Wanted: Wing-top snorkel flexible hose - Defender Source
Old October 21st, 2014, 09:31 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Anyone know where I can get this kind of snorkel hose with the proper hose-end cuffs (this one is by Masai and has a length of 300mm or about 12 inches) but in a 16-inch length (or thereabouts) with a 2.75 or 3.00 inch inner diameter?
Thanks guys
Old October 21st, 2014, 10:18 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
-Ren Ching
Old October 21st, 2014, 10:47 AM
you can get silicone hose in black for a fraction of that cost if you're not a purest
Mark Kellgren
KM4BOR
Old October 21st, 2014, 10:49 AM
rankar's Avatar
rankar
Steve, that looks to be the same length? Or is that really 16" or so? I couldn't find it on the site (I'll have to call RN).
------ Follow up post added October 21st, 2014 10:50 AM ------
Not a purist Mark. But can you get a silicone hose to have the cuffs at the end for a cleaner look and a tight seal?
Old October 21st, 2014, 11:31 AM
you don't need cuffing on regular hose. only on the convoluted hose where the clamp can't make a clean seal all around.
Mark Kellgren
KM4BOR
Old October 21st, 2014, 11:58 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I bought 5 feet for less than $30 from mcmaster carr, looks the same without the cuff. Works fine.
flex, snorkel, top, wanted, wing
WTB Short Snorkel engine bay snorkel hose bradfordish Wanted 3 March 17th, 2014 01:58 PM
flexible intercooler hose Sandt Defender Technical Discussions 2 May 6th, 2013 03:55 PM
flexible stereo antenna recommendations wilyliang Defender Technical Discussions 15 March 19th, 2013 10:31 PM
Wing Top Snorkel for 300Tdi CMSgt Bo Wanted 3 December 21st, 2012 03:43 PM
Wing top Snorkel mounting 1995 d-90 3.9/petrol Overland90 Defender Technical Discussions 3 September 11th, 2008 04:58 PM
