wtb 1.4 transfer case - Defender Source
Old March 7th, 2015, 07:06 PM
TOM R
tom
1998 D1
To put in my 98 d1 please email , I am in northern neck of va. And outside Philly in south jersey
The jerk 67 at Comcast dot net
Old March 7th, 2015, 08:41 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Why on God's green Earth do you want a 1.4 for a Disco.
Old March 7th, 2015, 09:12 PM
TOM R
tom
1998 D1
Better ratio for my slightly larger tires with the no power 4.0 v8
Old March 7th, 2015, 09:18 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
How big of tires? A TC swap is good for Hi range but does nothing for your Low range.
Old March 7th, 2015, 09:27 PM
TOM R
tom
1998 D1
Fish we already had this discussion on land rover forums, my low range is fine as is, just need better on road
245/75/16 plus the extra weight
Old March 7th, 2015, 10:58 PM
jafir's Avatar
jafir
Jafir Elkurd
Might try here:
http://www.defendersource.com/forum/...ase-58054.html
Old March 8th, 2015, 09:05 AM
TOM R
tom
1998 D1
thanks just sent him a pm
Old March 8th, 2015, 10:45 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You're going to be screaming at 75, just warning you!
Old March 8th, 2015, 12:11 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
That was my thought. Have you run the numbers through the Ashcroft Ratio Calculator? I've never heard of anyone rehearing to run 245/75/16's, and almost nobody regears for 235/85/16's either. If your truck is really struggling on 245/75/16's I'd be looking to other areas like the engine/compression.
Old March 8th, 2015, 01:02 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I agree with Zach and Fish... Mind you if you are looking for power on long steep mountain type hills, you need another engine... Or truck. Check out the Ashcroft ratio calculator... Those tires shouldn't call for such a drastic regearing.
Old March 9th, 2015, 08:38 AM
TOM R
tom
1998 D1
Yes I know my engine needs rebuild its in the works, Ashcroft converter says ( I can't remember what stock diff ratio is on d1) 1.4 transfer case with 375 diff, just under 3k rpm at 70 MPH
But where they sell the gears elsewhere on the site says 1.4 gears common for discovery with larger tires or towing, I am also building a trailer for camping to tow
Old March 9th, 2015, 09:30 AM
I pulled a 2300 lb car trailer with a 130 on it with a D1 on 235/85's.
I don't think you need to re-gear.
Old March 9th, 2015, 10:11 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You're looking at about 250-300 higher RPM's at highway speeds.
Old March 9th, 2015, 10:12 AM
Fix the engine. You have little tires. Changing the gearing is crazy. I would plan to swap in a new cam, chain and sprockets as that is most likely the problem.
Old March 9th, 2015, 10:18 AM
jafir's Avatar
jafir
Jafir Elkurd
I'd be screaming at 75. Screams of joy. I've maybe had the speedo read 70 once, and in sure it wasn't telling the truth.
Old March 10th, 2015, 09:43 AM
TOM R
tom
1998 D1
Nevermind
transfer case
WTB - 1.4 lt230 transfer case MarkNS Wanted 2 October 4th, 2014 05:53 PM
WTB series 1 ton transfer case (or 1.53:1 gear set for series tcase) cgalpin Wanted 3 March 7th, 2013 09:54 AM
wtb TRANSFER CASE tugo Wanted 8 February 11th, 2013 09:24 PM
Nylock nut size, rear flange of transfer case - also identify T-case ratio hillstrubl Defender Technical Discussions 3 July 11th, 2012 02:42 PM
transfer case . . . transfer Abrooks Defender Technical Discussions 38 October 20th, 2008 09:04 AM
