WTB 94,95,-97 ST NAS interior light trim plate - Defender Source
Old March 31st, 2015, 03:49 PM
johndoe007's Avatar
johndoe007
Patrick
1997 D90 ST #1615
I am looking for the 6 inch finisher section the little inside light fits inside of up between the two larger finishers the sun visors mount to. I'd normally call it a headliner part but as its only 3 inches wide its more of a finisher..
Thanks in advance!! email me please.... I need it....
1997 D90 ST #1615
I have not been asked once if my 90 was a Jeep after I installed my new decal!
Old April 1st, 2015, 08:44 AM
johndoe007's Avatar
johndoe007
Patrick
1997 D90 ST #1615
Part Number AWR1546LNF
Pretty Please?
1997 D90 ST #1615
Old April 1st, 2015, 09:33 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
looks like most of the usual suspects in the UK have the part...
AWR1546LNF | Panel - Trim - Land Rover Part AWR1546LNF
you can also check with Justin @ Lucky8
Old April 1st, 2015, 09:46 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
What are the part numbers for all 3 pieces? I need all 3 if available.
Legend in My Own Mind.
Old April 1st, 2015, 10:03 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Are you talking about these three pieces?
Trim Panel - Roof - Land Rover Workshop
Old April 1st, 2015, 10:21 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yeah. That's them
------ Follow up post added April 1st, 2015 09:22 AM ------
What about the light and wire extension from light to harness?
Old April 1st, 2015, 10:46 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
LR direct justs lists the item with the stock status of "subject to LR stock", which Land Rover has long listed as obsolete.
These are the pieces that many companies have talked about reproducing, but I have yet to see anything come to fruition.
Old April 1st, 2015, 10:51 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
My question is what dies a 2014 soft top cone with ? Do they have trim at all?
Old April 1st, 2015, 11:18 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I do not believe they have any trim
Old April 1st, 2015, 12:21 PM
johndoe007's Avatar
johndoe007
Patrick
1997 D90 ST #1615
Thanks yes They are NLA and the 94 apparently has a different part number and the part number I used above is for 95-97 which is what I need.
Anyone have one they want to get rid of?
1997 D90 ST #1615
Old April 1st, 2015, 04:00 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
That's strange. Looks unfinished. U wish someone would reproduce these. Can't be too difficult. I would buy 2 sets.
Old April 1st, 2015, 04:04 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Brian Kandefer had talked about doing it, as well as another company in Massachusetts. As far as I've seen, nothing has been produced. It seems like a great product idea.
Old April 1st, 2015, 04:53 PM
johndoe007's Avatar
johndoe007
Patrick
1997 D90 ST #1615
Great Idea. There is a makerbot store nearby to me. I will check it out tomorrow and let everyone know. They do high end 3d printing for a nominal fee in the hope you'll shell out the $30k for the machine.
1997 D90 ST #1615
Old April 5th, 2015, 01:43 PM
johndoe007's Avatar
johndoe007
Patrick
1997 D90 ST #1615
So I spoke with maker bot and they can make them for about $30 each! But I have to get them a 3d scan of one. Any chance someone has a 3d scanner at work?
1997 D90 ST #1615
Old April 5th, 2015, 02:50 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Wow cool. I would be in for a set for sure.
Old April 9th, 2015, 10:33 PM
ofender
Lar Malleis
1997 D90 / 1998 RR / 1999 D2
N.A.S. Soft Top trim parts
Hello Patrick,
It seems a lot of soft top (ST) owners would like to purchase a set. I have spent a crazy amount of time on this project to find the three parts; BTR9810 (RHS), BTR8513 (LHS) and BTR9811 (Centre). During my research, I have also learned that the parts above from the U.K. are covered in vinyl wrap. The N.A.S. trim pieces were bare plastic. All seem like they are unavailable from anywhere in the world.
I believe because the trim parts must be removed each time you change from soft top to hard top, some prior owners either damaged or just left them off. Although I have found different part numbers for the 94 vs. 97 they are the same parts or would work. Okay so to go forward what's next?
1.) Get a set from someone to copy. All of my buddies have hard top versions or SW, the parts we are looking for are (to my knowledge) only ST and N.A.S. Anyone know of a set or someone willing to loan them? From this I believe a company in the U.S. could make them. They are thin plastic but do have some complex curves.
2.) Possibility investigate the parts from a U.K. SVX S.T. Yes, it's different but could be an option.
If anyone has any other idea please let me know. Thanks, Lar
Old April 10th, 2015, 08:14 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
This would be great if someone can lend out a sample
Old April 10th, 2015, 08:40 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I was working with a buddy that makes prosthetics, long story short he has my set and has since gone MIA... He made three sets before he disappeared. 94 are different then the 95/97's. The 94's are wrapped with vinyl, while the 95/97's are injected molded. Anyway I haven't talked to him since Christmas and he has my originals and all the copies. Good luck, if anyone has questions I have gone through the process and it was fairly simple. Production was the issue, bc it isn't worth making a bunch of molds because of the limited markets
Old April 10th, 2015, 09:54 AM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
I'm in for a set. Yet another piece of my truck that Urban Land Cruisers "lost" on my restoration!! (So frick'n mad at David and crew! "Tanks for nothing")
Old April 14th, 2015, 01:44 PM
johndoe007's Avatar
johndoe007
Patrick
1997 D90 ST #1615
OK so I have some good news to report on the trim pieces. For $350 per piece an aeronautical engineering company with a really really good 3d scanner and "touch up" software will scan and give me a makerbot printable file. Makerbot will charge about $30.00 for the center bit and about $60.00 per side piece.
I am most likely going to have the scan done for my center piece only. At which time I will be offering them for sale in an unlimited quantity unlimited supply. How many people might be interested in a center piece?
I might even go thru kickstarter for this as well as I will be looking to recoup my costs but not make anything.
1997 D90 ST #1615
95, 97, ht, interior, nas
Rear 110 interior trim (aka boot trim) for sale ontheway For Sale - Parts 5 December 17th, 2014 11:07 PM
Bulkhead VIN plate and 4WD plate and tow plate o2batsea Series Technical Discussions 3 July 16th, 2013 03:12 PM
NAS 110 interior trim mounting tabs Jackie Treehorn Defender Technical Discussions 13 December 24th, 2012 11:06 AM
Interior Dome Light Trim Piece aosias Defender Technical Discussions 10 April 1st, 2010 09:28 AM
WTB: SW Interior Trim PCRover Wanted 7 October 7th, 2007 09:25 PM
