WTB: D90 Dash Dimmer Switch - Defender Source
Old January 10th, 2008, 12:38 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
My D90 Dash Light Dimmer switch self destructed so I am looking for a new or used replacement.
Gary
Old January 11th, 2008, 09:18 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
dim switch
Hi,
My guage dim switch died 3 days ago but I didn't know it. When it died it created a major headache for me. My alpine alarm crapped out at the same time so I spent three days hunting down the source. My alarm flashes both my extierior running lights and the interior gauge lights when it is engaged and disengaged. When I engaged the alarm I would blow , my alarm fuse, radio fuse, and the left (front, rear and side marker) lights fuse. I didn't know it but this last fuse also controls the gauge lamps. So I spent a butt load if time focused on touble shooting my alarm. It wasn't until I read your post and a couple other posts regarding gauge dim switch issues. So this a.m. I popped out my switch and ran a jumper at the dimmer switch harness plug to bypass the dimmer switch. All of my problems were solved with that simple solution. I found out you do not have to have the jumper to run the gauge lights. They are default in the dim mode with the switch turned off - or totally disconnected. When I put the jumper in place the gauge lights were in the bright mode. I attached a few picks of what I did. I put the switch back in place but not pluged into the harness. (after I put the jumper inplace I put a pice of electrical tape arounf the jumper to hold it in place. (not pictured). So if you can live without having easy control to dim the gauge lights you relly don't have to replace the switch. If you want them dim - just remove the harness plug from the switch - if you want them brighter - install a jumer as I did.
ID:	11625   Click image for larger version
90, d90, dash, switch
Dash Light Dimmer Switch Stmpede Wanted 6 November 30th, 2008 10:29 PM
WTB - d90 - Good to Great Deal. uzj100 Wanted 1 July 15th, 2005 12:54 PM
WTB: Owners and Workshop manuals for 97 NAS D90 wea Wanted 2 August 30th, 2004 11:23 AM
WTB, Need LOCK from rear door 95 SW D90 Vadim Wanted 0 August 29th, 2004 02:11 PM
WTB: Forward Facing Rear Bench for D90 DJ Menasco Wanted 2 January 24th, 2004 05:53 PM
