where to find a throttle position sensor? - Defender Source
Old May 8th, 2014, 09:31 PM
jackD90
jack a smith
1995/D90
help! i need a throttle position sensor for my '95 defender. who has one or where do i call to find one?
Old May 9th, 2014, 07:18 AM
I have one but why do you need one?
Lots of people guess they have a fault but really it's actually a problem elsewhere.
Old May 9th, 2014, 10:34 AM
Erik@Lucky8's Avatar
Erik@Lucky8
Erik
1985 D110 Ex-MOD & a few others
$135/shipped.
Brand new genuine.
Current:
2007 Range Rover L322 - 4.4L HSE LUX
2003 D2 - Monte Carlo Blue 2" TF lift
1991 RRC Hunter - 2" OME
1985 D110 EX-MOD
Gone:
2006 LR3
2004 D2
2001 D2
2001 D2 - Lucky8 Project D2 - REDUX
2000 D2 - Trail Project, maybe
1999 P38
1995 RRC LWB
Old May 9th, 2014, 10:42 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Originally Posted by Erik@Lucky8 View Post
$135/shipped.
Brand new genuine.
Uhh.. what? I'll take every single one you have/can get. These are NLA and the cost was more than double that when they were available.
Old May 9th, 2014, 10:45 AM
Erik@Lucky8
Erik
And resell them for $150?
http://www.roversnorth.com/Products....search=err4278
Current:
1985 D110 EX-MOD
Gone:
2006 LR3
2004 D2
2001 D2
1999 P38
1995 RRC LWB
Old May 9th, 2014, 10:50 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
That's not the correct part, but you're more than welcome to sell him that one
ERR2263
------ Follow up post added May 9th, 2014 10:51 AM ------
Trying to corner the market?
-Jeff
I get enough calls about them that they're worth having
Old May 9th, 2014, 10:58 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Check Will Tillery for a used one. If I recall correctly, I bought the last new one from one of you guys for my old NAS truck.
TPS...one of the many reasons I'm so glad to run a three hundy now.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old May 9th, 2014, 11:07 AM
Erik@Lucky8
Erik
ERR2263
Microcat says my part good for Defender. Microcat says your part for RRC and D1.
Current:
1985 D110 EX-MOD
Gone:
2006 LR3
2004 D2
2001 D2
1999 P38
1995 RRC LWB
Old May 9th, 2014, 11:14 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Come on... Microcat for a NAS Defender, you know better!
Old May 9th, 2014, 12:11 PM
Can't you swap pigtails between the early and later?
Old May 9th, 2014, 12:34 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You may be able to swap pigtails, but I'd be surprised if it still worked correctly with the different connections...some modification required
ERR4278:
ERR2263
Old May 9th, 2014, 12:54 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
I would be surprised if it went bad, except for the wires. These are Hall Effect sensors, I believe, nothing to wear out, since the magnet never contacts the windings.
Old May 9th, 2014, 01:10 PM
They go bad all the time.
chris snell
Chris Snell
87 Ex-MOD 110
They do go bad. When mine went bad, the engine would suddenly lose power. Replaced the TPS and the problem went away for good. And yeah, ERR2263.
2013 LR4
Old May 9th, 2014, 01:11 PM
Dogpilot's Avatar
Dogpilot
James Wallace
The sensor itself does not wear, but again the wires do.
Old May 9th, 2014, 01:26 PM
Are you sure they are hall? I think I cut one open and it was a potentiometer
Old May 9th, 2014, 01:27 PM
What makes you think they are hall effect sensors? I figured they are simple pots.
Old May 9th, 2014, 01:29 PM
Okay... I just read the manual and it clearly says they are a potentiometer and that is how you test them.
Old May 9th, 2014, 01:31 PM
and as such they can be easily tested and verified for correct operations.
Old May 9th, 2014, 01:36 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Well dip me in sheepshit. Most all OBDII systems use Hall sensors. Mainly due to wiper bounce on potentiometers wipers. It drive the primitive computers OBD systems use crazy. Even most OBD I systems used them for less computing required to sample the sensor repeatedly to filter out the bounce. Manufacturers readily used off the shelf engineering, just adapting the systems to their specific vehicle, but the block engineering remains similar, why many sensors items cross over between multiple vehicles of divergent makes.
sensor
Throttle Position Sensor Source?? rgrrvr Defender Technical Discussions 34 April 10th, 2013 09:56 PM
Throttle Position Sensor (TPS) Duke D90 Wanted 0 April 3rd, 2010 05:15 PM
TPS - Throttle Position Sensor for 1997 D90 #ERR4278 pcscharfe For Sale - Parts 11 August 27th, 2009 02:31 PM
Idle problem - Throttle position sensor? JBfoot Defender Technical Discussions 20 January 7th, 2008 11:45 AM
Throttle position sensor chrisvonc Wanted 0 April 24th, 2005 05:57 PM
