WTB: 1 steel wheel anr4636 - Defender Source
Old January 13th, 2008, 01:03 PM
I need a single anr4636 steel to match the other 4 I have. I will be painting it so it doesn't have to be pretty but needts to be straight.
My current spare is a narrower steel wheel (not sure of the number and it's at the bottom of the pile right now), but would be willing to trade as well.
Anyone have one?
Old January 13th, 2008, 01:30 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
is that the Disco 1 steel spare?
Old January 13th, 2008, 03:34 PM
Not sure. I can tell you in a couple of days - looks just like the anr4636 but maybe 1/2" thinner.
Old January 15th, 2008, 04:41 PM
Charles if it looks like the wheels on the blue 110 I sent you this morning you may be in luck-that truck has two spares and I was going to put alloys on it any way.
Old January 15th, 2008, 04:45 PM
Yes it very most likely is! Will add it to the list of things to compare on our trucks
I warn you that switching to alloys will require a modified hub cap on the alloys (might be available in the UK) or spacers which are $$
charles
Old January 15th, 2008, 04:49 PM
Charles- I have the deep dish alloys which should fit over the 110 hubs- if not I have a set of 4 30mm spacers. I may end up using spacers on the front to retain the stock turning radius.
Old January 15th, 2008, 04:51 PM
his spare is a 272309 which is an old 109 wheel. they are 5.5" wide with a different offset than the anr4636.
charles if nobody wants the old 109 unit I will happily relieve you of it.
the anr4636 is readily available and fairly inexpensive.
dave
Anyone have one?
Old January 15th, 2008, 04:59 PM
Doug, sounds good, just wanted to make sure you were aware. Sounds like you are on top of it.
Dave, roger that.
charles
Old August 30th, 2009, 06:57 PM
Blakesrover
Blake
Disco 1
what is the difference in offset?
I have been trying to find the ANR4636 5.5" x 16" but have only had people call me with the earlier 109 wheels 272309.
What is the difference in the offset of these two wheels? I know the offset of the 272309 is 1.75" but cannot find the offset for the ANR4636.
I thought the ANR4636 is wider, but, how much wider? is it a notcieable difference?
Also, is there any difference between these two wheels at all in the manufacturing/rating beside the offset? If so what are those?
thanks.
bperry83@gmail.com
Old August 30th, 2009, 10:23 PM
They have different provisions for the wheel nuts too although they seem to work on the newer studs.
wheel
WTB: 1- NAS 110 steel wheel mud ruts Wanted 1 January 27th, 2009 07:20 PM
WTB: 15" steel wheel - pref 15 x 8 black B-Kerr Wanted 1 February 22nd, 2007 08:01 AM
Steel Wheel Lug Nuts woldd90 Wanted 1 November 19th, 2005 07:44 PM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
Discovery I Steel "wagon" spare wheel... RedRhinoProducts Wanted 0 December 8th, 2004 08:10 AM
