weber carb for 2.4 4cyl - Defender Source
Old May 2nd, 2013, 02:25 AM
chasrover's Avatar
chasrover
I am looking for a weber carb for a 1986 90. 4 cyl 2.5. (I know it says 2.4 in heading)
Old May 2nd, 2013, 06:55 AM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
Sent PM............
Todd
'95 D90 #2206
'66 109" P/U
Old May 2nd, 2013, 06:58 AM
chasrover's Avatar
chasrover
Needs to be double barrel 32/36 i believe.
Old May 2nd, 2013, 08:24 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Stock or replacement?
The stock carb is an odd size 32/34 DTML.
Search eBay UK and you'll see:
"WEBER 32/34 DMTL CARB ETC7144 LANDROVER 2495cc 90/110"
This is the same carb used on the 2.25 D-90.
If you want to install a 32/36, you'll need a manifold like this:
http://www.ebay.com/itm/Land-Rover-H...-/261118200222
Both are subject to having the needle & seat stick and overflowing fuel, so look at getting a viton tipped seat.
If you use the 32/36, you'll need to re-jet as the "out of the box" setup is way too rich.
Also trace the feed line from the tank and your 90 may have a small metal fuel filter housing with a replacement paper element inside. Remove that thing and toss it. Then use an inline unit. If you already have an inline unit, replace it.
Hope this helps.
RDavisinVA
Old May 2nd, 2013, 08:30 AM
chasrover's Avatar
chasrover
Thanks for that. I couldn't remember which one I needed. That is it. I have found one from Craddocks but I need it sooner than later so I wanted to see if I had any hits here first. I don't need new either used is fine but I will take a new one if it is in the US.
Old May 2nd, 2013, 10:16 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Used?
If you want reliability, get a new one with a viton tipped needle in the needle & seat that regulates fuel based on float level.
If you want to struggle with a used one that will always give you problems, I may have one or 10 of those lying around.
RDavisinVA
Old May 2nd, 2013, 10:21 AM
chasrover's Avatar
chasrover
This is for a quick fix. on an engine that won't be in the truck for long. I just need it to move under its own power for a month tops.
Old May 3rd, 2013, 06:37 AM
chasrover's Avatar
chasrover
Do you have one lying around?
Old May 6th, 2013, 06:38 AM
chasrover's Avatar
chasrover
I am still looking for this carb. Used is fine.
Old May 6th, 2013, 08:31 AM
kjva
Ken Jackson
1985 110 Wagon
I have a recon Weber I put on a 2.25 85 110 then shortly after put a 200tdi in it.
Will check the model and let you know.
Old May 6th, 2013, 08:39 AM
chasrover's Avatar
chasrover
Thank you.
Old May 7th, 2013, 09:08 AM
chasrover's Avatar
chasrover
OK I am still looking for a Carb state side. Now the bank holiday is over in England I might have to go that route. I figure it is worth one more try to find a cheap used one here in the states. A couple people seem to have them but then they disappear to never be heard from again. If you have a 32/34 double barrel Weber Carb for a 2.5 even if it is in pieces I would love to take it off your hands ASAP.
Weber 2BBL Carb Set Up? texrover Series Technical Discussions 19 June 5th, 2012 12:05 AM
Weber carb 34 ICH manual choke for series IIA and III aka rover For Sale - Parts 0 December 13th, 2011 11:25 PM
Carb difference and door panels DIVERPRO Defender Technical Discussions 2 March 20th, 2005 05:31 PM
a one carb manifold for the V8 engine DIVERPRO Defender Technical Discussions 3 March 9th, 2005 11:46 AM
twin SU carb and intake off of a 3.5 draaronr For Sale - Parts 1 January 1st, 2005 11:28 PM
» Defender Registry
D-Storm
LI90
Cash
gilby
Add your Defender
