WTB 2.25 petrol flywheel - Defender Source
Old October 23rd, 2014, 01:44 PM
greenmonster
Scott McGonigle
1971 series IIa 109
I need a flywheel for clutch replacement repair. Minimum thickness is 39mm before discard, mine is too thin. Any help or direction also appreciated....rovers north does not have any.
Thank you,
410-299-2702
boatcheck @ yahoo . com
Old October 23rd, 2014, 01:55 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Scott-- please let us know if you find one on here as we are still checking all our sources for one for you. Thanks!
Old October 23rd, 2014, 02:02 PM
Linoge's Avatar
Linoge
Jonathan
1985 D90
I'm not sure what became of it or what condition it is in (the engine had ~155,000 miles on it), but I'm sure the flywheel came out of my 2.25L Rover when they did the engine swap. I can check with the shop the truck's and pieces are at if you're interested.
Old October 23rd, 2014, 02:07 PM
greenmonster
Scott McGonigle
1971 series IIa 109
Jonathan, that would be great, just depends on how aggressive they were when resurfacing in the past. In addition to thickness, please verify the pilot bushing hole is 1 1/8" in diameter.
Old October 23rd, 2014, 02:53 PM
rovertrader's Avatar
rovertrader
Dale
I have a 2.25 in a 109 if you want to go through getting it out/apart.
Old October 23rd, 2014, 03:20 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I have a knee high stack of used 2.25 flywheels.
RDavisinVA
Old October 23rd, 2014, 05:31 PM
staufferdave6
dave stauffer
1986 110
flywheel
Yes you do Robert and your knees are 10 feet from your feet. Ive seen the stack.
Old October 23rd, 2014, 05:37 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Scott we have one coming for you if you still need it, should be with us in the next few days. Let me know
Old October 23rd, 2014, 06:05 PM
greenmonster
Scott McGonigle
1971 series IIa 109
Zack, did you mean one coming for me??. Robert might have a used one that works, we are still sorting it out. I would still prefer new if possible, as I don't have any plans for drive train replacement.
Robert is indicating there is a different flywheel for the 3 bolt main and the 5 bolt main engines. Tthe bolts that hold my flywheel to the crankshaft are larger (14mm) so I assume my turner engineering remanufactured engine has the 5 bolt main.
I know I need the 1 1/8" diameter hole for the pilot bushing.
Old October 23rd, 2014, 07:02 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Sorry, yes, fixed
It'll be here within the week, I can shoot you some photos and measurements before you make a decision if you'd like.
Old October 23rd, 2014, 07:24 PM
greenmonster
Scott McGonigle
1971 series IIa 109
Zack that would be great. Please use my email or phone. As I don't get on the forums much.
Old October 24th, 2014, 05:05 PM
Linoge's Avatar
Linoge
Jonathan
1985 D90
Sounds like my flywheel is 1.5" thick, but the bushing hole is also 1.5" large. Sorry.
Old October 24th, 2014, 06:39 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
We have about 20 to 30 engines in the workshop, so I can compare 3 to 5 main if necessary.
We have just about every Land Rover engine older than a TD5 starting with Series I.
There are also Diahatsu, Iveco, & Isuzu 2.8 Turbo Diesels.
The small peppy Perkins Prima 2.0 Turbo Diesel used in the MG Maestro, and a sload of TDi engines.
We also have 3 rows of Mercedes OM617 engines and crummy old Rover V8s.
Am in the process of building what may be the last batch of GM 2.5 4 cylinders.
So you'll have to forgive me if the flywheels all run together after a while, but the Rover flywheel stack is there if Zack is unable to provide one.
There are other stacks, but at least all the Rover ones are in one place.
Also counted 11 Series 3 main cranks and a few cylinder heads if you know of anyone in need.
RDavisinVA
Old October 24th, 2014, 07:25 PM
greenmonster
Scott McGonigle
1971 series IIa 109
Robert,
Just emailed you. Zack's is 1.41" or 35.8mm. Too thin. Need minimum 39mm. Also 2" approximately between flywheel center to center of bolt hole. You may be my only hope.
Let me know what you can come up with. It is much appreciated.
Old October 24th, 2014, 07:35 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Email reply sent.
BTW no way the measurement is 2" center to center.
RDavisinVA
Old October 25th, 2014, 09:33 AM
greenmonster
Scott McGonigle
1971 series IIa 109
Robert, you're right. After looking at picture I think he measured between holes edge to edge. I won't be able to get to the truck until Monday to measure myself.
Old October 25th, 2014, 09:48 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Since that knee high stack of flywheels is not going anywhere over the weekend, I think you are safe to send correct measurements next week.
RDavisinVA
Old October 26th, 2014, 02:06 PM
3 main starter has two bolts and an inertia drive. 5 main unit uses three bolts and is a pre engaged type with a solenoid on the side
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old November 2nd, 2014, 05:44 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Found the flywheel you're looking for.
emailing paypal info.
RDavisinVA
Old November 3rd, 2014, 10:27 AM
greenmonster
Scott McGonigle
1971 series IIa 109
Thank you all for your help. I will be buying Robert's flywheel.
wheel
Need flywheel for 2.25 petrol greenmonster Series Technical Discussions 10 February 19th, 2015 08:57 PM
200tdi Flywheel housing and Flywheel Apocalypse Vehicle Wanted 0 October 11th, 2013 06:48 PM
Series 3 RHD 2.25 Petrol :: 1977 Land Rover Series 3 RHD 88" 2.25 Petrol fsquared11 Defender & Series Truck Registry 0 September 20th, 2013 12:42 PM
WTB: 200TDI or 300TDI flywheel Mike Sandone Wanted 0 September 10th, 2011 02:12 PM
Need 3 2.5 Petrol Flywheel Hosuings ASAP SafariHP Wanted 0 August 3rd, 2010 01:20 PM
