WTB Hub and I have a few questions - Defender Source
Old July 12th, 2016, 07:34 AM
BlackField's Avatar
BlackField
Oscar
D110
Anyone have a Drive Member and Hub Assembly sitting around relatively free of barnacles and algae that they are willing to part with? I just want one for measuring, it won't be going on a truck.
How standardized are these among all the usual suspects defender axles? Are there thick and thin drive members? is it the bolt through dimension that changes?
Oscar
Old July 12th, 2016, 09:50 AM
There are thick and thin drive members. Post up a picture of what you have or what year truck you have. If you have thick drive members I think Gustavo is selling a HD set.
Old July 12th, 2016, 10:21 AM
There are only two hub arrangements on Defenders. Before the 300TDI and after. There are a few differences. Later has bearings closer together, thinner drive flange, and somewhat different seals.
Old July 13th, 2016, 06:50 AM
BlackField's Avatar
BlackField
Oscar
D110
Thanks Dave and John.
I honestly don't know what to look at to determine what's under my bitsa truck. I'll pull a wheel and snap some pics.
I'm mostly concerned with the external dimensions.
What are you planning/figuring? Disco stuff is fairly easy or come by (narrow bearing spacing and thin drive flange.
If you are thinking for a trailer set up, then the flange from a broken NAS Disco or D90 rear makes a nice cap for the narrow bearing hubs. Early RRC mushroom caps for the wide bearing hubs.
-Jeff
Three things Jeff,
One looks more straight forward than I was expecting, it's (the idea) of fitting some two piece rotors I have in the garage.
The second is for wheel spacer idea.
Third, I enjoy drawing this stuff in Autocad.
So, I can head down to the local salvage yard and look for a D1 and that should be close enough in external dimensions? When you guys mention thick and thin drive members is this the diameter of the flange that is wider/ thicker or the part that the 5 boots go through thicker? Looks like about 15mm or so in the picture.
Pulling a hub removing the caliper, five drive member bolts then one larger axle nut? 52mm axle nut? F wrench do it in most cases?
Thanks again
A few moron questions about interior trim panel removal. rustydefender Defender Technical Discussions 17 March 23rd, 2016 04:12 PM
Installed Momo wheel and hub, now have clicking noise whenever wheel turns bradfordish Defender Technical Discussions 8 September 3rd, 2013 06:46 PM
hub face to hub face axle length TexasD-90 Defender Technical Discussions 1 June 3rd, 2011 08:00 AM
93 NAS D-110 Diff oil and Hub Seal Questions AHollander Defender Technical Discussions 16 October 23rd, 2007 01:46 AM
few questions on fitting 300Tdi to NAS d90 Gkase Defender Technical Discussions 11 June 13th, 2006 02:17 PM
