Wheel Spacers - Defender Source
Old March 22nd, 2011, 08:51 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Smile Wheel Spacers
Need some Wheel Spacers for the 1997 Defender
R
781 640 264zero
Old March 22nd, 2011, 09:03 AM
is the $87 a pair guy still on ebay ? I have been running those for over a year and like them.
Old March 22nd, 2011, 09:31 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
sure looks like it!
http://cgi.ebay.com/ebaymotors/HUBCE...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Wheel...Q5fAccessories
Old March 22nd, 2011, 09:33 AM
Doug are you just running a pair in the front? Thinking of doing the same.
Old March 22nd, 2011, 09:37 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I bought some "defender" spacers from the optionselects guy on ebay and I am returning them today because they actually don't fit my truck. They are for a Dicso 2. Maybe he will send the right ones out to you, but heads up.
------ Follow up post added March 22nd, 2011 09:48 AM ------
So now I am confused...
Maybe you were just offering two different options, but...
The optionselects one is 5 bolt with 4.75" spacing and a 14/1.5 threaded lug.
The ezaccessory one is 5 bolt with 6.5" spacing and a 16/1.5 threaded lug.
I bought the optionselect one that was supposed to fit a defender but also was listed as 5/4.75" and 14/1.5 lugs and it certainly didn't fit.
I believe the ones that fit a defender are the 6.5" and 16/1.5 lugs. Is this true? I would measure but my truck is at the shop so I am helpless, but still kinda confused, and I guess a bit frustrated too
Old March 22nd, 2011, 10:03 AM
I have a set front and rear. Fronts are all that's necessary. Not sure who all have them but Gustavo,Jonathan, myself, and others have been running them for some time with no issues.
Mine came from the ezaccessory place
Old March 22nd, 2011, 10:11 AM
Rugbier's Avatar
Rugbier
Gustavo
Yes the second link is the one ezzaccessory guy
NO SIGNATURE
Old March 22nd, 2011, 10:21 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Do you use threadlocker or anti seize or a combination of both. I feel like I have heard of issues with aluminum spacers against steel hubs. Maybe antisieze between the two and threadlocker on lugs?
Old March 22nd, 2011, 10:26 AM
This always comes to mind.
http://www.defendersource.com/forum/...ad.php?t=26316
------ Follow up post added March 22nd, 2011 10:28 AM ------
Cool, thanks. Anything special I need to know about the ezaccessory ones before I buy them for the '95 with boost wheels? I've read that with some the threading is for the steel lugs, but I'd be running the alloys.
Old March 22nd, 2011, 10:30 AM
Rugbier's Avatar
Rugbier
Gustavo
I have run spacers in several applications , the main concern is the tend to expand after the first 50-100 miles, so install them, run them hard, then re-tight and be good ( even if they did not expand, do it just for the sake of it )
NO SIGNATURE
Old March 22nd, 2011, 10:32 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Thanks Josh. Thats probably what I was thinking of.
Old March 22nd, 2011, 11:13 AM
ron's Avatar
ron
Ron
Jeff
Yes the same thing happened to me will be shipping mine back today. I will try the EZ option.
Old March 22nd, 2011, 11:16 AM
Ron, will you be running them with LR alloys? Just trying to confirm that the EZ ones listed will work with the capped lugs I have.
Old March 22nd, 2011, 11:19 AM
ron's Avatar
ron
Ron
ok how about wheel spacers for a defedner bolt pattern to RR L322 bolt pattern?
I have some 18's hub centric with brand new MTR kevlars.
Old March 22nd, 2011, 11:23 AM
ron's Avatar
ron
Ron
yes will be running 295 75 16 on stock NAS rims.
Old March 23rd, 2011, 11:48 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Silverline in the UK sells some but because they are not as popular they are more expensive.
Old March 23rd, 2011, 01:00 PM
Rugbier's Avatar
Rugbier
Gustavo
They is absolutely no relation when using the spacer to the lug nuts ( the thread and length is the correct one as if did not have spacers ) .
I have run, steels, Alloys ( Freestyles, Deep Dish and boost ) with no issues
NO SIGNATURE
Old March 23rd, 2011, 01:07 PM
Duh, that makes sense now that I think about it, as it's just a pass-through the spacer. Thanks Goose
Old March 23rd, 2011, 01:23 PM
Rugbier's Avatar
Rugbier
Gustavo
Josh,
it is not a pass through
Spacer mounts to the hub using the studs on the hub, then the spacer has its own studs replicating the studs on the hub.
Now go get some coffee and wake up
NO SIGNATURE
Old March 23rd, 2011, 01:28 PM
I feel dumb. Thanks Goose
ac, wheel, wheel spacer
Need wheel spacers. tobit3 Wanted 9 August 4th, 2005 03:01 PM
Safarigard 1" aluminum wheel spacers dannykkim Defender Technical Discussions 1 March 7th, 2005 04:29 PM
wheel spacers krisp For Sale - Parts 15 November 30th, 2004 11:03 AM
Wheel spacers Dfndr90 Defender Technical Discussions 1 September 9th, 2004 12:22 AM
Wheel Spacers? Joe P Misc. Chit-Chat 5 April 9th, 2004 12:24 PM
