Wtb: 5 speed D1 - Defender Source
Old June 29th, 2015, 11:02 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Wtb: 5 speed D1
Needed for running gear, body condition irrelevant. Closer to DC the better.
Old June 29th, 2015, 11:14 PM
robertf
Robert F
1995 Discovery
maybe you know and this doesn't change your plan, but the shifter is in a different spot compared to a 90.
I do have a GEMS flywheel that I just removed. It'll need to be resurfaced
Old June 29th, 2015, 11:52 PM
Abrooks's Avatar
Abrooks
Tony Brooks
This is for a slightly different idea I have. Thanks though!
Old June 30th, 2015, 07:08 AM
5 spd hunter project ? Got to hand it to you Tony, for a guy with no time you sure do take on some large projects.
Old June 30th, 2015, 07:13 AM
rovertrader's Avatar
rovertrader
Dale
I have a D-I R380 if you decide on pieces....
Old June 30th, 2015, 08:21 AM
I know of a couple pedal boxes that have the clutch holes
Old June 30th, 2015, 08:23 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks, all! I was hoping to find the whole enchilada to facilitate an Lt230 conversion at the same time, but if I have to piece it together, so be it. I know there's a soccer mom out there somewhere that's aching for a new car . . .
Old June 30th, 2015, 08:45 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Tony, I believe Randy aka Roverbones has a full conversion kit, DiscoWeb Message Boards
Shayne at the Rover Shop does as well
Old June 30th, 2015, 04:17 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks, Zack!
Old June 30th, 2015, 04:52 PM
rovertrader
Dale
I have a Tcase too...
Old June 30th, 2015, 08:52 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
Tony, hit me up if you have any questions about the conversion. I put a DI R380 and LT230 in my '91 RRC about 4 years ago, fabbed up some pieces (like the pedal box) and took a few pics along the way.
1991 RRC 4.2, R380, LT230, TrueTrac, Detroit, sliders, 33s, blahblahblah....
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old June 30th, 2015, 09:16 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Stay auto......Ray will tell you.....trust me, and then a 2.5 NAD upgrade.....
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old June 30th, 2015, 10:00 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
It's a little different than than, Jeff. The Disco pedal plate will interchange with a '95 RRC, (but you can simply swap the pedals onto the '95 RRC plate too) But to fit a '94 and earlier (hard dash) RRC, the Disco plate is taller and the steering column goes through it too. There's also a dash support between the pedals on the hard dash RRC and the pedals are on separate pivots whereas the '95 RRC/DI pedals are on a common shaft. I wound up cutting the pedal mounting brackets off of both plates and fabbing them a bit to make everything work, rather than sourcing an early pedal plate from England.
BTW, you in the house yet?
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old June 30th, 2015, 10:07 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
I definitely will the next time I'm over that way.
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old June 30th, 2015, 10:25 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Nah, I love my 5 speed for what she is; in truth in wouldn't have it any other way. Now with a 2.5 NA it would be a beast...
Old June 30th, 2015, 10:56 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Pictures and any guidance would be very welcome. Was it worth the effort?
=TigerDan;651750]It's a little different than than, Jeff. The Disco pedal plate will interchange with a '95 RRC, (but you can simply swap the pedals onto the '95 RRC plate too) But to fit a '94 and earlier (hard dash) RRC, the Disco plate is taller and the steering column goes through it too. There's also a dash support between the pedals on the hard dash RRC and the pedals are on separate pivots whereas the '95 RRC/DI pedals are on a common shaft. I wound up cutting the pedal mounting brackets off of both plates and fabbing them a bit to make everything work, rather than sourcing an early pedal plate from England.
BTW, you in the house yet?[/QUOTE]
Old June 30th, 2015, 11:03 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
I've never regretted doing it. I have a '95 that I bought to flip, hate the automatic, If I were keeping it it'd get a 5-speed too.
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old July 1st, 2015, 09:05 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Dan- I've heard mixed stories in the past. You are saying without uncertainty that the D1 5 speed pedal box will bolt right into the soft dash 95?
Old July 1st, 2015, 11:45 AM
scatterling's Avatar
scatterling
Neil Hanekom
75 109 exMOD
PM sent
Old July 1st, 2015, 11:46 AM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
Well...I guess I can't say it without a slight bit of uncertainty as I haven't actually tried to do it. But I've compared the pedal boxes from both and haven't been able to find any difference between them. For that matter, as I mentioned before the pedals are on a common shaft for the soft dash RRC/DI, and the single pedal for the automatic is the same way, it's on a long shaft which goes all the way across so it should be simple enough to unbolt the shaft and slide it out, remove the single brake pedal and install the brake and clutch pedals from a DI, then drill the hole for the clutch master cylinder. I don't know if there's room under the dash to do this in place, but I plan on giving it a shot when I find a '95 that I want to keep and convert it to 5-speed.
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Wheel locking driving at top speed. MattD Defender Technical Discussions 12 February 19th, 2007 04:54 PM
Defender fan speed switch used draaronr For Sale - Parts 0 January 1st, 2005 11:22 PM
speed sensor wiring rcork Defender Technical Discussions 2 July 27th, 2004 09:44 PM
Help Speed Limiter evilfij Misc. Chit-Chat 10 May 7th, 2004 10:04 AM
speed liner or rhino liner TDI Guy Misc. Chit-Chat 5 May 5th, 2004 09:27 PM
