Wolf PVC soft top - Page 2 - Defender Source
Old June 26th, 2015, 09:16 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I can't add to the reasoning of "why", all I can say is that Exmoor has given us that answer time and time again. If you can get it to fit, please post up here and I'll relay that to Exmoor.
Old June 26th, 2015, 09:29 AM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
I bet the farm it fits. They probably don't want you to cut the top because of warranty issues. If it fits a Wolf it will fit a Tithonus without the front exo cage. I ran mine without it for a while before I got the nerve to cut it. Good luck
------ Follow up post added June 26th, 2015 09:35 AM ------
Originally Posted by chris snell View Post
That's the approach that Dale and I have been chatting about. It's a pretty good way to do it if you're otherwise happy with the Tithonus cage. It's just not an option for me because the x-bars get in the way of a gun rack. Sleeping in the truck is also an issue. I'm tall and I would need to make a little extension of my sleeping platform to fit my feet forward of the bulkhead but it's just not possible with the x-bars.
Why don't you just reman the B hoop without the X brace? That way you keep the original top and the rest of the cage.
Old June 26th, 2015, 09:41 AM
rovertrader's Avatar
rovertrader
Dale
Originally Posted by solarguy View Post
My research has led me to this. The Wolf and the Tithonus are identical except the front exo cage. My understanding is that there wasn't a top made for the Tithonus, it was a Wolf top that was manipulated to fit the Tithonus. I spoke to the manufacture and that is what they told me. I followed what they told me to do and it worked out fine. The cutting of the top is a hard thing to swallow.
The only 'cut' would be for the bolt and/or puck to go through where the A to B hoop attaches right?
Also, if the B had the X brace removed, you could add a smaller diagonal higher up in the corner so to speak, that didn't interfere with the bed platform.
Old June 26th, 2015, 01:03 PM
solarguy's Avatar
solarguy
Abraham Bell
Originally Posted by rovertrader View Post
The only 'cut' would be for the bolt and/or puck to go through where the A to B hoop attaches right? Also, if the B had the X brace removed, you could add a smaller diagonal higher up in the corner so to speak, that didn't interfere with the bed platform.
Correct. That's all I had to do.
Old June 26th, 2015, 01:34 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Thanks, Abe. I'm positive you're right. If this is the case, my plan is to get the local awning company to stitch a reinforcement around the bolt/puck and add a Velcro flap to the slit that has to be cut. I think it should look pretty "factory".
That's an interesting idea. But, if you're going to go to the trouble of building another B hoop, why not build lower C and D hoops while you're at it? I'm so conflicted on this problem. On one hand, I want my rifle mounts and I want to be able to sleep back there but the price is an entire cage build.
Do you think a fabricator could cut/grind the X brace off and make it look good?
------ Follow up post added June 26th, 2015 10:37 AM ------
The great irony of it all. I'm cutting a Tithonus top. This must be great entertainment for Raub.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old June 26th, 2015, 01:53 PM
rovertrader
Dale
Chris, I will check it when I return home, but pretty sure it should be quite simple. I will run it by Bill at RTE and get his thoughts as well....
Old June 27th, 2015, 09:24 AM
solarguy's Avatar
solarguy
Abraham Bell
If you already have the top that fits the cage there is no need to redo the whole cage. Just reman the b hoop at original hight with out the X brace. Problem solved. Am I missing something?
Old June 27th, 2015, 05:11 PM
chris snell
Chris Snell
87 Ex-MOD 110
It won't make sense to most but I really want a canvas top, the standard kind that Exmoor makes. I don't care for the look of the PVC and the added height of the Tithonus cage looks funny to me. I sometimes wish I had bought a standard ex-MOD instead of the Tithonus since I ended up replacing everything but the body and dash anyway.
2013 LR4
Old July 4th, 2015, 12:42 AM
chris snell
Chris Snell
87 Ex-MOD 110
So here's the deal: the Exmoor top absolutely works on the Tithonus roll cage. There is one minor modification to the top required but it takes less than a minute and requires no sewing or other major alternations. You will need some parts to do the swap. Fortunately, Brian at Defenders Northwest had them in stock and I was able to get it all done wrenching by myself in one long, sweaty day. I will be posting up the details of the conversion in the small projects forum but in the meantime, if you need the parts to do this, talk to Brian before buying a top and he can get you squared away.
This is an amazing top, far exceeding my expectations. I was dreading the idea of a PVC top and I figured that I was buying something that would get me through the summer until I could take the cage off and mod it. I was blown away when I unpacked the top. It's incredibly well-designed and well-made. In fact, I'm changing my whole plan and keeping this top and cage. I'll be modding the B pillar to alter the X-brace but the rest is staying.
More details coming soon.
The Summer Outfit by Chris, on Flickr
2013 LR4
Old July 4th, 2015, 07:08 AM
greenmountainrover's Avatar
greenmountainrover
Derek Chace
84 Lightweight FFR
Where did you get the pvc top and how much was it? My ex mod 110 needs a new top.
Green Mountain Rovers your Defender/Series sales and importation specialist.
802-655-4874
Old July 4th, 2015, 11:11 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Looks awesome!
Old July 4th, 2015, 11:17 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Exmoor manufactures this top - If you don't have the WOLF or Tithonus cage on your truck the top will not work…
Our fixer is in the UK at the moment and was able to run down this solution in person with Exmoor and confirm the additional items needed. We will be pulling together a kit next week for any Tithonus owners who want to do the conversion - and if stock allows we can plug in a pre-order special for D-Source.
Old July 4th, 2015, 11:27 AM
rovertrader
Dale
Well crap, this certainly poses a problem!! It looks great Chris!!
I, like Chris, wanted the canvas top, with windows, and half the cost- but requires chopping the Tithonus cage 2-3". The PVC offers no windows, but really does look nice- and allows 3" more headroom for us tall guys!
Brian, I have two Tithonus, so put me down for two kits- asap please, just PM payment info. I may do one canvas and one PVC, but after seeing Chris' pic, it sure is tempting to just do the Wolf and be done.
Thanks for trying the Wolf Chris, and look forward to your write up!
Cheers, and Happy Fourth!!
Old July 4th, 2015, 11:41 AM
greenmountainrover
Derek Chace
84 Lightweight FFR
damn I love the PVC look but I only have a normal ex mod 110.
802-655-4874
Old July 4th, 2015, 11:53 AM
Not worthy!
Old July 4th, 2015, 12:05 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
Dale, I do have one Tithonus PVC top in khaki green with side windows for you . Brand new. Custom ordered from the original supplier of these tops.
Old July 4th, 2015, 12:54 PM
chris snell
Chris Snell
87 Ex-MOD 110
I believe that the Exmoor top is an improved model over the standard MOD PVC tops manufactured by Trim Technology. Not 100% certain but I believe that Exmoor has added some usability features that are common with their new line of civilian PVC tops.
There is one window in the back, not unlike the window you'd get on a Badger. The good news is that additional windows should be very easy to add for people that want them. These tops are PVC and about the same thickness as a commercial-grade tent like you'd hire for a wedding. Most cities have awning manufacturers and they should be able to add the windows to your spec.
Like I said earlier, I'm blown away by the quality. I love Badger tops and Chris Laws is an awesome dude but if you're unwilling to wait the year+ to get a Badger, this is an near-equal solution IMHO if you're willing to give PVC a shot. The stitching quality is absolutely equal to Badger and in many areas, the attachments are even better than Badger. The fitment on my Exmoor is somewhat loose because I'm lacking the overhead ribs on the top of the cage but we're tracking those down and that will make it fit more tightly. Even without the ribs, there is no flapping around on the highway--it's just a more rumpled appearance.
2013 LR4
Old July 5th, 2015, 09:14 AM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
Hey Chris looks great, good find! We are interested in one of those for my son's tith.
Regarding the X brace I cut it off as soon as I got the tith. I just felt it was too intrusive so it was one less thing to worry about when I cut down the cage.
As for the overhead ribs I purchased a couple for series 88/109 at RN. They have a somewhat closer angle but look ok for my standards.
Old July 5th, 2015, 12:02 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
I don't get the no side window thing. The first batch of tops we ordered had no side windows. It was like a tunnel back there. Down right dangerous. We had side windows installed. This new batch was custom ordered with them .
I am sure you have very good reasons as to why you did not want side windows, Chris. Would love to hear it.
Old July 5th, 2015, 12:19 PM
rovertrader
Dale
Ken, are you in Florida or up north? We are in Satellite Bch and can run down to grab the top- lets chat tomorrow.
soft top, top
PVC 110 top l.a.rover Defender Technical Discussions 2 November 17th, 2013 06:34 PM
Wolf XD Extruded Aluminum soft top door tops Trey C For Sale - Parts 4 August 27th, 2013 09:33 PM
Whos running PVC softop? josh-man Defender Technical Discussions 7 August 8th, 2013 03:38 PM
Found vacuum hose loose on what looks like the fuel rail PVC valve flananuts Defender Technical Discussions 10 May 29th, 2013 07:27 PM
Wolf/Tithonus soft top for 110 chris snell Wanted 9 April 27th, 2013 12:41 PM
