WTB: Front/bottom pulley for a 1994 D90 (NAS) - Defender Source
Old September 6th, 2016, 05:35 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Hi, looking to buy ASAP for a front/bottom pulley for a 1994 Defender 90. I just discovered mine is cracked 3-4 inches and is loud. If not please provide the part number so I can purchase one at RN. Thanks.
Old September 6th, 2016, 05:38 PM
Assuming you are talking about the tensioner/idler, you can use a Disco one....it just puts the "tension bolt" on the top instead of the bottom. Makes it a little trickier to snug up, but by that I mean maybe adds a few minutes to the job. The plus side is the Disco ones are cheap as chips, whereas the Defender ones (last I saw) were priced into the stratosphere.
Old September 6th, 2016, 05:42 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
I am referring to the bottom front pulley (engine). I believe it's the crankshaft pulley #8?
Old September 6th, 2016, 06:46 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Are you are looking for the balancer? I was not able to locate a new one a few years back (they are unique to the 3.9), but D&D can refurbish them for you. If the only problem is a seal groove, then a speed sleeve will work (or you can have it hard chromed and ground to size).
Angus
Old September 6th, 2016, 06:59 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
I am looking for the big (the bottom) pulley below. Noticed the pulley on mine has a 3-4 inch cracked on the side of the groove where the belt attaches. Can anyone confirm what the pulley is called or have a part number so I can order one from RN. Thanks in advance
Old September 6th, 2016, 07:02 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Much easier than the balancer. Rovers North lists one (RNM097) for $63...
Angus
Old September 6th, 2016, 07:09 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Thank you. So it was the water pump pulley not the crankshaft pulley?
Old September 6th, 2016, 07:15 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Hmmm. Your diagram shows a serpentine belt, while my 3.9 has 3 separate belts. Not sure that is the right part for your set up if it is a serpentine.
Angus
Old September 6th, 2016, 07:22 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Here is what the front on my engine looks like. The alternator is removed.
Angus
Old September 7th, 2016, 09:49 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Bump looking for crankshaft pulley # 5
1994, 90, d90, nas, pulley
Need help 1994 D90 A/C tensioner pulley Jbullis Smaller Projects 6 October 12th, 2015 12:00 PM
Defender 90/110 Exmoor trim front bottom and headrest seat cover includes foam New Shop On Broward For Sale - Parts 8 January 23rd, 2013 08:10 AM
Front Seat Bottom Cover madcowdungbeetle Wanted 7 December 31st, 2009 06:41 AM
Anyone out there have an extra front seat bottom? D90 d90guyinla Wanted 5 January 3rd, 2008 05:33 PM
RR Classic Driver's Front seat bottom access door jack frisch For Sale - Parts 0 February 27th, 2005 12:50 AM
