WTB Cooling Fan for 3.9 V8 - Defender Source
Old June 25th, 2015, 12:08 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
To my understanding, not all 3.9's turn the same direction. I have a 3.9 whose threads on the front of the water pump (where the fan spins on) indicate that the fan tightens on the threads in the counterclockwise direction, as viewed from the front bumper, and thus the engine and fan turn clockwise when running. I have a fan from a Disco that doesnt turn that direction. I have been scratching my head about this for some time now. Legend has it that Land Rover, in their infinite wisdom, changed the crank rotation direction of the 3.9 at some point. Is this correct?
In other words, I require a fan that threads on the water pump counterclockwise, and spins clockwise when running. Anyone have one?
TIA,
Kent
1985 Land Rover 110 3-door ST
Old June 25th, 2015, 12:30 PM
Turn the engine on, check which way the fan turns and turn in the same way to unscrew
I'm assuming you have a v-belt engine, right?
Old June 25th, 2015, 12:34 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Yes, v-belt. I don't have a fan to unscrew though. I need one.
Not sure if you can see the threads in that pic. Engine turns clockwise, as looking from the front of the truck.
Old June 25th, 2015, 08:16 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
The engines turn the same direction, it's just the water pump/fan that is standard or reverse rotation depending on if it's a V-belt or Serpentine belt engine. V-belt engines are reverse thread on the fan clutch where it screws onto the water pump. I have several V-belt fans with clutches available.
1991 RRC 4.2, R380, LT230, TrueTrac, Detroit, sliders, 33s, blahblahblah....
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old June 28th, 2015, 08:35 AM
scatterling's Avatar
scatterling
Neil Hanekom
75 109 exMOD
I have one if you still need a fan.
Old June 28th, 2015, 09:41 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Do you want to go electric?
I have a dual Flexalite setup--26"x15"; it was on a RRC.
Rent my
Old June 28th, 2015, 11:18 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Found a fan/clutch from an RRC. I'll see if it works when it arrives this week. If it doesnt, I just might go electric.
fan, v8
WTB...AC... condenser-cooling fan motor..... justmarv Wanted 5 February 28th, 2014 02:52 PM
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
Radiator Cooling Fan mdmccallum Defender Technical Discussions 10 January 16th, 2009 10:02 AM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
looking for a viscous cooling fan drork Wanted 1 July 1st, 2004 11:29 PM
