue.
I have a brand new KM1 spare which I could use, so if someone has a newer KM1 just taking up space, I could use it. If you have two...even better. Can pick up on my way up to Boston.
HELP!
pics of them on the truck:
http://www.defendersource.com/forum/...&postcount=237
ID:	26838   Click image for larger version
ID:	26840   Click image for larger version
ID:	26842   Click image for larger version
Old April 20th, 2010, 09:21 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I would suggest all 4 tires at once.. It you have tires of different diameter due to excessive wear it is not good for the t-case that will have to compensate for the different in diameter...
I would jus thold off and get a new set as soon as you can afford them or find a compete used set..
Legend in My Own Mind.
Old April 20th, 2010, 09:26 PM
Good advice Randy, thanks. My rears are probably 60%, and fronts are probably 5%...I just figured if someone has two close to 60-70% that should buy me another year or so.
Old April 20th, 2010, 09:38 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
If you could find something close, that would be good but Try not to have that big of a difference in the tires.. 5 and 60 is a big difference..
Old April 20th, 2010, 11:31 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I looked at it this weekend and rears are like 80% they are in real good shape. Fronts are like -10$ I think I could see the air inside. Seriously there was one spot on the passanger side that was smooth flat for about 6 inches.
Check some Jeep forums or CL around the area. Get 1 or 2 for the front and get them mounted and balanced Thursday morning. You will be happy you did.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 21st, 2010, 12:38 PM
bjf's Avatar
bjf
barry f
94 ST #395
Horsey
Break out a credit card and buy four tires. Every one of these trucks no matter how perfect will cost you when you get it. Tires are an easy fix and it would be really dumb if you were penny wise and pound foolish. Get rid of the shit tires all around and get four new ones before you need tires and a transfer case.
Old April 21st, 2010, 12:47 PM
ini88's Avatar
ini88
Daniel Marcello
And your steering wobble and vibrations will be cured too! new MT rubber is nice and soft
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 21st, 2010, 12:56 PM
Thanks Barry. I have three nearly new (with one of those brand new) KM1s, so I just thought that two others in similar condition for cheaper than buying a whole new set of tires wouldn't really hurt anything mechanically.
Old April 21st, 2010, 01:00 PM
bjf's Avatar
bjf
barry f
94 ST #395
i say ditch them and your wrangler 15 inch wheels while you are at it.
Old April 21st, 2010, 01:08 PM
nah, I like the steelies so far.
Old April 21st, 2010, 01:21 PM
bjf's Avatar
bjf
barry f
94 ST #395
hardly call those steelies, actually that is insulting to genuine steel wheels. Just go buy tires. Buy 5.
Old April 21st, 2010, 01:22 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
When you purchased your 90 did it come with the freestyle wheels?
------ Follow up post added April 21st, 2010 01:24 PM ------
x2. replace it with BR130 wheels and Good Year MTRs
i say ditch them
Old April 21st, 2010, 01:38 PM
What are BR130 wheels?
bjf's Avatar
bjf
barry f
94 ST #395
I have the 130 wheels and love them. Contemplating the MTRs for next tires. I will try to buy five used from different people
------ Follow up post added April 21st, 2010 10:41 AM ------
wheels on a 110
Old April 22nd, 2010, 08:28 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Agreed.. If you like steel, I would get a pair of NAS 110 Steelies (130 rims) or a set of Wolf wheels then put some new rubber on them... You are a rover owner now.. break out the credit card and get that thing smoking... Don't be
Old April 22nd, 2010, 10:14 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
33x12.5x15 BFG KM1s
http://cnj.craigslist.org/pts/1669026226.html Somerset NJ
33x10.5x15 BFG KM1s they might work on your rims
http://southcoast.craigslist.org/pts/1687707719.html Freetown MA
(I think you mentioned you were going to Boston this weekend)
Might be worth looking into
tire, tires
WTB: D90 Tires reaper99999 Wanted 0 September 1st, 2008 04:02 AM
WTB - White 110 Wheels with or without tires GustavD90 Wanted 0 August 12th, 2008 11:18 PM
Tires, Tires, Tires Joe P Misc. Chit-Chat 28 August 9th, 2005 09:58 PM
WTB: BFG AT/KO 265/75/R16 tires Art Vigil Wanted 6 December 15th, 2004 04:07 AM
BFG AT Ko tires for sale Seriesman For Sale - Parts 6 August 18th, 2004 11:09 PM
