WTB 300 TDI fuel line and banjo - Defender Source
Old March 29th, 2016, 06:20 AM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
I need either the whole fuel line or just the banjo fitting (not the bolt) for a 300 TDI from fuel filter to injector pump.
Old March 29th, 2016, 07:57 AM
Cheap enuf:
WJP000220 - Fuel Pipe Filter to Pump 90/110 TDI
Or this?
http://www.johncraddockltd.co.uk/lan...r-to-pump.html
Dig around here to find your exact part:
http://new.lrcat.com/#!/1228/20326/20390/1579/21023
Old March 29th, 2016, 09:26 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I have a whole drawer of barbed fittings.
Are you running the stock filter?
Do you have a bad line with metal fittings on each end?
Do you know exactly what you need fitting wise.
You can run rubber line between the fittings and use hose clamps.
Am sure I can help if you provide more info.
If you want a whole set of new lines, Bills suggestions will work.
RDavisinVA
300 tdi, fuel, tdi
Good source for metric banjo bolts and hard plastic line Overlander Defender Technical Discussions 2 October 9th, 2013 08:46 AM
200Tdi injection fuel return line banjo bolt Apocalypse Vehicle Defender Technical Discussions 8 August 20th, 2013 11:13 AM
Fuel filter banjo bolts and fittings El Solis Defender Technical Discussions 9 March 5th, 2012 12:11 AM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
300 Tdi single fuel line michael67 Defender Technical Discussions 5 April 12th, 2011 09:51 PM
