WTB: ball-joint rubber boot? - Defender Source
Old December 4th, 2015, 08:07 PM
Does anyone know *if* (or where) one can source the "rubber boot" by itself for the ball joints? I seem to tear those damn things ALL the time, and apparently I didn't catch this one early enough so I need to rebuild the drop-arm joint (and ironically...already used the boot from this kit on a prior repair for a torn boot).
I'm *fairly* certain that the tie-rod ends rubber boot, and the steering ball-joint rubber boot are all the same.
Anyhow, if anyone has a part# or source for these "rubber boots" let me know...I'd like to load up on some, and salvage the ball-joint rebuild kit that I already have that is sans rubber boot.
Old December 4th, 2015, 09:11 PM
Have you met Britt from Diverse Suspension Technology?
-Jeff
Brilliant! Anyone used these on the steering ball-joint or tie-rod ends so I don't have to recreate (reguess) the wheel?
Energy Suspension Universal Dust Boots
Old December 4th, 2015, 09:13 PM
I can probably go measure....
Old December 4th, 2015, 09:32 PM
We used the energy suspension ones on BMW's back in the 80's. Let me know if find a source for ones to cover defender tie rod ends. I haven't made an effort to find the right size.
Old December 4th, 2015, 09:33 PM
Checked the panhard rod joint. 17.5 mm pin, 37 mm base, 18 mm height installed. Can't see anything really close enough....
Couldn't spot a loose TRE to check.
Old December 4th, 2015, 09:35 PM
I'm on it....
------ Follow up post added December 4th, 2015 09:36 PM ------
You mean the drag link end at the steering drop-arm balljoint?
Old December 4th, 2015, 09:39 PM
Yes. Meant to say pitman arm.
Old December 4th, 2015, 09:54 PM
Ok that's what I thought you meant....bummer, that means the search continues. I may reach out to Energy about making some up. Though that doesn't solve my short-term need for a boot.
Old December 7th, 2015, 06:20 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Sell the rebuild kit and buy the full drop arm. $89 bucks from RovahFarm.
-Ren Ching
Old December 7th, 2015, 06:33 PM
*Sort of* agreed, but really it's not all that hard to rebuild the drop-arm (even without taking it off, though I know some will disagree). The REAL larger issue is that these boots CONSTANTLY get torn...so even with a rebuild, I guarantee I'll be dealing with another torn boot scenario in the near future.
That said, still really having a hell of a hard time finding replacement boots for the drop-arm or tie-rod ends.
Old December 7th, 2015, 06:51 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
How are you tearing all these boots? I think that's the real issue!
Old December 7th, 2015, 06:53 PM
Not driving like a p*ssy on pavement! Jeez....you've seen my 90, right? The 130 mall-cruiser has no boot issues I assure you.
Old December 7th, 2015, 06:55 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Brandon does not have boot issues.
Old December 7th, 2015, 07:05 PM
I find that extremely hard to believe. Unless he just breaks enough shite that this stuff needs to be replaced before things get torn .
Huff, Galpin, and I have all had this exact conversation ongoing for years....I just finally decided to try to get motivated enough to find replacement boots after discovering - yet again - a completely torn drop-arm boot that unfortunately was caught too late and now has some play in the balljoint so I've got to replace it regardless. However, the "boot" from my spares kit was already pilfered by me previously to fix a prior tear .
Old December 7th, 2015, 07:50 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I don't drive like a pooosay and don't have boot issues. You're not buying the right boots
Old December 7th, 2015, 08:01 PM
Just to be clear, I wasn't calling you a p*ssy ...just making generalizations. That said, all it takes is one branch/etc to pop up and catch that boot and you've got an issue - but honestly no idea *what* actually ends up causing it, all I know is that there's a plethora of us that do suffer from this either on the drop-arm or tie-rod.
Old December 7th, 2015, 08:12 PM
rovertrader's Avatar
rovertrader
Dale
Age of the rubber doesn't help either. I need a boot for A arm rebuild kit- new kit with shot boot...
Must have a bigger problem to do that
Old December 7th, 2015, 08:14 PM
In order to not drive like a pussy you have to actually drive your truck year-round.
Old December 7th, 2015, 08:16 PM
rovertrader
Dale
Nah, just very old kit I bought when visiting George like 12+ years ago... Of course, could have had things stacked on it too, never know?!
Like Jason said, hate to trash kit d/t rubber boot deterioration
rubber
WTB: NRC3923 A-Frame Ball Joint Housing sonoronos Wanted 1 September 23rd, 2014 12:07 PM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
WTB: D-90 Cross rod end, steering drop arm, ball joint kit Blakesrover Wanted 1 October 1st, 2009 09:40 AM
rubber boot for horn stalk bjf Wanted 5 March 30th, 2009 02:08 PM
Quick fix-torn boot- rear a frame diff joint? J.P. Defender Technical Discussions 0 September 17th, 2008 09:08 AM
