WTB Galvanized fuel tank cradle - Defender Source
Old November 26th, 2008, 03:52 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
Mine is pretty much falling off the rig!
Thanks!
Old November 26th, 2008, 04:01 PM
They're readily available at RN etc.
Old November 26th, 2008, 05:28 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Start spraying your bolts now! I just took mine off half an hour ago and broke 5 out of the 6 bolts. . Huge pain.
Old November 26th, 2008, 09:39 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
great... thanks for the heads up... what should i spray it with?
And if I break one off... how do I get the remaining bolt out?
Old November 26th, 2008, 09:40 PM
cellulararrest
Chris Snyder
The penetrating lube of your choice. PB Blaster is good.
Old November 26th, 2008, 09:48 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
Cool, but how do I get it out IF I do break one off?
Old November 26th, 2008, 10:24 PM
A set of extractors and a powerful drill are good investments for working on your 90.
Old November 26th, 2008, 10:45 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
Where would you suggest I get the extractors... I am good with the drill
Old November 26th, 2008, 10:50 PM
Sears is fine. They're just kinda costly because they're high-grade metal.
You have to make a call on each fastener, sometimes you want to extract, sometimes you just want to drill out out as much as possible and then re-tap.
Both methods require pretty good centering while you drill. Obviously starting small and working up works the best.
Fortunately, many places on the bottom of the plate, if you totally screw up the bolt and its captive nut, you can just drill it all out and use a standard bolt and nut. And I think the anti-roll bar mount doesn't have captive fasteners at all (but I forget exactly). The very worst are the ones that go into the bottom of the crossmember. Access is pretty bad, and so is the rust.
Old November 26th, 2008, 11:05 PM
cellulararrest
Chris Snyder
What Jim said. Your success may vary
Old November 28th, 2008, 12:38 PM
Or you know, cut the captive bit off and weld on a new nut.
Old November 28th, 2008, 05:17 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I have 3 stock units that can be galvanized $20 each plus shipping
Old November 28th, 2008, 07:33 PM
rovertrader's Avatar
rovertrader
Dale
One correction- not if, but when you break one off, and rest assured, it will be the ones in the rear crossmember.
Ron- I'll take the 3 stock ones if they aren't too far gone, as I am getting a pile to take to the galv'r- make a deal....
Old November 29th, 2008, 08:41 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Just tossed a good used one in the scrap pile if you want it.
Email:
Old December 2nd, 2008, 03:31 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
ECR, you are very hard to get a hold of! I would like to know what you want for the used cradle and how much for shipping etc.
thanks!
Old December 2nd, 2008, 03:36 PM
ECR does not give shipping quotes.
Old December 2nd, 2008, 09:37 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
ECR... shoot me a PM, I am interested in that cradle!
Old December 2nd, 2008, 09:43 PM
cellulararrest
Chris Snyder
Ron has them... why not get one from him?
Old December 2nd, 2008, 09:53 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
PM'ed him... haven't gotten anything back...
Old December 3rd, 2008, 09:44 AM
ECR's Avatar
ECR
thanks!
Not at all hard to get ahold of.
Call the shop, open 5 days a week
Email, checked 5 or 8 times a day
I don't use the PMs on this board.
If you want it shipped then I'll ship it and Holly will get a CC from you for shipping.
If you need to know what the shipping will cost on your free part, then you'd need to do that on your own. I'm not goign to spend time doing a shipping quote for something I am giving away.
Email:
fuel, fuel tank
Fuel Tank Cradle - Skid plate Flagg Defender Technical Discussions 16 September 14th, 2006 11:30 PM
Slick Rock fuel tank cradle rvrsrvc Wanted 1 August 10th, 2005 09:48 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
