WTB: ball-joint rubber boot? - Page 2 - Defender Source
Old December 7th, 2015, 08:41 PM
Originally Posted by Jymmiejamz View Post
In order to not drive like a pussy you have to actually drive your truck year-round.
Hmmm....that is actually a very valid point. Ok, so I'm a non-p*ssy April->December, full-blown p*ssy from January->March.
Old December 7th, 2015, 08:42 PM
Your boots are probably rotting from sitting all winter.
Old December 7th, 2015, 08:52 PM
Mine aren't shot (the boot anyway) i think the ball joint is though..
i replaced all the other with greasable ball joints (3) but need to do the drop arm at some point.
BTW.. i drive all year long
Jason.....
95' D90 - daily driver..
Old December 7th, 2015, 09:07 PM
Yeah, must be the climate-controlled comfort of snuggled in the garage for the winter with other Rovers and classic cars that cause my rubber boots to wither away .
Old December 7th, 2015, 09:10 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Get a clamp for your steering stabilizer and swap to a disco arm.
-Jeff
Agreed, I'm not sure why more people don't do that, I like having 2 pair of easily replaceable ends. Never understood the defender style
Old December 7th, 2015, 11:34 PM
Ordered up a set of these to try just for the heck of it and since they were cheap enough, will report back:
Daystar KU13001BK Tie Rod End Dust Boots (15mm - 19/32 Inch x 35mm - 1 3/8 Inch) Pair. Daystar Suspension Parts
Old December 8th, 2015, 08:03 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Ordered up a set of these to try just for the heck of it and since they were cheap enough, will report back: Daystar KU13001BK Tie Rod End Dust Boots (15mm - 19/32 Inch x 35mm - 1 3/8 Inch) Pair. Daystar Suspension Parts
How do these solve the problem? The inner boot will still crack and dry out, right? I thought the problem is pinching and poor material quality. My 110 still has good boots, probably due to no pinching and better quality material.
Old December 17th, 2015, 08:46 AM
Ok, quick update...the above were garbage - there's not even a "lip" on the bottom edge so I'm not sure how these would stay in place with any sort of motion.
I ended up having an old past-its-prime tierod end laying around, so grabbed the boot from that...which *appears* that it could be part #214649 (the part has a "3025" stamped on it, much like shown here and in the below pic on the left). However, Paddocks also has #A0408 which they do state is actually for the drop-arm (here and in the below pic on the right).
Anyhow, the long and short of it is that the #214649 (3025) that I scavenged from my old tierod end DID work great on the pitman/steering drop-arm. I'm going to order up a few of the #214649 and #A0408 anyhow from Paddocks just to have on hand. So while the A0408 looks more like the one that came off my drop-arm, the 214649 works just fine and I see no reason this can't be used for the drop-arm as well as the tierod end.
rubber
WTB: NRC3923 A-Frame Ball Joint Housing sonoronos Wanted 1 September 23rd, 2014 12:07 PM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
WTB: D-90 Cross rod end, steering drop arm, ball joint kit Blakesrover Wanted 1 October 1st, 2009 09:40 AM
rubber boot for horn stalk bjf Wanted 5 March 30th, 2009 02:08 PM
Quick fix-torn boot- rear a frame diff joint? J.P. Defender Technical Discussions 0 September 17th, 2008 09:08 AM
