WTB: Harness ends for Heated Seats - Defender Source
Old December 31st, 2011, 05:51 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
If anybody can tell me where to locate a pair of female connectors for the pictured switch it would be helpful (I am looking for the connector and about 6 inches of the harness).
For some reason I think I can find them in older Discoveries, (if anybody knows the years please post as well, I have no problem going to a junk yard and cutting a pair out).
I wired up a set of Webasto Heater seats (with relays, etc..) and I would like to add a factory switch. If anybody has a lead it would be helpful. Thanks
ID:	45470   Click image for larger version
Name:	back of switch.jpg
Old December 31st, 2011, 06:19 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I think this plug will work, you might have to modify the plastic a little.
http://www.expeditionexchange.com/ca...1&cat=0&page=1
Old December 31st, 2011, 06:24 PM
tjfslaughter
thomas
Burbon
nice find, that will reduce a splice... thanks.
I will be ordering them soon. These Webasto Heated seats are really hot, with the Webasto coolant heater we are really warm in the truck.
I am getting a webasto air heater next week (in trade for some custom ammo....)
Old December 31st, 2011, 06:33 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Link to the webasto seat heaters? I am looking to buy some elements for my seats.
Old December 31st, 2011, 07:25 PM
tjfslaughter
thomas
Burbon
Here are the ones I have.
http://www.ebay.com/itm/WEBASTO-SEAT...item2eba224cae
Here is the PDF sales sheet.
They are very warm, the best I have ever sat on. I attached them to a set of Sheep Skin covers I got on the board from another D-90 member. They come with a 3 position switch (seat & seat and back). I took the time to install a relay and use a single switch (on High at all times). The LR switch will fit in my dash (it is only an on/off switch).
I had a friend at Webasto so I got the coolant heater, and seat covers at a deal... The air heater comes in next week....
Old January 1st, 2012, 12:02 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
How hard would it be to install these in existing seats? Something in the back of head is saying they spray glue the cloth to the cushions and that might be a problem. Anyone take apart a seat before that can weigh in on this that would be great.
Old January 1st, 2012, 12:11 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
you dont need to spray they have an adhesive strip. very easy to install done it on three sets of seats. .
Old January 1st, 2012, 12:28 PM
tjfslaughter
thomas
Burbon
It's very easy, if you don't want to do it, you can take it to an upholstery shop.
I stuck them to my seat covers so I could remove them if I ever wanted.
Old January 3rd, 2012, 08:14 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
I'm working on a 99 DI and I think it had heated seats. I'm going to use some cloth seats from my 96 DI so I don't need the heated seat harness. Let me make sure it had heated seats and get back to you.
BTW, the seats, center console and dash did not come with the truck and that's why I am not sure if it had heated seats.
John C.
Old January 3rd, 2012, 08:24 AM
tjfslaughter
thomas
Burbon
No problem John, I need an excuse to go The Mountain House!
Old January 4th, 2012, 10:09 AM
JohnC
This is it, right?
John C.
Old January 4th, 2012, 10:19 AM
tjfslaughter
thomas
Burbon
sure looks like it.
Old January 4th, 2012, 10:23 AM
JohnC
Ok, I'll see how much of the harness I can cutoff.
John C.
Old January 4th, 2012, 04:35 PM
ron's Avatar
ron
Ron
do you have the webasto wiring I tried doing the same thing with the disco swtches and can olny get the backs to work
also which Webasto coolant heaterdid you get? have pics of the install.
Old January 4th, 2012, 06:26 PM
tjfslaughter
thomas
Burbon
No pics of the install, I am on the road.
But look at the attached document, it gives you an idea. It is pretty simple if you understand how relays work (there are 3 on the Webasto harness and you have to tie properly into 2 on the truck).
Basically when the key is in the "off position" the webasto has control of the heater blower (the actual blower not the switch inside the truck, you need to keep that on high or low in the winter if you want the cab to warm up). As soon as you turn the key on the webasto gives you control of the heater blower...
I have the thermo 50 12volt.
On the seats if comes with a 3 position switch, Off, Seat, and Seat and back. I did not use the switch and I am running them off a relay. Basically each pad has a 12 volt + and a ground. Take the 12 volt + of each of the parts and put them together. Basically by doing that you remove the third position option and you can then use the factory switch....
Old January 8th, 2012, 07:57 PM
JohnC
I have that part for you. For your records in came off a 99 DI, my 96 DI (SD model with cloth seats) did not have the heated seats nor does my 95 DI (leather manual seats).
Let me know if you want me to ship it, meet up in the city or in Tappan.
John C.
Old January 9th, 2012, 07:58 AM
tjfslaughter
thomas
Burbon
I can drive up to Tappan. How does Friday sound?
Old January 9th, 2012, 08:05 AM
JohnC
Friday sounds good, I'll PM you my address.
John C.
seats
WTB - rear high back seats for '85 110 sparhawk Wanted 0 December 16th, 2010 04:36 PM
WTB Rear bumper ends cgalpin Wanted 9 April 30th, 2009 11:43 AM
WTB: Defender front seats pmd Wanted 7 April 5th, 2008 09:19 PM
WTB: d-90 front seats for ST ember Wanted 1 April 5th, 2005 07:35 PM
FS: Four SW Jump Seats from 95 D90 DJ Menasco For Sale - Parts 4 December 19th, 2003 12:28 AM
