WTB aluminum end piece from LT77 - Defender Source
Old April 25th, 2013, 02:43 PM
I am looking for the aluminum end piece of an LT77 housing - the part that mates to the transfer case (aluminum part on the left of this picture). It's about 6" long.
Or any equivalent transmission end piece that can bolt to an LT230 that is about 6" long (or longer) and has parallel faces already machined. It's for my EV project and I'm looking for the easiest way to make an adapter and this would get me 90% there.
TIA
charles
Originally Posted by pendy
I'm here for the D's
Old April 25th, 2013, 02:56 PM
Yeah the ZF end piece is a bit skinny (i have one). I could use cut off a piece of the main housing but this would require machining and then likely welding on an adapter plate, whereas with one of these I could bolt an adapter plate to it.
I'll check with Rob, thanks.
charles
Old April 25th, 2013, 04:17 PM
Whoohoo, now that's what I'm talking about. Rob hooked me up with one for free!
FYI, the LT77 version is 4.75" wide/long and the R380 one is 5.75"
Old April 25th, 2013, 04:23 PM
Rob is good people.
Old April 25th, 2013, 04:34 PM
Originally Posted by evilfij View Post
Rob is good people.
He sure is!
Old May 6th, 2013, 10:54 PM
I'm working on my adapter and doing test fitting and mockups on an LT230 but want to verify one thing since none of this is bolted to the frame yet. Is that flat spot on top shown in the first picture going to be horizontal when everything is in place (assuming an R380)? I just want to clock the motor to be level on top and I believe this would be.
Old May 6th, 2013, 11:04 PM
Flat piece is on top.
Old May 6th, 2013, 11:12 PM
Yup, but can you confirm it sits horizontal (parallel to the ground)?
Old May 6th, 2013, 11:19 PM
I mean I can't say down to 1 degree, but it looks horizontal when mounted in the truck. It is where the shifter assembly mounts.
Old May 6th, 2013, 11:28 PM
Awesome, thanks
aluminum
WTB: Aluminum Wing Top Protectors Holiday Wanted 1 November 20th, 2012 01:22 PM
WTB rear end door latch Overlander Wanted 0 April 6th, 2012 04:44 PM
WTB crossrod eye end roverman2010 Wanted 0 October 20th, 2011 10:16 PM
WTB: D-90 Cross rod end, steering drop arm, ball joint kit Blakesrover Wanted 1 October 1st, 2009 09:40 AM
WTB Complete Rear End Hammertime Wanted 11 October 14th, 2008 07:43 PM
